Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 14, 2009, 08:34 AM   #61
Personal Sales Rating: (3)
Boostd4's Avatar
Drives: 06 AS GSR SE
Quote:
Originally Posted by blk-majik View Post
Did you try replacing the MAF yet? You said you found another local X who would let you borrow some parts to test... seems worth the hassle if you didn't try it yet. How is your EGT reading (err...nvm unless you installed an EGT sensor)? I was thinking LTFTs as well... might be worth double checking, especially if its outside +- 5%
Well, the AFRs are solid so we really didn't think there was any issue with the MAF. However, at this point I'm trying everything. I did find a couple of people locally willing to loan me a MAF sensor, so that's next when I get a chance to get back to the shop.
__________________
2006 AS Evo 9 GSR SE
www.gstmotorsports.com
Past -
2008 WW Evo X GSR SSS aka "The Problem Child"
2004 AS Evo 8 GSR Vishnu Stage 1+
Offline
Old Aug 14, 2009, 09:37 AM   #62
Personal Sales Rating: (0)
Drives: 2010 WW Evolution X
^^ try looking for someone to lend you the stock coils to...i mean it's worth a try...
Offline
Old Aug 14, 2009, 11:17 AM   #63
Personal Sales Rating: (1)
Drives: 05 EVO
In no way did your cam timing get messed up right?
__________________
05 Evo
05 CBR 600RR
96 SE-R, sold... (t25, cams, brakes, suspension, 260whp/260wtq, 111mph trap, lots of road course time, blah blah)
Offline
Old Aug 14, 2009, 11:52 AM   #64
Boostd4's Avatar
Quote:
Nope, haven't cracked open any part of the stock longblock.
__________________
Past -
Offline
Old Aug 14, 2009, 12:04 PM   #65
Personal Sales Rating: (6)
Hiboost's Avatar
Drives: 2008 Evolution X & 1996 Eclipse GSX
Quote:
Originally Posted by Noize View Post
Its probably fueled that way for a margin of safety against the unexplainable knock.
His tuner is Bryan at GST (formerly Razorlab), who is easily one of the best ECUflash tuners in the Evo community. He knows exactly what he's doing, there is not an issue with the shop's equipment either, I'm sure of it.
It is simply an issue with this specific car that needs to be discovered and sorted out.
I agree that Bryan at GST has likely looked at all the angles from the tune itself, but I had to cover all the bases.
The theory of the car being in some sort of limp mode seems very plausible up until there is usually a SES light activated when that happens. It's quite amazing how much the ECU can restrict you though, when I triggered an airflow too low code the other day after making too many changes to my tables and I was flooring it and could barely get any boost. Mind you this is with a MBC so it managed to restrict boost through throttle reduction and/or timing retard. I'm almost curious enough to trigger it on purpose so I can see exactly how it's doing that so effectively.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Old Aug 14, 2009, 12:34 PM   #66
dkstas's Avatar
Drives: 08 Octane Blue EVO X
^Is that the P1235 code, if so I triggered it on some of my runs down the 1/4 and my traps dropped from 116 -117 to about 113. So the reduction of timing is quite possible.
Offline
Old Aug 14, 2009, 02:39 PM   #67
Boostd4's Avatar
Yes...Bryan cringes when he sees my car roll into the parking lot.
I agree about the SES light not coming on...but it may be one of those passive safeguards that doesn't necessarily throw a code...it just does what it's supposed to do...limit power.
__________________
Past -
Offline
Old Aug 17, 2009, 12:59 PM   #68
Boostd4's Avatar
Still no luck...hoping to pop into the shop this week to try the next battery of tests.
__________________
Past -
Offline
Old Aug 19, 2009, 12:09 PM   #69
Boostd4's Avatar
So over the past couple of days I've gotten a couple of PMs from people who have found that they are having this knocking issue...interesting.
Trying out the race gas next week, no time to make it to GST this week.
__________________
Past -
Offline
Old Aug 19, 2009, 12:31 PM   #70
BigT's Avatar
Drives: 2 ****su's
Did you swap the MAF yet?
Offline
Old Aug 19, 2009, 12:35 PM   #71
Boostd4's Avatar
Quote:
Doing that the same day as the race gas test...as well as the coils.
__________________
Past -
Offline
Old Aug 27, 2009, 12:02 PM   #72
Boostd4's Avatar
Just keeping the thread alive...100 octane this weekend.
__________________
Past -
Offline
Old Aug 27, 2009, 12:46 PM   #73
t12ung's Avatar
Drives: Apex Silver Evo X
Mike I wish you the best of luck this weekend. If you need to swap out parts my car is finally running again so I can swing by GST as a parts donor if needed.
Offline
Old Aug 27, 2009, 02:00 PM   #74
Boostd4's Avatar
Quote:
Thanks man, I'll definitely let you know.
At this point, we're really just trying to isolate what the problem is. After 3 months we still don't know what to fix.
__________________
Past -
Offline
Old Aug 27, 2009, 02:45 PM   #75
Hiboost's Avatar
Maybe just switch to E85 and add a meth injection setup to mask the stupid issue until it fails enough to finally expose what the real problem is.
Hopefully the 100 octane test will let you verify what it isn't and help you focus your efforts on what the possible reasons really are. You may want to try using the airflow and torque disable mods to just take those flow limit tables out of the picture all together.
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Tags
engine, evo, evox, gsr, hesitation, intermittent, knock, knocking, leaking, limited, loss, low, power, rpm, trouble
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
