Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 9, 2009, 02:00 PM   #1
Personal Sales Rating: (2)
tsitalon1's Avatar
Drives: 2008 Evo X GSR
Attn tranny rebuild specialist ***UPDATED***
Hey guys,
This is an open invitation to any tranny rebuild shop that believes they can resolve my notchy shifting once and for all.
I will do everything in my power to document every stage of my quest. While I wouldn't consider the shifting quality to be junk, it definately doesn't shift smoothly at all especially as a DD. I have aprox 24k miles and am sick of tired of waiting for it to smooth out. Tried Amsoil and it helped a bit. I would normally contact the vendors directly as I have done with previous vehicles and ask for quotes...But this time I want it to be as public as possible.
Below are my symptoms/expectations:
2008 Evolution X GSR Transmission
Vehicle Build Date = NOV 2007
Miles on tranny = ~24,000
Current power level unknown - car is stock with Testpipe and EcuFlash self tune...guess 280-300whp (trapped 108 in 1/4 mile)
Issues:
Moderately to severely NOTCHY shifting during N-1, 1-2, and 2-3 shifts especially at LOWER rpms. Higher rpms (>5000) considerably smoother.
I notice that the “notchiness” varies from day to day, temperature to temperature. >90º shifts a little smoother.
Never grinds, but I do feel some blockage at times. **update** Feeling some slight grinding occassionally now.
My suspicions:
Factory clutch not disengaging properly..can feel car move when shifting from N-1 on flat ground. (new southbend stg 3 clutch (feramic) with minimal marcel and sprung hub awaiting install) as well as ams retaining ring and clutch line.
“Feels” like internal tranny lubrication not adequately getting to hub/sleeve/syncros
TRE stated:
Mitsu changed the hub/sleeve/syncro design after my build date. This could not be verified by Jnztuning via a CAPS search.
My expectations after rebuild:
1. Newest Mitsu hub/sleeve/syncro setup (if one exists)
2. Improved retaining pins on diff...see post: EVO X 5 Speed failures and solutions
3. Smooth shifting into/out of any gear at any rpm. (butter smooth would be great!!)
4. 20% stronger internals from shot peening internals (400awtq will be the max this tranny will see)
5. NO ENGRAVING or marking at all on tranny and please use sealant that resembles Mitsu sealant as I am attempting to retain the factory powertrain warranty.
6. Full support after rebuild to iron out any issues that may exist.
I do not need a full fledged race tranny that can support 800 hp...This tranny will NEVER see more than 400awtq in this car.
Let's find a fix guys!!
***UPDATE 9-3-2009***
Well Guys,
I have been reserving judgment until I had a chance to put some miles on the tranny and new clutch. Car has now been driven 350 miles with the new setup.
First let me say right off the bat that these steps did NOT resolve the notchiness. I am disappointed to say the least.
I spoke with John about the tranny at length and basically he stated that the tranny was in immaculate condition when he received it, and not much else beside the REM process could really be done. My main concern was if the clutch was really dragging that there would be accelerated/abnormal wear on the syncro's. This was not the case, John found nothing "wrong" with the syncro's sliders or gear facings. I was told that the REM process was accomplished on the sliders and gears, and I can tell you that it does overall shift smoother, however the 2nd-3rd shift still produces a good amount of notchiness. I suspect that a tranny shop cannot fully overcome engineering issues.
For those concerned with fluids, I did switch from Amsoil to Redline Mt-90 on John's suggestion and it seems to shift better overall, but that could be the REM or fluids or both working. Cold fluid still produces much more notchiness. I am contemplating draining a quart of the MT-90 and putting in one quart of the MTL in to "thin" it out a bit.
I was also told that the center diff was substantially strengthened, so I believe my efforts were not in vain, as I *should* be immune now from the infamous diff retaining pin failures.
For those following the clutch portion of this, I am somewhat disappointed in my Southbend clutch at the moment. I am reserving full judgment until I reach the break-in point since I only have 350 of the required 750 miles. I will not go into detail on this yet. I am working through email with SouthBend trying to figure out our course of action.
The clutch operates fine, and I can drive the car normally. My issues are more related to pedal engagement height, pressure and transition. I do not have any weird clutch noises and it is not slipping though I have not really pushed it since I am still in the break-in period. I also do NOT believe the new clutch is playing a role in the notchiness, I have verified that the clutch is not dragging at all.
Can anyone answer this question for me:
In the old push style clutches, as clutch disc wore down, the engagement point of the pedal would move up to the top.
Am I right in assuming that on pull style clutches the opposite is true?
Since the PP is concave before installation and the springs of the pressure plate move outward as you bolt the clutch to the flywheel, I would assume that the engagement point moves closer to the floor as the clutch wears on a pull style clutch.
My engagement point of my southbend starts at half pedal but finally grabs about 1 inch from the very top, as bad as, or worse than stock. This makes it difficult to feather it, as your working against the PP pressure and the pedal assistance spring which is not linear toward the top of the throw.
__________________
CITI-BANK HAS RAISED THE APR FOR ALL TO 14.99 - PLEASE CHECK YOUR ACCOUNT
Alex
Offline
Old Jul 9, 2009, 02:06 PM   #2
Personal Sales Rating: (44)
I'd put a good clutch in the car like the Exedy Twin Disc.
Offline
Old Jul 9, 2009, 02:12 PM   #3
tsitalon1's Avatar
Quote:
Dave, that was my initial thought, however, several people have reported simply changing the clutch didn't help resolve the notchiness at all. Could you share any experience you have that points to the clutch more than the tranny itself?
Another reason I opted not to go with the twin is to retain the factory powertrain warranty. I've had good luck with my X in that Mitsu has stepped up several times to resolve my issues. So I would like the clutch to be invisible to them in the event something stupid happens that *should* be covered.
__________________
Alex
Offline
Old Jul 9, 2009, 02:43 PM   #4
Personal Sales Rating: (0)
This is a sure sign something is not right. I think a clutch and a real REM treatment ( not a micropolish that looks like rem) would help.
The trans suffers from center diff issues as well that need taken care of while in there.
Offline
Old Jul 9, 2009, 04:05 PM   #5
tsitalon1's Avatar
Can you pm me with the costs involved?
__________________
Alex
Offline
Old Jul 10, 2009, 06:42 AM   #6
tsitalon1's Avatar
Dave / John,
I am ready do do something about this issue. I am sick of it. I am leery of simply replacing the clutch only to find that I may be in the same position after the clutch swap. So I thought it may be best to have the tranny looked at as well, since it'll be down anyway.
Would it be your advice for me to simply replace the clutch first and see where that leads me, versus having the tranny inspected as well? Won't I still have the possibility of the diff retaining pin issue anyway?
Car is used 99% as a DD. Probably will never track, might drag every now and then.
I am open for suggestion and ready to move on this in any direction you guys think is best.
__________________
Alex
Offline
Old Jul 10, 2009, 07:30 AM   #7
Personal Sales Rating: (24)
itsme4g63's Avatar
Drives: hallucogenically law breakingly mad & absurd
the dealership does not want to resolve this I presume?
__________________
http://www.youtube.com/user/Nodsldmc007
[ ] Big Turbo
[ ] Built Motor
[ ] Standalone
[ ] Built Trans
[ ] Built Transfercase
[ ] E-85/E-98
[X] Reliability
Offline
Old Jul 10, 2009, 07:55 AM   #8
tsitalon1's Avatar
Quote:
"Your tranny is operating under normal tolerances" was both the dealer and MMNA response.
My wanting to maintain the PT warranty is mostly tired to stuff like motor/rear diff/ and transfer case.. they rest I can fix with my own $.... I don't have a dealer near me anyway..
__________________
Alex
Offline
Old Jul 10, 2009, 08:08 AM   #9
itsme4g63's Avatar
That sux! I got one near me, but they are a pita, so I drive way out of my way to get warantee work done.
__________________
[ ] Big Turbo
[ ] Built Motor
[ ] Standalone
[ ] Built Trans
[ ] E-85/E-98
[X] Reliability
Offline
Old Jul 11, 2009, 11:32 AM   #10
tsitalon1's Avatar
Bump
__________________
Alex
Offline
Old Jul 12, 2009, 10:30 AM   #11
ak47m203's Avatar
Drives: evo xmr, civic, pathfinder, hopefully ZO6 with-in 5years
some says get a GSR it's better tranny than MR.
__________________
http://www.cardomain.com/ride/3308500
Are you in the North Texas area? http://forums.evolutionm.net/north-t...club-ntec-303/
Evo X MR Perrin Drop In. Nesie 1 pc UICP. Modified Stock exhaust. Resonator delete.
Stock dyno:
http://www.motionbox.com/videos/7a9ad9b71614e3c3
f5
Will do:AP pro tune and boost pill(later this year), test pipe.
Tune dyno: ?
Offline
Old Jul 12, 2009, 03:33 PM   #12
Quote:
he does own a gsr
Offline
Old Jul 16, 2009, 07:33 AM   #13
tsitalon1's Avatar
Quick update for those interested.
I've been in communication with John Shepherd and he has agreed to tackle the issue and provide support in the event the issue exists afterwards.
I will begin pulling the tranny ~ 7/24/09, wish me luck
__________________
Alex
Offline
Old Jul 16, 2009, 08:12 AM   #14
Personal Sales Rating: (3)
Drives: WW EvoX GSR
interesting... i have a 11/2008 X and I have some tranny problems.
miss-shifts and clunky changes are the main ones..
also SOMETIMES when i am stopped with it in 1st and my foot on the clutch after a while something happens and i can feel the gear level move a bit (i leave my hand resting on the gear knob)
not sure what that's all about, but I too feel like the clutch isn't properly dis-engaged..
i was going to pull the restricter out and then maybe adjust the clutch pedal to see if i can make the dis-engagement high a bit lower..
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Old Jul 16, 2009, 08:55 AM   #15
tsitalon1's Avatar
No adjustment on the Evo X for this I know my clutch is dragging, I am just not sure what else is wrong, so I'll let Shep look at it.. I will use this thread as my documented journey
__________________
Alex
Offline
Tags
5spd, 72409, case, citibank, evo, gsr, john, oregon, portland, rebuild, rebuilt, shepherd, stock, thoughts, tranny, transfer, transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
