Jul 9, 2009, 01:22 PM
Personal Sales Rating: ( 9)
Drives: 08.5 PB X
Try swapping out the MAF for a new one also....
__________________
DGMotors NY DD Tune 23psi 282whp-295wtq 90% humidity
Mods:
Nisei UICP
Eibach Pro Kit
Buschur Bullet Catback
Buschur Intake
Seibon CF Trunk
Rexspeed Trunk Lip
Rota Torques - 18x9.5 20et
Offline
Jul 9, 2009, 01:23 PM
Personal Sales Rating: ( 3)
Drives: 06 AS GSR SE
Quote:
Definitely...going to do this when I swap the coil packs. My only thought on this is that if the MAF were failing or bad the AFRs would reflect this.
But at this point anything is possible.
__________________
2006 AS Evo 9 GSR SE
www.gstmotorsports.com
Past -
2008 WW Evo X GSR SSS aka "The Problem Child"
2004 AS Evo 8 GSR Vishnu Stage 1+
Offline
Jul 9, 2009, 02:24 PM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
The knock is not the main factor for the low power output. I tuned a Evo 10 the other day with a 3076 and it made "proper" power, meaning, it actually made more power than the stock turbo.  Timing was very close to Boostd4's timing before the knock up top.
Offline
Jul 10, 2009, 09:51 AM
I found a local who is willing to let me swap out a few parts for some tests.
Another thought that came to mind was maybe a bad cam angle sensor...or something similar?
__________________
Past -
Offline
Jul 13, 2009, 10:19 AM
Bump for advice...
__________________
Past -
Offline
Jul 13, 2009, 11:49 AM
Personal Sales Rating: ( 1)
Drives: 05 EVO
So compression and leakdown came back good, so that's great news. Fueling (A/F), and timing seem to be okay...
So that's making me think it might be ignition related?
__________________
05 Evo
05 CBR 600RR
96 SE-R, sold... (t25, cams, brakes, suspension, 260whp/260wtq, 111mph trap, lots of road course time, blah blah)
Offline
Jul 13, 2009, 11:56 AM
That's what I'm thinking as well...or possibly a bad sensor somewhere. I'll be popping in some known working coil packs this week at some point.
Does it make sense that possibly the cam angle sensor (or maybe another similar sensor) may be off? And if it were...wouldn't the car throw a CEL?
__________________
Past -
Offline
Jul 13, 2009, 11:59 AM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
I would check the turbine blades by removing the vband in between the hotside and compressor side.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Jul 13, 2009, 12:19 PM
Personal Sales Rating: ( 0)
Good Luck figuring this out guys, and thanks for posting so much detail here for us to learn from.
Offline
Jul 13, 2009, 03:07 PM
Quote:
Definitely not the turbo...this is the 2nd turbo that this problem existed with...
__________________
Past -
Offline
Jul 13, 2009, 03:16 PM
Drives: 2006 Mitsubishi Evolution IX MR
If the knock is not audible then try swapping out the knock sensor. your sensor might be defective.
__________________
-buschur tbe with test pipe
-buschur SS O2 housing
-buschur ported exhaust manifold
-nisei competion fmic plus piping kit
-nisei mini battery
-Walbro 255 Fuel Pump
-FIC Bluemax
-GM 3-Port
-aem air filter
-self tuned with EcuFlash & Zeitronix
Offline
Jul 13, 2009, 05:40 PM
2008 Mitsubishi Lancer Evolution
Drives: Lancer Evo X GSR
Okay, I think I may know the problem since I ran into similar problems too. Does your Greddy Catback have a plate on it that says JASMA? JASMA stands for Japan Auto Sports Muffler Association and they have tough standards to clear sound and emission tests in Japan.
A few years ago, the standards weren't as tough so they weren't too bad. The exhaust standards in Japan has gotten tougher and now a days these exhausts are pure 100% Sh*t, sometimes they are worse than stock and are only for looks. I have run into a few of these exhausts including the one I used to have (Kakimoto Hyper N1+) and they have restrictors in them that are only around 50mm (2 inches). When running these exhausts with a stock turbo or the low 300 whp range, you probably wont have any problems. Once you swap turbos, you'll see a drop in your power even if your boost is higher than before. Basically what is happening is back pressure is building up and creating a huge loss. You'll probably see drops in whp from mid RPM and start seeing large counts of knock starting from the 5500-6000 RPM zone.
Please check your exhaust and swap it with another if you can and throw it back on the dyno. If it is a JASMA exhaust, you'll probably see a huge difference if you get a straight 3 inch on there instead.
Offline
Jul 13, 2009, 05:49 PM
I just did a little research on your exhaust, although it may not have the JASMA plate it may still be the same as the JASMA exhaust. If it is, the resonator on the mid pipe will proabaly have a 2 inch internal diameter. Also, can you look thru your tail pipe and measure the inner diameter of the muffler itself? I see you have 80mm piping but I'm afraid the inner diameter of your muffler maybe much smaller.
Offline
Jul 13, 2009, 11:08 PM
Drives: 08 Octane Blue EVO X
^I really hope this is not the case, I have the same exhaust. Sic, what exhaust are you currently running?
Online
Jul 14, 2009, 12:24 AM
Quote:
I actually complained to Kakimoto about this and they agreed to everything I told them. They actually custom built me a full 80mm exhaust with no restrictors but I had to sign a waiver saying I wont use it on the streets
Offline
Tags
engine, evo, evox, gsr, hesitation, intermittent, knock, knocking, leaking, limited, loss, low, power, rpm, trouble  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
