3.5" Maf Scaling Table??
I’m hoping some one here can give me a hand or a jump start with the maf scaling tables. I’m going to use a 3.5” maf housing that measures exactly 86mm ID. I measured the stock maf housing and I got 65mm ID. The new maf housing is roughly 31% larger. But from the treads I’ve been reading I think 31% increase to the table will be too much.
Anyone that doesn’t mind sharing there maf scaling tables for a 3.5” maf please post them.
It really is that simple, worst case you want to overshoot a bit so it is on the rich side, then work your way back down leaner again to tweak it.
For reference I went with a 1.35 multiplier (35%) and trims are pretty close to what I had. Select the entries you want to change and choose "Multiply Data" under the edit menu and enter in the multiplier you want to use. I like to go to the View menu and do a "view graph" to verify they changed properly, the curve should be pretty much the same as before.
I had a little trouble finding these too, just happen to have them open so I'll share
evo10base.xml
52680015.xml
I settled on 1.39*stock values after starting at 1.48 (extra safe).
I'd just start at 1.4* just like tephra said. If you do the math, it works out:
area of circle: pi*r*r
inner diameter(stock): 2.8" (r=1.4)
inner diameter(primo): 3.3" (r=1.65)
area (stock) = 1.4*1.4*3.14 = 6.15 sq inches
area (primo) = 1.65*1.65*3.14 = 8.55 sq inches
conversion ratio (primo/stock): 8.55/6.15= 1.39
It is amazing how nicely the car runs on a maf this huge!
evo10base.xml
Code:
<scaling name="MAFVoltScaling" units="units" toexpr="x*5/1024" frexpr="x*1024/5" format="%.3f" min="0" max="5" inc="1" storagetype="uint16" endian="big"/> <table name="MAF Compensation" category="Fuel" type="2D" scaling="AirFlow16"> <table name="X" type="X Axis" elements="40" scaling="MAFVoltScaling"/> </table> <table name="MAF Compensation #2" category="Fuel" type="2D" level="1" scaling="AirFlow16"> <table name="X" type="X Axis" elements="40" scaling="MAFVoltScaling"/> </table> <table name="MAF Compensation #3" category="Fuel" type="2D" level="1" scaling="AirFlow16"> <table name="X" type="X Axis" elements="50" scaling="MAFVoltScaling"/> </table>
Code:
<table name="MAF Compensation" address="5753a"> <table name="X" address="615ea"/> </table> <table name="MAF Compensation #2" address="5758a"> <table name="X" address="6163a"/> </table> <table name="MAF Compensation #3" address="575da"> <table name="X" address="6168a"/> </table>
evo10base.xml
52680015.xml
evo10base.xml
Code:
Code:
Guys, I used 1.4 multiplier for 3.5 inch maf, the trims are within 1.5-2%, but there is a big quetion. The car iddles at 0.4 volts, and in the maf scaling table values for 0-1.02 volts are 0-s. So basicaly when we are multiplying those values by 1.4 we are gettion 0 at the end. Does this mean that we are not scaling the MAF in 0-1.02 volts area. Am I missing something ?
