Evo X Engine Management / Tuning ForumsDiscuss the major engine management systems.
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
ok noob here......I just got a cobb ap and fired up stage 2. Well I went into live logging and went into "knock retard" and I'm getting a reading up to 2.4 at low rpms, but I did a few WOT and got one reading up to 1.8 and seeing a few pulls over 1.1......how bad is this and what can I do to fix issue? What else should I be looking for in my cobb ap live data logging?
Ouch! Thats a lot of knock! 1.0=3 counts so yeah man knocking bad. Do you have a WB installed? and have ATR?
__________________
08 Evo SSS/WW Tsudo Cat-Back Exhaust (no cat)
ETS intake, ETS DP Open dump Ecuflash, Evoscan, Self tuned it now for my X (Thanks to the help of people on this forum) LC-1 Wideband, UR UICP,LICP and Garrett 4.5 IC, Perrin 3 Port, Forge WG, Forge BOV
(on the way), 20% tent and Rally Armor flaps all installs done by me and tuned by me.
78 Corvette 406sbc 175 shot.
no wb or atr, I need to get that stuff soon. I thought I could run stage 2 with no big issues. Dang, well what can I do to make knock go away? I got 50/50 mix of 100 octane and 91 and that didn't seem to help much. I guess I'll go back to stage 1
?? Cobbs number?? I called them and some guy on the phone didn't know anything and told me to go get it tuned.....lol that why I got the ap....but I guess you still have to pay for a tune, should of skipped this ap and just got a tune, what good is it tohave if you got to get TUNED still.....I can't believe this, is anyone else having lots of knock retard using ap stage 2 and if so WTF did you do to make it stp
Switch to the AZ 91 octane stage 2 map. If that still doesn't work.. sorry to say but it's either use Stage 1 91 and fall back to stage 1 AZ 91, or get a pro tune.
Well if you don't know what your AFRs are I would check Fuel pump relay. Might be going bad. Could be to lean, bad gas, timing all kind of stuff. But I would change your fuel pump relay with headlight think it is and re-log. Find thread on here or look in your manual and see what one is the FP relay.
Also what year?
__________________
If its all time yes! If its sometimes there and sometimes not then no.
__________________
But if its at same rpm area and starts to knock .35 or whatever there is a problem in that area with timing or whatever. Lets say everytime you do a pull in 3rd or 4th and at 4500rpm you start seeing knock everytime there is a problem. Now if you do 3-4 pulls and 1 pull out of them there is knock at that rpm area your fine.
__________________
