Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 10, 2008, 11:58 AM   #1
Personal Sales Rating: (0)
Gexxer's Avatar
Drives: Evo X
My engine tick
My engine had a tick from the day i bought it back in January. People said it was the injectors or the coil packs firing and i didn't worry about it. Till last week when i finally met up with another guy here in vegas with a GSR and his doesn't tick..
Currently my car is at the dealership with the head being pulled off. they believe its a couple bent valves, but are waiting till they pull them and talk to mitsubishi. I will update this post once i have heard from them today. Just wanted to give a heads up to people that have heard some bad noises from their compartment.
update oct 11th -
I just got the car back from dealship. the tech said the car is drivable and they ( mitsubishi ) haven't released anything for them to fix it, so unless a valve fails I'm boned for now. I read thru the paperwork briefly and it stated the noise is in all four cylinders and its not the injectors.
__________________
'08 X GSR
AGP Hardpipes
AGP FMIC
Dynojet CMD Piggyback <--- testing ATM
Offline
Old Oct 10, 2008, 12:02 PM   #2
Personal Sales Rating: (5)
EVIL_EVO_VIII's Avatar
Drives: 08 Octane Blue Evo X
Have you over reved the car or mis-shifted gears?
Offline
Old Oct 10, 2008, 12:13 PM   #3
Gexxer's Avatar
Drives: Evo X
never, even when i took the car out to the track i short shifted it at 6k-6500 and as i said the night i pulled out of the dealship it was there.. on both of the GSR's they had.. So I was under the impression that it was the coils or the injectors since none of my previous cars used setups like this car
__________________
'08 X GSR
AGP Hardpipes
AGP FMIC
Offline
Old Oct 10, 2008, 12:35 PM   #4
RogueValley's Avatar
Drives: 92 Stealth RT/TT| 08 EvoX RR GSR|Broke 06 GTO
Do keep us updated. I too have noticed a clicking, I assumed it was a semi-lousy setup with the new timing chain. Had mine since day 1, but it hasn't ever caused me any issues other than makes me irritated everyonce in a while.
Offline
Old Oct 10, 2008, 01:09 PM   #5
Drives: '03 TB EVO VIII
I used to get a similar ticking sound on my old integra when the valve lash would come out of adjustment. Of course, the evos have an automatic lash adjuster, but this can fail as well. If this is the case, my understanding is you'll get a ticking or a chattering sound.
Don't know if this applies to an X or not, but I took this from the '03 VIII service manual:
LASH ADJUSTER CHECK M1111002900347
If an abnormal noise (chattering noise) is heard by malfunction
of the lash adjuster immediately after starting the engine and
does not disappear, it might be the lash adjusters. Perform the
following check.
NOTE: An abnormal noise due to malfunction of the lash
adjuster is produced immediately after starting the engine and
changes with the engine speed, irrespective of the engine load.
If, the abnormal noise is not produced immediately after start-
ing the engine or does not change with the engine speed, or it
changes with the engine load, the lash adjuster is not the cause
for the abnormal noise.
NOTE: When the lash adjuster is malfunctioning, the abnormal
noise is rarely eliminated by running the engine at idle speed.
However, the abnormal noise may disappear only when seizure
is caused by oil sludge in the engine whose oil is not main-
tained properly.
1. Start the engine.
2. Check if the abnormal noise produced immediately after
starting the engine changes with the change in the engine
speed.
If the abnormal noise is not produced immediately after
starting the engine or it does not change with the engine
speed, the lash adjuster is not the cause for the noise.
Therefore, investigate other causes. The abnormal noise is
probably caused by some other parts than the engine proper
if it does not change with the engine speed. (In this case, the
lash adjuster is in good condition.)
3. With the engine idling, change the engine load to make sure
that there is no change in the level of abnormal noise.
If there is a change in the level of abnormal noise, suspect a
tapping noise due to worn crankshaft bearing or connecting
rod bearing. (In this case, the lash adjuster is in good
condition.)
4. After completion of warm-up, run the engine at idle to check
for abnormal noise.
If the noise is reduced or disappears, clean the lash adjuster
(Refer to GROUP 11B − Engine overhaul − Rocker Arms
and Camshaft − Inspection P.11B-32.) It is suspected that
the noise is due to collapse of the lash adjuster. If there is no
change in the level of the abnormal noise, proceed to step 5.
5. Run the engine to bleed the lash adjuster system. (Refer to.)
6. If the abnormal noise does not disappear after air bleeding
operation, clean the lash adjuster (Refer to GROUP 11B −
Engine overhaul − Rocker Arms and Camshaft − Inspection
P.11B-32.)
Good luck with getting things fixed.
Offline
Old Oct 10, 2008, 01:16 PM   #6
Drives: WW X
I have the same problem with the ticking, I'm gonna have to get that checked
Offline
Old Oct 10, 2008, 01:29 PM   #7
08EvoXGSR's Avatar
Drives: 06 C55 AMG
I've had it for 19k miles and never realy thought about getting it checked....thought it was just a 4 banger banging!
__________________
Originally Posted by Dyno4mance
OP may not have a bad TC but he certainly has a service manager with a bit of tard in him.
Offline
Old Oct 10, 2008, 01:37 PM   #8
Personal Sales Rating: (1)
Joe's Evo X's Avatar
Drives: Evolution X, Kawasaki Ninja zx10r 2006
MMMMMMm this is not good. And other people are hearing the click. I hope its nothing. Mine is not doing this but ill keep an eye out for it.
__________________
CURRENT MODS
DTM FMIC
DTM DOMINATOR 2 TURBO FROM BLOUCH
DTM LICP
AQUAMIST METH KIT HFS-1
U-R DOWN PIPE
U-R TEST PIPE
U-R CAT BACK EXHAUST
U-R UICP
AMS INTAKE
AMS SHIFTER BUSHINGS
GREDDY PROFEC B SPEC II EBC
GREDDY TURBO TIMER
EIBACH PRO KIT LOWERING SPRINGS
ACT CLUTCH
AEM WIDEBAND GAUGE
5% WINDOW TINT
390AWHP/330 TORQUE ON MD @ 23-24PSI TUNED BY MITCH
Offline
Old Oct 10, 2008, 01:41 PM   #9
Damn lash adjusters. I thought Mitsu had this problem fixed in '99 with the big bore lash adjusters?
Offline
Old Oct 10, 2008, 02:24 PM   #10
Personal Sales Rating: (2)
2003 Ford Mustang
zTargeTz's Avatar
Drives: 99 GSX, 08 RR GSR
Quote:
my 99 still has the small bore and is very clacity clack clack. but its a 4g63, comes with the territory
__________________
Rawr
Offline
Old Oct 10, 2008, 02:27 PM   #11
Personal Sales Rating: (21)
scottatyamaha's Avatar
Where did the tick sound like it was coming from in the engine? Did you have to put your head up to the motor to hear it? Did it change sounds when reving the engine?
Offline
Old Oct 10, 2008, 02:30 PM   #12
i get the tick too and every X ive heard sounds the same.. You guys are being paranoid as hell..This is my 4th Evo, and EVERY single one of them had the ticking sound from the engine. Its the injectors or the lifters ticking most likely
Offline
Old Oct 10, 2008, 02:34 PM   #13
Quote:
At first I was worried, brushed off the worry, and it was reinstated when the OP mentioned it. My LS2 didn't tick... But that's apples to oranges.
Offline
Old Oct 10, 2008, 02:48 PM   #14
08EvoXGSR's Avatar
Drives: 06 C55 AMG
its a 4 banger-my RA from 06 did the same thing, MS# did, focus ST did...its the sound a 4 banger makes....no worries guys-turn the radio up, windows down, boost up, spool up-and make the girls giggle
__________________
Offline
Old Oct 10, 2008, 03:48 PM   #15
EvoXCrazy's Avatar
Drives: Evo X GSR
To OP how long has the other guy with the gsr had his? If it new that would explain the no tick, Mine didn't tick till I put some miles on it
Offline
Tags
2008, engine, evo, fix, h22, injectors, jeep, lancer, liberty, low, noisy, rpms, scion, tapping, tick, ticking, valve
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
