Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 13, 2009, 06:36 PM   #1
Personal Sales Rating: (0)
evolvingevo's Avatar
Drives: evo X mr
stock boost problems
Ok so I took off my AEM EBC today to return to stock boost because I was getting tired of throwing overboost codes everyother time I stomped on the gas! I would throw two sometimes three codes...p0135 or p0137 (can't remember) p1345 and p1870.
I hook all the vacuum lines up back the way they came and went on a test run only to find out that I am now only pushing 13psi!!! WTF!!
the only thing different that I did from stock is I did not put the boost pill back in the line, I didn't think that it was really needed! I reset my ECU and went on another run and still only 12-13psi!
My mods are as follows...
K&N cone filter
HKS exhaust and center pipe
ETS DP with o2 dump and ETS TP
If anyone has any suggesstions for me that would be great because this car is incredibly slow on 13psi of boost.
thanks guys!!!
__________________
HKS legamax exhaust, and center pipe
ETS DP with o2 dump and test pipe
K&N cone filter with custom heat shield
AEM wideband, tru-boost, and voltmeter
clear bra from Formula One
20% tint all around
50% tint front winshield
Offline
Old Jul 13, 2009, 07:29 PM   #2
Personal Sales Rating: (1)
Drives: 05 EVO
Uh..... the boost pill is there for a reason. Changing the diameter by hundreths of an inch significantly changes how the system operates.
__________________
05 Evo
05 CBR 600RR
96 SE-R, sold... (t25, cams, brakes, suspension, 260whp/260wtq, 111mph trap, lots of road course time, blah blah)
Offline
Old Jul 13, 2009, 08:05 PM   #3
SiC
2008 Mitsubishi Lancer Evolution
SiC's Avatar
Drives: Lancer Evo X GSR
There are 3 pills on the EvoX boost control system. The main one that is in the vacuum line from the turbo outlet is there to restrict the amount of pressure that reaches the actuator. Removing this one will decrease your boost since more pressure will reach the actuator causing it to open.
The other 2 are before the boost control solenoids. Removing these will actually increase the boost since more pressure will be allowed to be relieved by the solenoids. The more pressure that is relieved, means the less pressure that will make it to the actuator which will increase the boost.
Offline
Old Jul 13, 2009, 09:21 PM   #4
Drives: evo X mr
where do the three pills in the vac lines go?
edit: I only remember taking one out.
__________________
20% tint all around
Offline
Old Jul 13, 2009, 09:55 PM   #5
SiC
SiC's Avatar
Read my post again
Offline
Old Jul 13, 2009, 10:35 PM   #6
Drives: evo X mr
so if I install the pill between the turbo outlet to the actuator and leave the other two out and just keep an eye on the boost you think that I will be fine?
__________________
20% tint all around
Offline
Old Jul 14, 2009, 12:29 AM   #7
SiC
SiC's Avatar
Put the main pill back in (from the turbo outlet) and leave the others (before the solenoids) in place. If you remove the pills in front of the solenoids, your boost will jump too high. If you want to remove those, you'll need to lower the WGDCs.
Offline
Old Jul 14, 2009, 07:02 AM   #8
Drives: evo X mr
OK so I put the main pill back in (line off hot pipe) and left the others out (don't remember what I did with them, must have thrown them out) and now I can get up to about 18 psi but in the higher gears like 4th and 5th where there is more load! second and third only put out about 16-17psi. Also there are no boost spikes what-so-ever. It's not like I stomp it to the floor and the boost spikes at like 25-26 then tapers down to 20-21...not at all (this is how it was with the EBC), now the boost kinda slowly rises up and when it hits between 16-18psi it holds it there, which is good but still a little low! What is the next step I should take now?
__________________
20% tint all around
Offline
Old Jul 14, 2009, 06:53 PM   #9
Drives: evo X mr
bumpin it up for some boost!!!
__________________
20% tint all around
Offline
Tags
boost, diameter, ebc, evo, evolution, exhaust, hks, increase, legamax, pill, pipe, problem, taper, test, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
