Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 30, 2009, 09:35 AM   #76
JEP
Personal Sales Rating: (0)
JEP's Avatar
Drives: 08 Evo X, supercharged dodge viper GTS, SVT Focus Euro Package, 2008 GSXR 1000
I talked to my local dealership the service manager says their is no TSB for this problem!!! I would think it would throw a code (lean Condition)...
Offline
Old Aug 30, 2009, 04:56 PM   #77
mufasis's Avatar
Drives: 08 Mitsubishi Lancer Evolution X GSR
Send a message via AIM to mufasis
would it be possible to talk to north america mitsu and have them look into this?
__________________
03 Subaru WRX - Stolen
03 Mitsubishi Lancer Evolution VIII GSR - Sold
05 Subaru WRX STi - Sold
06 BMW ///M3 - Sold
08 Mitsubishi Lancer Evolution X GSR - Current
Offline
Old Aug 30, 2009, 05:56 PM   #78
EvoM Super Moderator
Personal Sales Rating: (20)
2008 Mitsubishi Lancer Evolution
Noize's Avatar
Drives: PB Evo X
Third repost. Check the stick in Evo X ETD
__________________
Powered by Ultimate Racing and Ecuflash
Site rules and guidelines can be found by clicking here
Autocritic blogspot
Offline
Old Aug 31, 2009, 08:55 AM   #79
therocket's Avatar
Drives: 08 WW EVO X GSR
Thank you for the info guys, I will check my X tomorrow!
I have only 4k miles but just 2 days ago I've seen the IDC up to 100%, so I was already thinking that there was something strange.
I will try to measure directly the voltage (9V cruising, 12-14V boosting), but in any case can you explain me what test I can do switching the relay?
Someone suggests to switch the DRL relay and then check if the DRL work properly (if relay is bad, DRL will stay always on or off?); some other suggests to switch the high beam relay and check if high beam stay on (if relay is bad, they switch off after few seconds? And this is true also for HID lights?).
What do you suggest as best test?
Thanks!
(as always, sorry for my English )
Online
Old Aug 31, 2009, 12:32 PM   #80
Personal Sales Rating: (5)
raytrix's Avatar
Drives: Wicked White Evo X
http://www.zettlerauto.com/products/plugin-relays.asp
SSD (Solid State Device) version of the relays. Possible replacement over mechanical.
Offline
Old Sep 3, 2009, 03:24 PM   #81
Spunkysandoval's Avatar
Drives: 08 Evo X
Send a message via AIM to Spunkysandoval
Hey Naji,
I threw together a nice little HOW TO and posted it in the HOW TO section for the fuel pump test. feel free to chime in on it or refer people to it when you need them to confirm their relays are working
Here is a link
HOW TO : fuel pump relay 1 test
__________________
Fender Roller For Rent in So Cal
I do fenderwork, pm me with questions :D
Mods: Invidia Riceback single exhaust, tightened stock ricegate actuator, ricemasters clutch, hawk ceramic rice pads, hks drop in rice filter :P
Offline
Old Sep 3, 2009, 03:46 PM   #82
Personal Sales Rating: (2)
Chabada15's Avatar
Drives: 05 Evo VIII
hope u solved the problem...but if your just getting knock and its not lean then maybe the stock knock sensor could be loose, this was a common problem on the 8/9 after a few years, although the X in still wayy new it could be an issue to look at...sorry if im no help lol
__________________
Evo-NY #243
Quote:
Originally Posted by SHIFTT IX MR View Post
Owning an EVO is like having a super model for a girlfriend, you gotta give some, to get some. And when you try taking some, it brakes, *****es, and moans the whole way to the bank.
Offline
Old Sep 12, 2009, 03:44 PM   #83
Guru's Avatar
Drives: 08 EVO X WW GSR SSS Aero Navi
Mine went bad had to swap it out for the high beam relay yesterday. I thought I had a leak in the inlet pipe but turned out to be that. 22,000 miles with all stock fuel system. Crazy. At least it is easy to fix. Glad I have a wideband in the car.
__________________
Dan
Thinking of a Blouch Turbo? Read this first:
http://forums.evolutionm.net/service-parts-tuning-review/375268-stay-away-blouch-turbo.html
Offline
Old Sep 13, 2009, 01:04 PM   #84
808_EVO's Avatar
Drives: 2008 RR EVO X GSR
I'm at about 5k on the odo and been getting random detonation... Swapped my fuel pump relay with the headlight relay to see if it helps... And if I notice my headlights acting up (I have HIDs and couldn't do the high-beam test) then we'll see.
__________________
808_s2k --> 808_Evo
The current setup
Offline
Old Sep 15, 2009, 08:20 PM   #85
Drives: 2008 Evo X GSR
Connecting dots - new Relay Part Number?
Quote:
Originally Posted by Chris@AMS View Post
Recently I have seen an event happening which I felt would be worth mentioning to those of you that own an EVO X. I may have found an issue that would affect the fuel system of the car and make the car run very lean, and possibly cause engine damage. The issue is related to the stock fuel pump voltage switching relay. The Evolution 8, 9 and now the 10 all have a relay which switches the fuel pump from low voltage to high voltage when certain conditions are met (full throttle, or boosted conditions). ...
This issue seems to be prevalent on cars with higher mileage on them.
OK - so bear with me. I don't know what I'm talking about. Just trying to connect the dots and take preventative measures to protect my GSR...
There's a thread in the general forum talking about a new replacement Relay Part Number that is used for the Fuel Relay.
Can someone tell me if this relay could prevent the problem that Chris@AMS describes? Or are they completely unrelated issues?
__________________
Current: '08 Mitsu GSR, '06 Honda Pilot
Prior: '05 Infiniti G35 Coupe, '05 Subaru WRX, '04 Lexus RX330, '99 BMW 328i, '97 Toyota 4-runner, '95 Acura Integra, '93 Toyota MR2 Turbo, '91 Toyota MR2 Non-Turbo, '91 Honda Civic
Offline
Tags
afr, cal, evo, fender, fuel, grand, lean, normal, prix, pump, relay, roller, services, stock, tune
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
