Jul 15, 2008, 02:21 PM
#121
Personal Sales Rating: ( 6)
Drives: WW EVO X
Quote:
Originally Posted by ArchieBabes
Thanks Man. Now its time for you to install that Meth Kit and make some more power.
It sure is, you got me inspired!
__________________
WW EVO X #32
AMS Front Motor Mount & Underhood Shifter Bushings
TurboTrix Piping Kit
ETS Dual Exhaust
T1R o2/DP Combo, T1R Testpipe, Shift Boot, Stubby Antenna
Prosport Boost Gauge
AEM Uego
DTM Stg. 2 FMIC
Perrin EBCS
Eibach Springs
Whiteline RCK
TWM STS, Bushings
Ichiba Spacer
Seibon CW hood/OEM Trunk
Chargespeed FRP VG
ECUTek Tune (318whp/359 Torque @ 26psi)
First EVO X in Canada to Break 300whp
Offline
Jul 15, 2008, 02:37 PM
#122
Personal Sales Rating: ( 38)
Drives: EVO X GSR
Quote:
Originally Posted by Joe's Evo X
Welll the long wait is over lol nice numbers. Did you ever try a 50/50 mix, I dont think ill be running 100%. I cant wait until mine goes on the dyno in 2 weeks. I should be over 400 awhp on a MD.
My tuner suggested to run 100% Methanol.
You will get more power running 100% than 50/50 mix.
Offline
Jul 15, 2008, 06:58 PM
#123
Personal Sales Rating: ( 0)
Drives: '01 Audi S4
Why will 100% methanol produce more power than a 50/50 water/methanol mixture?
Offline
Jul 22, 2008, 06:10 AM
#124
Personal Sales Rating: ( 1)
Drives: Evolution X, Kawasaki Ninja zx10r 2006
I heard if you run 100% that you are more likely to get leaks and for the system to fail.
__________________
CURRENT MODS
DTM FMIC
DTM DOMINATOR 2 TURBO FROM BLOUCH
DTM LICP
AQUAMIST METH KIT HFS-1
U-R DOWN PIPE
U-R TEST PIPE
U-R CAT BACK EXHAUST
U-R UICP
AMS INTAKE
AMS SHIFTER BUSHINGS
GREDDY PROFEC B SPEC II EBC
GREDDY TURBO TIMER
EIBACH PRO KIT LOWERING SPRINGS
ACT CLUTCH
AEM WIDEBAND GAUGE
5% WINDOW TINT
390AWHP/330 TORQUE ON MD @ 23-24PSI TUNED BY MITCH
Offline
Jul 22, 2008, 08:34 AM
#125
Personal Sales Rating: ( 4)
Drives: 2006 Mitsubishi Evolution IX MR
it depends on the meth kit installed. some can handle 100% meth some cant. as far as i know snow performance can handle 100% meth. as far as the aem kit goes it says on its website up to 50%. see link if you wanna continue using 100% just make sure you check it regularly for leaks.
__________________
-buschur tbe with test pipe
-buschur SS O2 housing
-buschur ported exhaust manifold
-nisei competion fmic plus piping kit
-nisei mini battery
-Walbro 255 Fuel Pump
-FIC Bluemax
-GM 3-Port
-aem air filter
-self tuned with EcuFlash & Zeitronix
Online
Jul 31, 2008, 12:32 PM
#126
Drives: Evo
I think there is a reason behind people say their kit is 50% meth compatible...
Offline
Aug 2, 2008, 01:24 AM
#127
Quote:
Pretty much what i was thinking. I think ill take a lil hp loss for reliability.
__________________
CURRENT MODS
DTM FMIC
DTM LICP
U-R DOWN PIPE
U-R TEST PIPE
U-R UICP
AMS INTAKE
GREDDY TURBO TIMER
ACT CLUTCH
AEM WIDEBAND GAUGE
5% WINDOW TINT
Offline
Aug 2, 2008, 05:30 PM
#128
Personal Sales Rating: ( 5)
Drives: 2008 evoX
I was looking at the install for the aem injection kit and was wondering where these 2 wires go?
Green wire, Boost-Safe output for timing retard or boost dump solenoid. 1.7a Max
Blue wire (opt) 0-5vdc pressure signal. (.328v = 0psig, 5vdc = 38psig)
__________________
Blouch turbo
Nisei intake
Nisei uic
Nisei lic
Ams intercooler
Ams MBC
Ams tune
Ams front motor mount
Xtreme boost external down pipe
ur injectors
ur resonated test pipe
ur single catback
Walbr fuel pump
ACT streetlite flywheel
ACT 6-puck with heavy duty pressure plate
AEM meth/water injection
Labonte meth/water injection safety switch
Aem wideband
Autometer boost gauge
Eibach springs
Rexspeed sidespats
Rota Grids 18x9.5
Goodridge ss brake lines
Offline
Tags
14, dual, ecutech, evo, exhaust, injection, methanol, psi, push, stock, turbo, watermethanol, zx  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
