Nov 3, 2009, 03:44 AM
#61
Personal Sales Rating: ( 0)
Drives: Evo X
man i didnt realize this topic came back.
For those with the issue... it is a known issue with MMNA. I got mine fixed with little hassle from the dealership once I got a service writer that wasn't a piece of ****. Although its always better to talk to them before you take the car there if you have mods.
__________________
'08 X GSR
AGP Hardpipes
AGP FMIC
Dynojet CMD Piggyback <--- testing ATM
Offline
Nov 3, 2009, 08:06 AM
#62
Personal Sales Rating: ( 2)
Drives: Evolution X GSR
What did they do to fix it?
__________________
2008 Lancer Evolution X GSR
Baseline - 259whp @ 21PSI *stock turbo*
Tuned - 358whp @ 25PSI *stock turbo*
Tuned by TTP Engineering - Orlando, FL
Offline
Nov 3, 2009, 08:59 AM
#63
Drives: Evo X
I had a bent tappet in cylinder #3 and a broken tappet in #4. they replaced both. read the first couple pages of this post, I talk about the when and where it took to get it done a little bit.
My car was bone stock when this problem developed also.
__________________
'08 X GSR
AGP Hardpipes
AGP FMIC
Offline
Nov 3, 2009, 09:38 AM
#64
Drives: 2009 Lancer GTS BLK/BLK , 2008 Mitsubishi Lancer Es
my fiances scion tc ticks my 08 es ticks my 09 gts ticks, they ALL tick and ALL have 35k miles or more both lancers ticked since day 1.
does your x still tick @ all ?
__________________
2009 Black Lancer GTS S&S, OEM EVO X hood , EVO X Recaro Seats, 2.4L Injen CAI, 18x8 MSR 045 225 40 HP Fierce tires, Carputer w/ 7" touchscreen running Centrafuse 1.47, Blacked out grille , Autopager 2 Way Alarm, Escort Passport 8500 X50 with ZR3 Laser Shifter, 20% Tint
Offline
Nov 3, 2009, 11:08 AM
#65
Drives: 2010 EVO X.....I dont need a wing!
Just to update my experience with the "tick", I have taken it to a shop to get a second opinion.
Mechanic's diagnosis. Valve train normal.
Culprit: Noisy stock Injectors.
Everything is normal.
Offline
Nov 3, 2009, 08:35 PM
#66
Drives: Evo X
since the fix.. no ticking... just the regular noisy injectors and other normal noises when i bought the car. btw... my tick got so loud i could hear it in the cabin with the windows rolled up. when i went ot the dealership the last time when they fixed it... the service manager was standing there and said "man, what's wrong with your car?" when i pulled up.
i dont mean to sound like an @sshat, but do you know the difference between normal engine sounds and bad engine sounds? I'm not being sarcastic either. A LOT of people dont know what sounds are supposed to be there and what aren't.
__________________
'08 X GSR
AGP Hardpipes
AGP FMIC
Offline
Nov 3, 2009, 08:37 PM
#67
Drives: Evo X
the service writers tried these bull**** lines on me when i first started taking the car in.
for the record... it took 6 visits to the dealership over a 6 month period. I put over 10k miles on the car during this time. I kept going back so they had records of my complaints and could not later come back and say i did something to void the warranty or cause this damage.
__________________
'08 X GSR
AGP Hardpipes
AGP FMIC
Offline
Nov 5, 2009, 07:09 PM
#68
wow. Youre making me paranoid about my engine!  Hope that this is not the case. I have not gone to he dealership to diagnose the problem, took it to a knowledgeable friend in the industry.
Did you notice any other symptoms other than the ticking? ie power loss, limp mode, etc?
Offline
Nov 5, 2009, 08:09 PM
#69
Drives: Evo X GSR
Does anyone notice the ticking sound coming from different parts of the engine bay? Our engines aren't exactly quiet with the hood up by any means...
I had a 2008 subaru legacy before I got my X and it was by far louder than any engine bay I've listened to so I thought the sounds were completely normal.
Offline
Nov 5, 2009, 11:56 PM
#70
Drives: Evo X
if you guys really want to cure your paranoia..... get together with another X and listen to each others engines.
__________________
'08 X GSR
AGP Hardpipes
AGP FMIC
Offline
Nov 6, 2009, 09:25 PM
#71
2008 Mitsubishi Lancer Evolution
Drives: Lancer Evolution SS-T
It IS the injectors making the racket and the 'ticking' noise is dependant on the cycling, and that is dependant on a heap of inputs like eng temp, ambient temp etc etc
Hence why you can put one X next to another and they may not exhibit the same ticking or cliking noise. If both cars have had the same drive cycle, you'll find they will resemble the same noise.
For what it's worth, it's perfectly normal and acceptable as it's a part of their design. I know it does seem to sound like 'sticky' hydraulic lifters to the untrained ear, but everything is fine.
Offline
Nov 7, 2009, 04:33 PM
#72
Drives: Evo X
this is where my statement about knowing the difference between normal sounds and abnormal sounds comes in.
I can tell you from spekaing with MMNA directly ( read: their voice to my ear ). This is a problem they are looking to address as it is happening a lot. They wouldn't tell me how many cases they had going, but he did say mine was not the first to have failed Valve Tappets.
yes this engine is noisy.... it is NOT more noisy than my 4g63 motor. It is also still only a 2 year old motor... you can't expect problem to not come up.
one more thing.... the ticking of the valve tappets sounds quite a bit different than the clicking from the injectors. I tried to record the sounds while i was waiting for the stealership to fix it, but i dont have a mic good enough to filter out the ambient noises.
__________________
'08 X GSR
AGP Hardpipes
AGP FMIC
Offline
Tags
2008, engine, evo, fix, h22, injectors, jeep, lancer, liberty, low, noisy, rpms, scion, tapping, tick, ticking, valve  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
