ExtremeTurboSystems.com – WA Custom Intercoolers, Intercooler Kits, Turbo Kits and Performance Parts. [Visit Site]
ETS Evolution X Turbo Kit and Replacement Manifold - Sneak Peak!
Old Jan 27, 2009, 04:32 PM
ETS Michael's Avatar
Here are couple sneak peak shots of our turbo kits and stock replacement manifold for the Evolution X - We will start testing in the next couple of weeks.
Stock Replacement Manifold - $899.00
Utilizing a Tubular Equal Length design, and retaining the Twin Scroll features of the stock turbocharger, the ETS Stock Replacement Manifold offers substantial improvements over the economical factory cast unit. The heart of the ETS stock replacement manifold is the Twin Merge Collectors at the turbine inlet. Unlike the factory unit, where exhaust gasses collide head on into each other, the twin ETS Merge Collectors align the exhaust flow in the direction of the turbine for fast spool and more top end power. Adding to the high flow, the equal length runners make sure all cylinders are tuned the same.
https://www.evolutionm.net/forums/ev...ock-motor.html - 614whp on the stock block!! Using our Single Scroll 35R Turbo Kit.
T3 Top Mount Turbo Kit - $4600.00 (35R)
For serious power upgrades on the Evo 10 look no further than an ETS Turbo Kit. Packed with features like high flowing Equal Length ETS Manifold, true Merge Collector, full 3” Downpipe, direct routed Wastegate Dump, low angle turbo outlet, high flow upper intercooler pipe, Tial 44mm Wastegate, and any T3/T4 or Garrett GT series turbos, these kits will get the job done, street or track. Along with great performance, Features such as an exhaust flex, T-Bolt Clamps, 4ply silicone, and braided oil lines, will help make sure that you do not have to use the ETS Life Time Warranty!
T3 Top Mount Twin Scroll Turbo Kit - $5290.00 (35R)
If fast spool is what you need, then an ETS Twin Turbo Kit is what you’re looking for. A twin scroll turbo kit will typically spool the same turbo 300-500rpm faster than a conventional manifold design. This is accomplished by pairing the correct cylinders in the firing order together, so that the pressure waves arrive at the turbo 180deg apart, making a stronger impact upon the turbine wheel and thus accelerating the turbo faster. Another benefit of opposite cylinder pairing is that when one exhaust valve is open, the exhaust valves of the other cylinder in the pair are closed. 180deg. apart, helping spool the turbo quicker with no loss of top end power.
T4 Top Mount Twin Scroll Turbo Kit - $5580.00 (40R)
Knowing how hard big T4 Turbos are to spool with a 2.0l engine, a twin scroll manifold is desirable for T4 based Turbos such as the GT40r, T04z, and the Gt35r-T4. The Large T4 exhaust sections of these turbos will make big power above 7000rpm, and the twin scroll pressure pulse manifold design helps spool these large turbos sooner than later. Utilizing dual wastegates, the exhaust pressure waves of cylinders 1&4 are kept separate of 2&3 so that they can impact the turbine wheels individually, 180deg. apart, helping spool the turbo quicker with no loss of top end power.
Turbo Kit Intake
Installed Pics
Finished Product
We are hoping to have the kit installed in the next two weeks with results posted. We will be offering a discounted price for the first 5 people. we are going to be offering a $1,000 discount for the 5 demo kits. This will give us customer feed back in case there is anything the market does not like. A good example is the blue silicone, we have a few customers that love the blue silicone, while the majority seems to like black.
We plan on shipping the first demo kits, 2 weeks after our dyno results are posted. This will give us time to drive the car around and make any changes we feel are necessary.
All the same options will be available
Manifold
- Stock
- Polished
- Ceramic Coated
Turbine Housing
- Stock
- Ceramic Coated
Downpipe
- Stock
- Polished
Wastegate
- 1x 44mm on single scroll
- 2x 38mm twin scroll (NEW! Slim V-Band 38mm TiAL)
Turbochargers (Ball Bearing and Journal Bearing)
- Precision
- Garrett
- HTA
- CBRD
ETS Michael is offline
Old Jan 27, 2009, 04:40 PM
Papi4baby's Avatar
Mucho fapping...
Papi4baby is offline
Casper.'s Avatar
pmed ya man, awaiting response
Casper. is offline
Old Jan 27, 2009, 04:43 PM
Disrupt's Avatar
I can't wait for the results!
Disrupt is offline
Old Jan 27, 2009, 04:51 PM
Talon_66's Avatar
****ing sick!
Talon_66 is offline
Old Jan 27, 2009, 05:21 PM
Violat0rX's Avatar
sick! if only this was announced about a month later...closer to tax return time...lol
Violat0rX is offline
Old Jan 27, 2009, 05:23 PM
arbo651's Avatar
Very nice
arbo651 is offline
Old Jan 27, 2009, 06:25 PM
dustin03's Avatar
Looks good Only the best. Sent you a pm
dustin03 is offline
Old Jan 27, 2009, 06:46 PM
DC_TypeR's Avatar
Don't mean to sound like an a$$, but I hope the down pipe and exhaust housing of the turbo gets coated, or a wrapped, or both.... cause if not, it looks like you can pretty much kiss your brake and AC lines good bye (from the heat off the two)
That looks too close for comfort. (although it just might be picture angles)
None the less, very nice product, and welds look great.
-Chris
DC_TypeR is offline
Old Jan 27, 2009, 07:10 PM
flyboytb's Avatar
stock replacement + dominator 2 or red, = FUN!
flyboytb is offline
Old Jan 28, 2009, 08:59 AM
boostin20's Avatar
Those are some incredible looking kits, i will be saving my pennies for that twin scroll 35R
boostin20 is offline
Old Jan 28, 2009, 09:16 AM
kelvar13's Avatar
kit looks amazing. +1 for wishing it was closer to tax return season. I need to hurry up and file.
kelvar13 is offline
Old Jan 28, 2009, 09:28 AM
Sabot's Avatar
Nice kits PM send.
Sabot is offline
Old Jan 28, 2009, 09:36 AM
Originally Posted by Papi4baby
Mucho fapping...
Sending a PM now!
We should have results posted in the next couple of weeks. We plan on shipping the first 5 demo kits 2 weeks after our testing. We would like to drive the car around and make sure there is no heat issues, the reason we went with a top mount over a standard mount turbo kit is to keep the heat away from the firewall, weather stripping, lines, etc. The manifold has the most of heat all, so putting that closer to the block is a big plus. If heat becomes an issue in our testing, we will build a heat shield for the downpipe, but there is a good inch between the lines and the downpipe.
Originally Posted by Talon_66
****ing sick!
This just gives you time to prepare, we are going to be offering a $1,000 discount for the 5 demo kits. This will give us customer feed back in case there is anything the market does not like. A good example is the blue silicone, we have a few customers that love the blue silicone, while the majority seems to like black.
Originally Posted by arbo651
Very nice
-Chris
Chris,
No problem! The downpipe in the picture was a mock up pipe and might look a little close, but it's definitely the angle the picture was taken. There is around a 1.0" gap between the downpipe and the line. We plan on running this kit for a couple weeks after testing to make sure there is no heat issues. If there is a problem, we will build a heat shield.
You know it!
Thanks Guys!
Old Jan 28, 2009, 10:04 AM
Boltz.'s Avatar
Looks awesome. But you guys really need to ditch the blue couplers.
Boltz. is offline
Quick Reply: ETS Evolution X Turbo Kit and Replacement Manifold - Sneak Peak!
