Feb 9, 2009, 01:37 PM
Personal Sales Rating: ( 0)
Drives: X
Blouch Dominator II vs FP Red - Pros/Cons
Ready to pull the trigger on my next round of upgrades, but need some more info regarding the path for the turbo. I have read countless posts about both the Blouch Dom II and the FP Red and all seem to get very positive reviews. What are the real differences between the two in real world terms.
Is one better for pump gas?
Is one better at spooling up?
Which is closest to stock spool?
My personal objective is to have a fast reliable pump gas X. I prefer stock like manners but with power upon desire. I have no desires to track the car either drag or on a road course. Driveability is very important for me. The turbo install would include fuel injectors and a re-tune. Any help is greatly appreciated. Those with personal experience with either on the X please post your comparisons in regards to stock driveability.
Offline
Feb 9, 2009, 01:45 PM
Personal Sales Rating: ( 24)
Drives: 300+ yards
I believe I just read this morning that CBRD has a new turbo, stock style, that he is currently working on, searching....
Offline
Feb 9, 2009, 02:04 PM
Personal Sales Rating: ( 1)
Drives: 05 EVO
The better question would be, what are the mechanical differences? I think the Blouch uses Garrett compressor and turbine wheels from the GT3076 (76mm compressor, 60mm turbine). I don't know what size wheels are in the Red. I would add the third option, one of the two Garrett options (3071 or 3076).
__________________
05 Evo
05 CBR 600RR
96 SE-R, sold... (t25, cams, brakes, suspension, 260whp/260wtq, 111mph trap, lots of road course time, blah blah)
Offline
Feb 10, 2009, 04:09 PM
Drives: X
Anyone have some information to share?
Offline
Feb 10, 2009, 04:12 PM
Personal Sales Rating: ( 15)
Drives: 97GSX<GGIXMR
i know someone that has one but i haven't been cleared to give info out...haha...sorry guys...
__________________
12.05 @ 116.5mph....93 oct., Stock turbo, Stock motor (Stock cams), Stock Intake Manifold & TB, crappy 6 spd tranny, a bunch of bolt-ons, SPARKTECH nonCDi COP, 25 psi, Tuned by Kasey @ MAP (2009)
For the Fastest/Quickest Stock Appearing Turbo Times of 2009 Click Below
For all your Ignition NEEDS & WANTS, CLICK BELOW!!
Offline
Feb 11, 2009, 12:47 PM
Personal Sales Rating: ( 2)
Drives: 08 EVO X WW GSR SSS Aero Navi
Both seem to spool up very similarly but the Red outflows the Blouch turbos by a large margin. Expect full boost around 3800ish RPM give or take. Injectors required with eitehr one. It's a no brainer to go with the Red considering the pricing is pretty close. I'd never deal with Blouch ever again, but that is another story. . . .
Offline
Feb 11, 2009, 03:34 PM
Quote:
well in light of your obvious bias opinion do you have any factual evidance I.E. fow rates and boost charts for both turbos with similar supporting mods (for boost charts).
Im not saying I dont belive you. just looking for proof rather than a bias opinion. Which is likely what the OP is looking for also.
Online
Feb 11, 2009, 03:36 PM
Blouch 2 is 52 lbs/min. FP Red is 60 lbs per min pproximately.
Offline
Feb 12, 2009, 03:57 PM
Drives: X
So anyone else with any info regarding the spool up performance between the two? If spool up is the same, the obvious choice would be the FP Red. Its less expensive and has more power potential. The other consideration is support from the vendor. Am I missing something obvious? Why is there such a difference in price between the two? They both use a stock housing but with different wheels?
If the FP Red and Blouch spool up at 3800, where does stock spool at?
Offline
Feb 12, 2009, 05:28 PM
So you're saying that the FP Red flows more than the larger framed FP HTA GT3076R, which has the same internal upgrades as the FP Red and is rated at about 57 pounds per minute?
The FP Red flows about the same as the Blouch Dom II, Mr. Guru. You're one serious BS'er.
FP Red:
http://store.forcedperformance.net/m...Code=NTEVOXRed
HTA GT3076R:
http://store.forcedperformance.net/m...e=Lancer-Turbo
Offline
Feb 12, 2009, 06:20 PM
Personal Sales Rating: ( 12)
Drives: 03 evo VIII, 87 Grand National
Deleted.
Offline
Feb 12, 2009, 07:43 PM
Quote:
Originally Posted by Dennis F
Vincent, have you read any of the posts from FP Red guys who have trapped 140+ mph?
That is 60+ pds per/min territory.
It looks like the Blouch 2 is just a tad bigger then a Green in terms of airflow.
If that's true, that would imply that the FP HTA GT3076R will produce over 650whp? Wow. That would be a turbo that spools faster than a standard GT3076R that produces more power than a standard GT35R. That's mind blowing.....Lies.
Offline
Feb 12, 2009, 08:52 PM
A Green is 49 ln.min correct? Or is it more? A Red is quite a bit larger than a Green. I believe the compressor wheel is a 60-1 or equivalent.
Offline
Feb 12, 2009, 08:56 PM
Deleted.
Offline
Feb 12, 2009, 11:14 PM
Personal Sales Rating: ( 25)
2008 Mitsubishi Lancer Evolution
Drives: Evo X
Here is a graph of an FP Red on my car, the tune is very conservative as I was headed to California to run it on track for the first time and needed it to be rock solid... A/F ratio's are in high 10's.
Mods:
FP Red
3" TBE
R/C 780cc's
AMS Intake
AMS Intercooler
AMS Intercooler pipe
110oct tune
FP Red vs. Stock Evo X:
Online
Tags
10, 3076, blouch, comparison, dominator, evo, evolution x, flow, fp, fp red, green, iix, rate, red, turbo, vs  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
