Feb 5, 2009, 10:36 AM
Personal Sales Rating: ( 6)
Drives: 05 Evo8 SSL
Fantastic!
Online
Feb 5, 2009, 01:11 PM
Silver Sponsor
Personal Sales Rating: ( 1)
2008 Mitsubishi Lancer Evolution
Drives: 08 GG Evo X
I have a Cobb intake so someof that may be different for others but it will get you close !
Offline
Feb 5, 2009, 01:35 PM
NTEC Club Forum Leader
Personal Sales Rating: ( 4)
Drives: RR EvoX
5.904*7000/1200 = 34% IDC? That's hella low. or am I off in what you're showing us?
__________________
Are you in the North Texas area? Check out NTEC!
mmmm corn
Online
Feb 5, 2009, 01:52 PM
Drives: Evo X
Any chance this can help with the "fuel dilution in oil problem"?
Offline
Feb 5, 2009, 02:10 PM
Silver Sponsor
Drives: 08 GG Evo X
Quote:
That is from the overly rich factory tune
Offline
Feb 5, 2009, 02:14 PM
Drives: 2006 Mitsubishi Evolution IX MR
Quote:
you are off. you are using the voltage which is wrong. should be the ipw at that rpm.
__________________
-buschur tbe with test pipe
-buschur SS O2 housing
-buschur ported exhaust manifold
-nisei competion fmic plus piping kit
-nisei mini battery
-Walbro 255 Fuel Pump
-FIC Bluemax
-GM 3-Port
-aem air filter
-self tuned with EcuFlash & Zeitronix
Offline
Drives: Evo X
Quote:
I certainly hope that that proves to be the case. But based on the other long thread on the fuel dilution issue, it seems that the few people with custom tunes that have had their oil analyzed are reporting the same high levels of fuel dilution...
I'm looking for anything that can help!
Offline
Feb 5, 2009, 02:53 PM
Drives: RR EvoX
Quote:
Right... the display he showed had V on the left and something in ms on the right. I figured it was ipw in ms... (figured wrong?)
__________________
mmmm corn
Online
Feb 5, 2009, 04:08 PM
Personal Sales Rating: ( 10)
Drives: On the mustang dyno
Nice. They look so much like the Subaru injectors.
I hope someone post a decent injector latency values. Its kinda time consuming when you have to reflash each setting to find out which one works best.
I will have to give these a try.
__________________
---Will have new numbers soon----
08 Evo X FPRED
03 Evo VIII FPgreen (street), GT42r(Drag), soon to try 6262 to both street and drag.
Times
12.0 2005
11.4 2008
10.8 2009
Offline
Feb 5, 2009, 04:44 PM
Drives: Lancer Evo X GSR
Quote:
Look at the post above by HB Speed, he posted the scaling & latency info.
Thanks HB Speed
Offline
Feb 5, 2009, 08:14 PM
Personal Sales Rating: ( 0)
Drives: 2008 EVO X
I can not wait to get some of these and a turbo.
Offline
Feb 5, 2009, 10:18 PM
latency
Quote:
Thanks HB Speed
He also mentioned he had a different intake. It will depend on how the latency was done. If it was done before the intake install then that would work.
I haven't seen a MAF scaling on the released version of Ecuflash, so I'm pretty sure the scaling for the different intake pipe was done through the latency and injector scaling. If ecuflash was used.
__________________
08 Evo X FPRED
Times
12.0 2005
11.4 2008
10.8 2009
Offline
Feb 5, 2009, 10:26 PM
I thought the Cobb intake doesn't change the MAF housing (just a cone filter) so MAF scaling shouldn't be needed. With the cone filter the AFR may be slightly leaner but most people adjust that thru the fuel maps and not with injector scaling. So even if he dialed these injectors in with the Cobb intake, there should be a minimal difference when using a stock intake.
Offline
Silver Sponsor
Drives: 08 GG Evo X
Actually I loaded the stock maps with my scaling and injector latency and it was almost identical to my pre inj mapping all you should have to do is adjust fuel table to get wot right
Or a slight adjustment of latency or scalar if your intake is waaAy ofF
Offline
Feb 5, 2009, 10:30 PM
I will try it when I get the injectors.
__________________
08 Evo X FPRED
Times
12.0 2005
11.4 2008
10.8 2009
Offline
Tags
800cc, cc, deatsch, dynamics, evo, factory, fuel, injecters, injector, injectors, modified, oem, orange, stock, work, works  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
