Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Mar 29, 2011, 05:44 PM   #1
Personal Sales Rating: (0)
Garage is empty, add now
Jookies's Avatar
Drives: 2010 Evo X
Points: 2,673, Level: 31
Points: 2,673, Level: 31 Points: 2,673, Level: 31 Points: 2,673, Level: 31
Daily Activity: 0.5%
Daily Activity: 0.5% Daily Activity: 0.5% Daily Activity: 0.5%
Little bit of knock normal?
Hey guys, so I tried to find a thread really close to mine, so i wouldn't hafta waste everyone's time with another knock question haha, but couldn't seem to find one. Anyway, At WOT I'm getting between 0.7-1.8 "knock retard" on cobb AP, which is from what i understand, about 1-2 counts of it. Is this normal to see? or should i be worried?
Offline
Old Mar 29, 2011, 05:58 PM   #2
Personal Sales Rating: (1)
HELPr's Avatar
Drives: Evolution X
Points: 2,054, Level: 27
Points: 2,054, Level: 27 Points: 2,054, Level: 27 Points: 2,054, Level: 27
Daily Activity: 1.1%
Daily Activity: 1.1% Daily Activity: 1.1% Daily Activity: 1.1%
Hmm, i too see knock on the AP, but its almost always when engaging a gear, almost every gear change = 0.4 or 0.7 KNOCK and i see as much as 3.5 during take off in first gear, not launch, just normal daily driving take off, easy throttle.
__________________
Straigts are for fast cars, Corners are for fast drivers.
Do it once... Do it right.
COBB SF Intake
Buschur Exhaust
COBB AP (just installed)
TRUSTED SELLERS
1. Evofreak21
2. fostytou
Offline
Old Mar 29, 2011, 06:01 PM   #3
Jookies's Avatar
Drives: 2010 Evo X
Thats odd... Mine is only at WOT or very close to WOT, never at partial throttle.
Offline
Old Mar 29, 2011, 08:00 PM   #4
2008 Mitsubishi Lancer Evolution
HPEVOX's Avatar
Drives: 08 EVO X GSR
Points: 2,740, Level: 31
Points: 2,740, Level: 31 Points: 2,740, Level: 31 Points: 2,740, Level: 31
Daily Activity: 1.2%
Daily Activity: 1.2% Daily Activity: 1.2% Daily Activity: 1.2%
Any clutch slipping can cause the initial knock when engaging a gear, but you should be fine as long as you keep it below 1.0 .35 and .7 you're all good according to the techs on here.
__________________
GO: Inj intake, ETS 4" IC/UICP/LICP/CBE/HFC, MAP O2 elim DP, Cobb Stage 2-93oct pro-tune, Ohlins DFV, Whiteline RCK/RSB/Rear End Links, ACT 6 puck sprung, Magnus CMC, Grimmspeed 3-port EBCS, Girodisc slotted rotors EBC reds, Binary brake nozzles, AMS SS lines/shifter bushings, Dunlop Star Specs
SHOW: Rexpeed CF font bumper lip (v-style), CF front bumper splitter (type f), AEM digital boost & AFR gauge, DSG A-pillar dual gauge pod, Cobb Knob, OEM rims painted black w/factory RR lip.
Offline
Old Mar 29, 2011, 08:15 PM   #5
Jookies's Avatar
Drives: 2010 Evo X
Quote:
so when mine goes to 1.4 and 1.8... that's too high?
Offline
Old Mar 30, 2011, 12:44 AM   #6
Points: 4,349, Level: 41
Points: 4,349, Level: 41 Points: 4,349, Level: 41 Points: 4,349, Level: 41
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Quote:
up to 0,7 knock retard = 2 knock sum - at WOT acceptable if it is random
1,8 = 5 knock sum, a bit much at WOT, tuning would be needed.
Offline
Old Mar 30, 2011, 05:22 AM   #7
Jookies's Avatar
Drives: 2010 Evo X
Ash crap lol, well then looks like I hafta just uninstall the AP... Don't have the money for a tune... Would going to a lower map, like the 91 stage 1 map perhaps remedy this?
Offline
Old Mar 30, 2011, 05:41 AM   #8
Daily Activity: 0%
Perhaps yes, try it. Or just download ATR and amend the timing/boost map yourself.
Offline
Old Mar 30, 2011, 05:42 AM   #9
Drives: Evo 8
Points: 2,704, Level: 31
Points: 2,704, Level: 31 Points: 2,704, Level: 31 Points: 2,704, Level: 31
Daily Activity: 0%
Going to a lower octane map would probably increase your knock counts as the fuel is more prone to detnation.
__________________
Nothing :(
Offline
Old Mar 30, 2011, 05:43 AM   #10
Daily Activity: 0%
Quote:
Exact opposite - stay on the fuel and change map to 91 oct - it will decrease timing and target boost.
Offline
Old Mar 30, 2011, 05:50 AM   #11
Jookies's Avatar
Drives: 2010 Evo X
Yeah that's what I meant, how much power do you think i'll lose going to that map from the Stage 1 93 LWG?
Offline
Old Mar 30, 2011, 06:09 AM   #12
Jookies's Avatar
Drives: 2010 Evo X
i also usually get gas from a crappy no name place ( still 93, but not exxon or shell, etc) could the quality of the gas be a little worse from there?
Offline
Old Mar 30, 2011, 07:34 AM   #13
EvoM Moderator
Personal Sales Rating: (15)
fostytou's Avatar
Drives: '08 EBP Evo X, '04 FZ1, Former: '06 GG IX SE (88590715),35R Powered Eclipse GST, 6/4 TSi AWD, Bandit 600s
Points: 8,717, Level: 62
Points: 8,717, Level: 62 Points: 8,717, Level: 62 Points: 8,717, Level: 62
Send a message via AIM to fostytou
If you are really worried about it your best option (as said above) is to download ATR and reduce timing by 1* around that area. Going to another map may not solve your problem as it may have the same timing values. If the knock goes away then you can fine tune it so only the required cell is reduced... if it stays then its probably phantom and no big deal.
__________________
'08 OBP GSR W/ SSS - Corn Fed!
  • BBX-Lite, AMS Intake, AMS UICP/LICP, ETS FMIC, ETS O2 dump, Mil.Spec 100Cell Cat, Stealth cat-back, FIC 1100cc HiZ, Blaqops w/ Walboro 255, GM 3-Port BCS, Billet Al Gas Pedal
  • AEM UEGO, ProSport Boost Gauge, Passport 8500 x50 Hardwired, Auto-dimming mirror, OP2.0
RIP '06 GG IX SE Corn Fed 393hp/385tq (EvoM Comp VDR)
  • Full Bolt-on
  • Tephra V7, JDM MAP, Direct boost ctl w/ GM BCS
Offline
Old Mar 30, 2011, 07:40 AM   #14
Jookies's Avatar
Drives: 2010 Evo X
Interesting, how difficult is it to use ATR?
Offline
Old Mar 30, 2011, 07:54 AM   #15
Daily Activity: 0%
As easy as Excel
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
07, acceptable, accessport, cobb, counts, detect, evo, knock, kock, normal, range, retard, stage, tuning, worry
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
