Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Search
Sponsored by: Simple Tire
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old May 7, 2008, 05:12 PM   #1
Personal Sales Rating: (0)
2008 Mitsubishi Lancer Evolution
janvin21's Avatar
Drives: Evo X (GSR)
Points: 3,940, Level: 39
Points: 3,940, Level: 39 Points: 3,940, Level: 39 Points: 3,940, Level: 39
Daily Activity: 0.4%
Daily Activity: 0.4% Daily Activity: 0.4% Daily Activity: 0.4%
AMS Intake Question
ok! I install this AMS intake and I notice that there's a three hoses that connect to the stock intake, I know that one connect to BOV but the other two where do you connect them? does anybody here has a AMS intake install in thier X? how did you install them? I don't have a MBC setup yet,
Offline
Old May 7, 2008, 05:56 PM   #2
Personal Sales Rating: (4)
Garage is empty, add now
Joe's Evo X's Avatar
Drives: Evolution X, Kawasaki Ninja zx10r 2006
Points: 6,594, Level: 53
Points: 6,594, Level: 53 Points: 6,594, Level: 53 Points: 6,594, Level: 53
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Ok i am trying to install this my self and i have the same question lol help plz.
Offline
Old May 7, 2008, 06:05 PM   #3
Daily Activity: 0%
**** i just read there web site and we got the intake systme with out the breath bugs so we cant install them on the intake system. It says to get an oil catch can for the crank case and venting the solenoid to the atmosphere. How the **** do you do that.
Offline
Old May 7, 2008, 06:45 PM   #4
Mightygnu's Avatar
Drives: EVO X GSR
Points: 4,751, Level: 44
Points: 4,751, Level: 44 Points: 4,751, Level: 44 Points: 4,751, Level: 44
Daily Activity: 0%
Send a message via AIM to Mightygnu
I don't think you have to use the other hoses...
__________________
- Chris
Offline
Old May 7, 2008, 06:48 PM   #5
Daily Activity: 0%
Quote:
i am pretty sure we do or eles it is going to suck sh*t str8 into the motor.
Offline
Old May 7, 2008, 06:54 PM   #6
Mightygnu's Avatar
Drives: EVO X GSR
Daily Activity: 0%
This is directly from AMS' website, so I don't know what you guys are going to have to do without being there and seeing it.
This intake can be ordered in two different configurations. The default configuration is WITHOUT breather bungs for the crank case and boost control solenoid. With this set-up we recommend an oil catch can for the crank case and venting the solenoid to the atmosphere. This will not effect your EVO X's performance negatively in any way.
The second configuration incorporates bungs on the intake pipe where you plug in your breather hoses just as they were from the factory.
__________________
- Chris
Offline
Old May 7, 2008, 07:25 PM   #7
STi2EvoX's Avatar
Points: 5,591, Level: 48
Points: 5,591, Level: 48 Points: 5,591, Level: 48 Points: 5,591, Level: 48
Daily Activity: 5.5%
Daily Activity: 5.5% Daily Activity: 5.5% Daily Activity: 5.5%
Well, I would opt for the 2nd config for the intake because having suction on the crank case breather line helps get out the oil blow by gases more efficiently than just having the line open. Plus, you can still use an oil catch can with this setup and it will actually work better anyway because yet again, there is suction pulling out the blow by gases. Just make sure to use a mesh like sponge material in the catch can itself otherwise it won't capture all of the blow by gases as well as it could. Hope this helps...
Offline
Old May 7, 2008, 10:19 PM   #8
Daily Activity: 0%
Well i was thinking of going to a local welder and having them weld a place where i can place this to hoes what do you guys think.
Offline
Old May 7, 2008, 10:52 PM   #9
MajesticOne's Avatar
Drives: 2008 EVO X GSR
Points: 5,840, Level: 49
Points: 5,840, Level: 49 Points: 5,840, Level: 49 Points: 5,840, Level: 49
Daily Activity: 0%
I just left it hang for now. I need to get an oil catch can, but no real rush, I connected an extra hose I have and have it leading out of the engine bay. The car runs fine, I just need to install my MBC and boost gauge this weekend.
Offline
Old May 8, 2008, 04:01 PM   #10
Daily Activity: 0%
Ok so i called ams and they said to get a catch can or just get a little filter to put on the crank case. So i went to auto zone and bought a little filter and pulled the hose off and just attached the small filter to the metal tip and it works fine. I just have to clean it every once in a while from oil. The other hose I dont have to worry about they said plus i have a EBC i am going to hook up.
Offline
Old May 8, 2008, 08:58 PM   #11
Mightygnu's Avatar
Drives: EVO X GSR
Daily Activity: 0%
Glad to hear your up and running!
__________________
- Chris
Offline
Old May 9, 2008, 08:10 AM   #12
Points: 2,659, Level: 31
Points: 2,659, Level: 31 Points: 2,659, Level: 31 Points: 2,659, Level: 31
Daily Activity: 0%
Glad to hear you got it done! I had a problem with a 2002 chevy putting on the intake but then again Im just an idiot =O
Offline
Old May 9, 2008, 01:53 PM   #13
Personal Sales Rating: (2)
SilverEvoX's Avatar
Drives: Rotor Glow Evo X
Points: 5,465, Level: 47
Points: 5,465, Level: 47 Points: 5,465, Level: 47 Points: 5,465, Level: 47
Daily Activity: 0%
Anyone have the catch can installed yet with pics? I ordered mine without the optional spots for the "factory" style setup again. I already bid on a Greddy catch can and am trying to figure out a good mounting spot for it when my AMS intake arrives in about a week. Thanks ~Trent
__________________
AMS Polished Intake/AMS Test Pipe/AMS Twin Tip Catback/Buschur FMIC/Buschur Polished UICP/Grimmspeed 3 Port/Defi Red Racer Boost Gauge/Innovate DB 99 Red Wideband Gauge/FIC 1100's/BlaqOps 255lph Kit/E-85/Swift Spec R Springs/SBC RPF-1 18x9.5 +15
Cobb Protuned 369whp 395wtq @ 26psi
Offline
Old May 9, 2008, 02:34 PM   #14
Gold Sponsor
Personal Sales Rating: (42)
AutoMotoSports's Avatar
Drives: 2007 BMW 335i
Points: 81,360, Level: 100
Points: 81,360, Level: 100 Points: 81,360, Level: 100 Points: 81,360, Level: 100
Daily Activity: 0%
thanks for answering the question for us. As was stated we offer the intake in two different varieties. some people really don't want to have to worry about a crank case venting into the intake pipe. We respect that and now offer our intake in two different ways.
most of the ones we have been installing we have been doing it without the two lines. Customers seem more keen on doing that either because its cheaper or that its a cleaner stream of air to the motor. We do highly recommend running a catch can on any engine though with or without an intake. Its just a healthier way to operate the car.
Eric
__________________
Eric Gaudi
Sales Mgr.
Email
www.amsperformance.com
847-709-0530
  • Worlds first 9 and 8 sec Nissan GT-R and quickest 8.97@169.49
  • 2009 AMS Racing – 60+ Victories & 4 National Championships
  • 2009 Redline Time Attack Unlimited & Modified AWD Champions
  • World's Highest HP EVO 4-9 - 1142 AWHP 8.42 ET
  • Now offering products & services for Porsche, GT-R, BMW & Audi
Offline
Old May 9, 2008, 04:10 PM   #15
Mightygnu's Avatar
Drives: EVO X GSR
Daily Activity: 0%
Eric
Thanks for providing such a great system!
__________________
- Chris
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
ams, breather, bungs, catch, connect, crankcase, evo, extra, hoes, hose, hoses, install, intake, oil, venting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
