Jul 22, 2009, 08:07 PM
#31
Personal Sales Rating: ( 2)
Drives: 2008 Evo X GSR
Quote:
Originally Posted by carrito.net
The first one, a larger pump was used and made the pedal a little stiffer than expected (althoug it still works flawlessly), but if an smaller diameter pump is used the pedal fell would be even better.
Plus:
- The pedal height is adjustable
- The pump is 100% rebuildable (if it ever fails, ha ha ha)
- Muchhhhh stronger than any other option
How much of a custom build is this? Does the tilton simply bolt to the base plate? It looks oem
__________________
CITI-BANK HAS RAISED THE APR FOR ALL TO 14.99 - PLEASE CHECK YOUR ACCOUNT
Alex
Offline
Jul 22, 2009, 10:07 PM
#32
Personal Sales Rating: ( 6)
Drives: Evo X
The best solution IMHO... But I am a little biased, ha ha ha
Plus:
sorry for spilling the beans on that mod
but hey we wants permanent... ask and thou shall receive eh?
__________________
I look at it this way For centuries now man has done everything he can to destroy defile and interfere with nature poisoning the atmosphere over-fishing polluting the rivers and lakes, destroying wetlands and aquifers so when nature strikes back, and smacks him on the head and kicks him in the nuts, I enjoy that. I have absolutely no sympathy for human beings whatsoever. None. And no matter what kind of problem humans are facing, whether it's natural or man-made, I always hope it gets worse.
Offline
Jul 22, 2009, 10:13 PM
#33
Personal Sales Rating: ( 0)
Drives: RR GSR X
Man this info is gold. Thanks a lot.
__________________
ETS V2 Catback
ETS O2 Down pipe
ETS Test Pipe
ETS 4" FMIC
ETS UICP
AMS LICP
AMS Fan shield
Harmon Motive intake
Eibach Prokit Springs
Mishimito Coolant Hoses.
Skunk2 Shift Knob
Perrin Stubby Antenna
Cobb AP Stage 2 ACN AMS
AEM UEGO/Boost
Exedy Stage 2 HD
Act Prolite Flywheel
Whiteline Roll Center Adjustment
Offline
Jul 23, 2009, 01:58 PM
#34
Drives: RR Evo X GSR
wait hold on a sec, i see the pics, but im a noob, how can i get my dealer to do this for me...they r estimating 3 weeks b4 they even have a MC to put on my car!!!!!!!!
__________________
ETS 3.5" Intercooler - Intercooler Piping Kit - Short Ram Intake - Test Pipe
UR Short Downpipe
Tanabe Concept G Catback Exhaust
Hallman MBC
Defi Boost Gauge
AEM Wideband
AMS Underhood Bushings - Reinforcement MC Ring - SS clutch line
Greddy Counterweight Knob
JIC FLT-TAR Street Coilovers
Volk Racing Mercury Silver TE37s 18 x 9.5 +22 mm
ACT HDSS Street Clutch
Works Shifter Bushings - Short Shift Kit
RA Mudflaps
Pioneer AVIC-D3X
EcuTek Tuned
On Dynojet:
351 awhp 340 awtq
Offline
Jul 23, 2009, 04:35 PM
#35
The first one, a larger pump was used and made the pedal a little stiffer than expected (althoug it still works flawlessly), but if an smaller diameter pump is used the pedal feel would be even better.
Plus:
The 75 and 76 series CMC are roughly $120...what's involed with making it work?
I will have my tranny/clutch and CMC out this weekend. I would love to do this.
Does it bolt right up without drilling the base plate and pedal?
__________________
Alex
Offline
Jul 23, 2009, 04:43 PM
#36
Drives: 08 GG EVO X GSR, 08 RR Outlander ES
subscribed
__________________
2008 GG EVO X GSR SSS
~ AEM Intake: GST Boost pill: Buschur "Quiet" CBE: No Limit Recirc O2 Dump: No Limit Testpipe: No Limit UICP
~ SPEC P-Trim Twin Clutch : AMS Underhood Bushings
~ TWM Short Shifter w/ Bushings : TWM Big Type R Shift Knob
~ Sharkfin Antenna: OEM Mud flaps: Ralliart Taillights
~ Zeitronix ZT-2 Wideband w/ 3.5 MAP Sensor
Installing - AMS Clutch Master Cylinder Ring
Custom In-Dash Carputer : CF Sub enclosure
Offline
Jul 23, 2009, 05:01 PM
#37
Personal Sales Rating: ( 1)
Drives: EVO X MR Rotor Glow
The car and idea was mine, but the installation process belongs to a friend of mine called Abdiel from TransmisionesPR.com, but I can tell you this much, YES the base has to be drilled and the pedal has to be lightly modified to accept the helm joint.
According to our experience the pump does not have to be extremely large to work.
His phone number is 787-458-6866
__________________
www.carrito.net Home of the FIRST EVO X in the 10's
09 Evolution X MR Rotor Glow
AMS Upper pipe / Dual Exhaust / Downpipe / SST Cooler
Do-Luck Carbon Fiber trunk
TiTek Carbon Fiber hood intake
APR Carbon Fiber Radiator shield
Yiito Turbo's 20g Turbo upgrade
Tusbosmart BOV
GSC Power-Division S1 Cams
AEM & PERRIN Cold Air inatke
SSR Type F wheels 18x10.5 +15
NITTO INVO 18x275/35
OEM Rear Strut Brace
Perrin 3" Antenna
STOPTECH Big brake kit 355mm All four wheels
Offline
Jul 23, 2009, 05:20 PM
#38
Personal Sales Rating: ( 3)
Drives: 2008 evo 10 gsr, 2000 chevy venture L0L ex cars 2006 evo Se
I have that ams part in & I have had no problems with my master cylinder
__________________
**DG Motors Sponsored**
Call DG Motors 631-957-8464 for all you Evo needs
Dyno Tunes
Installations
Full builds
Dyno time
Offline
Jul 23, 2009, 08:48 PM
#39
Thank you !!
__________________
Alex
Offline
Jul 23, 2009, 10:58 PM
#40
Quote:
How long have you had the ring on?
Offline
Jul 23, 2009, 11:14 PM
#41
Drives: Evo X
Quote:
no way in hell a mitsu dealer will do this... you are on your own there.....
__________________
Offline
Aug 1, 2009, 07:03 AM
#42
Drives: OB Evo X GSR, 72 c-10
LOL, you might as well get the dealer out of your mind when it comes to installing aftermarket parts on your car, especially if anything needs to be modded to accept the part. I'm kinda amazed some dealers agreed to install aftermarket clutches on customers X's. That normally is a no no.
Carrito, what bore master cylinder did you use, and which bore would you recommend instead?
Offline
Aug 1, 2009, 04:07 PM
#43
Drives: EvoX Gsxr1K6 WR450
It took me about 2 hours to install the AMS Clutch Master Cylinder re-enforcing ring. You will Need 2 people ideally and I found it quite fiddly getting it back in.
Offline
Aug 1, 2009, 07:07 PM
#44
7/8" but I recommend 3/4" for must cases, We didn't know exactly and I ordered the larger one, but it is a bit overkill, the smaller diameter 3/4" works much better... Plus is rebuildable, height adjustable and way stronger than the Evo 9 or stock one
__________________
Tusbosmart BOV
Perrin 3" Antenna
Offline
Aug 6, 2009, 11:52 AM
#45
My dealer has installed an aftermarket clutch, the reinforcement ring and the clutch line
__________________
UR Short Downpipe
Hallman MBC
Defi Boost Gauge
AEM Wideband
RA Mudflaps
Pioneer AVIC-D3X
EcuTek Tuned
On Dynojet:
351 awhp 340 awtq
Offline
Tags
2008, 76, ams, broke, clutch, cylinder, diameter, evo, install, line, master, series, sti, tilton, wrx  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
