Oct 13, 2008, 05:01 PM
Personal Sales Rating: ( 3)
Drives: Evolution X
Why am i the only one with this problem :(
I have a boost problem were it goes only up to 19 lbs no matter wat mbc it tapers really fast, my current mbc is FORGE UNOS , i have it running just like the instructions , one going to the inlet/outlet tube and the other to the westgate actuator like most are doing it, i used new vacummm hoses to prevent any hidden stock solenoids, wen i turned the mbc it was like this
1- turn - 13psi
2- turns- 18psi
3- turns- 19psi
4-10 turns 19 psis
Like it can go lower than that but no higher, i had a different mbc before(turbo xs standard) and it was the same exact thing.
Please help me with any tips or pictures that you may have or if you ever ran into this error tell me how you fixed it, thanks.
__________________
Looking for sponsors for HIN miami (Hot Import Nights ,The action takes place 5pm - MIDNIGHT, December 20, 2008 at Miami Beach Convention Center. )
PM ME
Proud to be sponsored by:
-AWD MOTORSPORTS ( www.awdmotorsports.com)
Offline
Oct 13, 2008, 05:05 PM
Personal Sales Rating: ( 2)
Drives: OB X, SSS
i had that problem with the perrin mbc, try switching the way you have the hoses connected
__________________
Engine: ETS Front Mount, ETS Upper IP, ETS Lower IP, AMS Intake System, GFB Bov, Forge MBC @ 23lbs, Forge wastegate actuator, Prosport Boost Gauge
Exhaust: Ultimate Racing Downpipe, Ultimate Racing Resonated Test Pipe, ETS Dual Exhaust, AEM Uego
Suspension: BC Adjustable Coilovers
Misc: Volk CE28N (Flat Black), RA Mud Flaps, ACT 6 Puck Clutch, ACT StreetLight Flywheel, 3% Tint
XtremeBoost
Darkside Engineering
www.tracktalk.net
Offline
Oct 13, 2008, 05:06 PM
Drives: Evolution X
well i did it exactly as it said in the instruction booklet but its never worth a try, ill go do it right now and come back with the results.
__________________
PM ME
Offline
Oct 13, 2008, 05:47 PM
Drives: Evolution X
tried it, but now its 1st gear - 15psi no taper, 2ne gear 15 psi no taper, 3rd 12 psis no taper, why would it go down in third, its late so i will try it tommorow again,
__________________
PM ME
Offline
Oct 13, 2008, 05:51 PM
Personal Sales Rating: ( 19)
Drives: evo8MR + subi RS +08 Lancer
when u say "turn" is that a full rotation or clicks?
__________________
Lots o' bolt on's... suspension, brakes, motor
327awhp/304awtq est. DLL @ roughly 23psi
New time:
12.13@113_____stock block, head, turbo... 6speed
Undefeated SCCA SOLO record in Gulfcoast and Delta region
Coming VERY SOON
Muellerized Stage3 MOTONS...
Offline
Oct 13, 2008, 06:07 PM
Drives: Evolution X
full rotation, which is about 5 clicks.
__________________
PM ME
Offline
Oct 13, 2008, 06:20 PM
Drives: OB X, SSS
wow idk i have the same one i think and mine works fine!?!?!?!
__________________
XtremeBoost
www.tracktalk.net
Offline
Oct 13, 2008, 06:40 PM
Drives: Evolution X
can you take a picture of how you have it set up please.
__________________
PM ME
Offline
Oct 13, 2008, 08:42 PM
Personal Sales Rating: ( 9)
Drives: 08 GG X
Dude just tighten your wastegate 3 full turns prob solved. take off the mbc
Offline
Oct 14, 2008, 04:23 AM
Personal Sales Rating: ( 4)
Drives: 2008 Lancer, 1999 Eclispe Spyder
check your spring. i have a hallman MBC and it came with 2 springs. i couldn't get one spring to go about 20psi the spring just wasn't stiff enough to hold it closed. so i put a new stiffer spring in it and it works like a charm.
__________________
2008 lancer
Offline
Oct 14, 2008, 07:05 AM
Personal Sales Rating: ( 21)
Disconnect the vac house from the wastegate completly and then go see what you boost. If you do not boost more than 19psi this way then you have a problem with something else, ie bad wastegate, wastegate to loose, boost leak, turbo problem or your gauge is wrong.
Offline
Oct 14, 2008, 09:11 AM
2008 Mitsubishi Lancer Evolution
Drives: HBSpeed Tuned X GSR | STi
do you still have the forge wga installed? if so take that off and see how much you boost
__________________
JOEY | '08 GSR 326HP/344TQ | '10 STi
| HKS Legamax Catback | AEM Intake | Nisei MB Pipes | ETS 3.5" IC | Cobb AP, Rear Sway | Walbro | DW 800cc | UR DP/O2 | RRE RallyCat | WORKS SSK, Base Bushings | AMS Cable Bushings | ARC Ti Knob | T1R Boot | RalliArt AC Panel, Taillights | BC Racing Coilovers | Volk CE28N TA 18x9.5" +24 | JDP RA Lip | APR CF VG, CF Rad Panel, Grill Cover | Defi Boost, CUII | Rexpeed Spats, Vents, Hood Dampers | OEM Visors, Trunk Spoiler, '09 Cupholder |
Online
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
