Mar 25, 2009, 02:04 PM
Personal Sales Rating: ( 0)
Drives: 08 WW Evo X
Heat wrap turbo? Good? Bad?
Hey is it a good idea to heat wrap my turbo? I know it makes it spool faster, but how much will it shorten the life of my turbo?
Offline
Mar 25, 2009, 03:22 PM
Personal Sales Rating: ( 6)
Drives: WW EVO X
Bad.
Doesn't spool faster.
__________________
WW EVO X #32
ECUTek Tune (318whp/359 Torque @ 26psi)
Tuned by Cam @ Lightspeed Innovations
First EVO X in Canada to Break 300whp
Offline
Mar 25, 2009, 07:34 PM
Drives: SLK350, Cayenne, Rav4, EvoX
bad for its life i would think
__________________
- It's wicked white
HKS Racing Suction Reloaded, HKS EVC EvoX edition, ECUTEK
Offline
Mar 25, 2009, 08:52 PM
Drives: evo x and 2k8 M5
not worth it for 10whp...
Offline
Mar 25, 2009, 08:54 PM
Drives: 2005 WW VIII GSR, 2003 AS VIII GSR
are we talking intake side or hot side?
Offline
Mar 26, 2009, 04:10 PM
Drives: 2008 GGP Evolution X GSR
Turbine side... it does allow them to spool faster, the exhaust gast is hotter and therefore thinner and can exit out quicker. You don't have to wrap it, you can get heat coating for it from SwainTech or HPC. Not to mention a coating helps for underhood temps. win-win...
Offline
Mar 26, 2009, 04:56 PM
Personal Sales Rating: ( 1)
2008 Mitsubishi Lancer Evolution
Drives: Lancer Evo X GSR
As most of you know, the exhaust temp on the X is much higher than the previous models. This is partially due to bad heat dissipation from the turbo being in the back side of the engine bay. I'm sure Mitsubishi became aware of this so they made the hood vent and heat shields with a vent that is suppose to direct air flow to the turbo.
By wrapping the turbo, heat dissipation will be worse and it'll probably lead to turbo failure. So far, I know 2 stock turbos in Japan that failed from the exhaust temps being too high (both had stock exhausts). The shop was saying it was due to high exhaust temp caused by high back pressure from the stock exhaust system. By wrapping the turbo, you'll also be increasing your exhaust temp = increasing your chances of turbo failure.
Offline
Mar 26, 2009, 05:05 PM
Personal Sales Rating: ( 4)
Drives: 2006 Mitsubishi Evolution SE, 1970 Porsche 911T
There is also the issue that by wrapping the header, the actual metal will be heated to a greater degree and things like water can lead to cracking because of larger temperature swings.
__________________
371 awhp 340 awtq @ 24.5psi on 93oct (45F)- AMS Tuned
- ETS 4" IC - ETS LICP - ETS UICP - ETS Intake - Perrin Filter -
- BR 3" TBE w/ test pipe - Buschur o2 Housing -
- AMS MBC -
- ETS Battery - Walbro 255 - S-M DC3 - ETS Radiator Hose -
- Exedy Twin HD -
- EnduraTech Coilovers (7k/9k)-
- AMS Brake Ducts - Hawk HT10/ PF Metallic Z - Technafit SS lines -
- Enkei RPF1 - Nitto NT05 -
- APR Splitter -
- Motul RBF600 - AMSoil -
- Stri Gauge -
Offline
Mar 26, 2009, 06:04 PM
just wrap the DP and call it a day.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
