Oct 2, 2008, 05:25 PM
Personal Sales Rating: ( 91)
Drives: 9.50 @ 148 (no nos)
Forge WGA testing
Today we tested a Forge WGA upgrade on a Evo X with just a cat back exhuast which previously made a best of 319 whp on our dyno
We installed the Forge upgraded actuator and found that the boost held significantly better through the power band
Power increased to 330 whp with a very conservative tune, but peak numbers dont tell the whole story as the shape of the curve is much improved and the power climbs all the way out to the red line
I will post a video and dyno sheet later when I have time after watching the moose hunter debate the liberal on TV
in the meantime, I wanted to suggest that the WGA upgrade seems like a great modfication on the X
Al
Offline
Oct 2, 2008, 05:31 PM
Silver Sponsor
Personal Sales Rating: ( 18)
Drives: from the passenger seat
excited to see the dyno sheet. Were you logging boost by chance?
Offline
Oct 2, 2008, 05:36 PM
Personal Sales Rating: ( 19)
Drives: AWD Machines
Nice numbers Al....
I hope the moose hunter has her bright orange vest on...we wouldnt want her getting shot at.
Offline
Oct 2, 2008, 07:40 PM
Personal Sales Rating: ( 6)
Drives: 2008 Evolution X & 1996 Eclipse GSX
11 peak whp sounds about right going from a stock WGA to the Forge. Once you preload the stock WGA that peak number becomes very similar as the turbo is doing all it can at 6k and above. Now at the 3-6k range I've held very steady boost in the low to mid range RPM's and the car has gained a ton of torque and better hp under the curve.
I set my boost in 5th gear for 26 psi and it will hold 25 psi in third all the way to 6k after which it tapers due to flow limits. The stock WGA would allow taper at a much lower RPM unless you really over preloaded it to the point of not being able to run lower boost due to restricting the internal wastegate flapper. The Forge WGA is a great upgrade for consistant and controllable boost levels and I can recommend it even if the stock turbo prevents it from improving the 6k+ rpm range. I would also be interested to see an overlayed dyno sheet of how mid range is the biggest boost with this mod.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Oct 2, 2008, 09:07 PM
Personal Sales Rating: ( 3)
Drives: gg mr ix , 55 VW vert, 55 VW ragtop
i'm installing one right now on a red. any recommended preload for the forge?
Offline
Oct 2, 2008, 09:15 PM
Interestingly, on this car we were unable to set it to achieve lower than a 25 psi minimum boost spike on pre load. We were running the boost through a Forge UNOS MBC. On pre load we set it with the least amount of pre load we felt prudent so that there were sufficient threads in the fitting at the end of the rod and the minimum boost spike was no lower than 25 psi. We tried 2 full turns extra pre load and it had no effect on the boost level or power.
The car seemed to hold 22 psi or 21 psi of boost for a really long time on the road. Frankly, while the peak power increase was not that earth shattering, the change in the feel of the power band was very inpressive.
Bang for the buck wise its a great modficiation.
Al
Offline
Oct 2, 2008, 09:24 PM
Here is the dyno sheet
Offline
Oct 2, 2008, 09:28 PM
Personal Sales Rating: ( 2)
Drives: OB X, SSS
yeah i noticed a nice difference when i got mine about 1 month ago
__________________
Engine: ETS Front Mount, ETS Upper IP, ETS Lower IP, AMS Intake System, GFB Bov, Forge MBC @ 23lbs, Forge wastegate actuator, Prosport Boost Gauge
Exhaust: Ultimate Racing Downpipe, Ultimate Racing Resonated Test Pipe, ETS Dual Exhaust, AEM Uego
Suspension: BC Adjustable Coilovers
Misc: Volk CE28N (Flat Black), RA Mud Flaps, ACT 6 Puck Clutch, ACT StreetLight Flywheel, 3% Tint
XtremeBoost
Darkside Engineering
www.tracktalk.net
Offline
Oct 3, 2008, 12:37 AM
Quote:
For me zero preload was just barely being able to slip it on the eyelet
I ended up with 1 turn in from there and so far I can do 22-23 psi minimum boost while still being able to get solid low to mid boost control to 26 psi with an MBC. Still tapers beyond 6k but it's a great upgrade for holding boost as long as possible in the mid range.
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Oct 3, 2008, 06:43 AM
Drives: WW EvoX
This is my car Al is talking about here. Thanks for everything Al, I had a blast driving back home the car pulls nice and strong considering the mods it has which isn't much. It was definately worth the upgrade and with the re-tune you gave it it seems I get slightly better gas mileage. I'm going to keep the car like this for a few months more than likely until early next year and then get rid of the cat. Hopefully my schedule is nice and stable by then and we can get pipe installed and re-tune a little bit more aggresive to make that extra power. Based on the way this car is reacting to mods it wouldn't surprise me if we break 360whp with out an intake.
__________________
Performance Mods: Nisei UIP - Ecutek Tune by Dynoflash @ ICS Performance Dynojet - Forge WGA - Forge Unos MBC - SX HFC w/ WB bung - Tsudo N1 Extreme Exhaust
Interior Mods: Defi White Racer Gauge - AEM UEGO WideBand
Exterior Mods: 20% Tints all around - Faux CF wing inserts
Offline
Oct 3, 2008, 01:42 PM
Quote:
Thanks for allowing us to use your car for our testing
As i am writing this we are installing the WGA on our X with full BR stage III - and drop in pistons - should be interesting
Al
Offline
Oct 3, 2008, 02:24 PM
Personal Sales Rating: ( 0)
Drives: 06 C55 AMG
nice....Al-you hook us up on a buy for the Forge WGA?
__________________
Originally Posted by Dyno4mance
OP may not have a bad TC but he certainly has a service manager with a bit of tard in him.
Offline
Oct 3, 2008, 03:25 PM
Well - I will have to see how many they have in stock after I have made this post - I'll get with them on Monday
I only had 3 which all went today
Al
Offline
Oct 3, 2008, 05:13 PM
Personal Sales Rating: ( 128)
Drives: 2005 Evo RS.. 1st Street Evo in the 8's!!
The WGA woke my evo X up as well.. along with the Ecutek flash from Al the car made ~340whp in 100degree weather..
__________________
Tel. 954-753-6006
AIM= mikeatawd
www.AwdMotorsports.com
- 2003 Black Evo GSR - 8.75@163mph (US Quickest 4g63 Evo )
- World's Quickest Evo 8 Street Car - 8.98@156mph
- World's Quickest / Fastest Stock Turbo Evo - 10.21@133mph ( Most-Wanted )
- World's Quickest Mivec Evo 9.05@157mph( Most-Wanted )
- Florida's Quickest Evo IX Street Car - 9.75@143mph ( Shaun's )
Modifying the 4g63 for only 2 years.. Yes Only 2 years.. Hard to believe with the records above..
Offline
Oct 9, 2008, 11:19 PM
Personal Sales Rating: ( 1)
Drives: 2008 X GSR
Thanks for the write up. I already adjusted my stock WGA, does the forge adjust the same? Does the forge WGA need adjusting or just plug and play?
__________________
2008 Evolution GSR (Needed da 5 speed)
IVYTUNED 400WHP
FP RED
Injen CAI
Hallman MBC
ETS FMIC
800cc Fuel Injectors
UR fuel pump kit
UR O2 Housing
UR TBE
Eibach Pro-Kit
Advan RZs 18X10 +25
2006 Evolution MR (destroyed by pole)
Offline
Tags
adjust, boost, evo, forge, forged, install, ix, mod, motorsports, preload, spike, unos, upgraded, wastegate, wga  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
