cobb ap knock retard ?
Old Feb 18, 2010, 08:35 PM
Whitewind's Avatar
Originally Posted by Golden
Cobb says that 1.05 and less is normal as long as its random. Some say its almost impossible to tune them all out.
Yep
Old Mar 9, 2010, 12:56 PM
RU EVO's Avatar
Is the knock count supposed to be for just one redline pull to measure a lot of knock ? For the past two weeks I have been noticing daily driving total knock around 4.6x this would be for the total drive to work or whereever not just one pull. I started getting knock past 2 when I changed to the blue fuel pump relay so I hope that is not causing an issue.
Old Mar 9, 2010, 02:07 PM
xhomm02's Avatar
This is my log, each pull at 4th gear is simillar. Is that necessary to tune the knock out?
I am running Stage 2 car Stage 2-93 Cobb map(a bit modified at low load)
Thanks,
Martin.
File Type: zip
Old Mar 9, 2010, 07:33 PM
Golden's Avatar
Cobb Knock Retard / .35 = Knock count
So .7 = 2 counts and .35 = 1 count
You should be fine, the 1's and 2's are almost impossible to tune out.
Here is his log for the lazy:
Code:
RPM 	IPW	LTFT	STFT	Knock	TP	Boost	Load
3330	11.52	3.12	0	0	34.43	11.31	150.94
2632	11.01	3.12	0	0	86.86	10.88	154.38
2753	12.8	3.12	0	0	86.86	15.23	179.38
2878	16.13	3.12	0	0	86.86	20.09	211.25
3041	18.94	3.12	0	0.7	86.47	22.99	214.06
3242	18.43	3.12	0	0.7	86.47	24.15	226.25
3453	19.2	3.12	0	0.35	86.86	24	225
3635	19.2	3.12	0	0.35	86.86	24.37	232.5
3848	19.97	3.12	0	0	86.47	24.95	238.75
4023	20.74	3.12	0	0.35	86.86	25.16	246.56
4247	21.5	3.12	0	0	86.86	25.74	250.62
4445	21.5	3.12	0	0	86.47	25.31	241.88
4632	20.48	3.12	0	0	86.47	24.58	236.88
4826	19.97	3.12	0	0	86.47	24	233.44
4979	19.97	3.12	0	0	86.47	24	230.31
5137	19.71	3.12	0	0	86.47	24	227.19
5304	19.46	3.12	0	0	86.47	23.79	223.75
5466	19.2	3.12	0	0	86.47	23.57	221.56
5618	18.94	3.12	0	0.35	86.47	23.57	219.38
5760	18.94	3.12	0	0.35	86.47	23.42	216.88
5891	18.69	3.12	0	0	86.47	22.84	215.94
6028	18.69	3.12	0	0	86.47	22.63	214.69
6162	18.43	3.12	0	0	86.47	22.04	210
6334	17.92	3.12	0	0	86.47	21.61	207.19
6426	17.66	3.12	0	0	86.47	21.25	204.38
6493	17.66	3.12	0	0	86.47	21.03	202.5
6590	17.41	3.12	0	0	86.47	20.88	200.31
6690	17.15	3.12	0	0	86.47	20.45	196.25
Old Mar 10, 2010, 08:48 AM
ikt
ikt's Avatar
cobb also released a new map for stage one and stage two for overboosting issues in some cars
Old Mar 12, 2010, 01:23 PM
COBB Tuning's Avatar
Some knock correction at WOT is ok, however, it isn't ideal. If you are seeing more and more knock correction, you might check your fuel pump relay as these do go bad and fuel delivery becomes more and more of an issue. That said, knock correction at low-load, low rpm and cruising is nothing to be concerned about. The engine will try to run as close to stoich/MBT as possible for best economy. We have noted this behaviour across all ranges of vehicles. Keep in mind that the knock sensor is an imperfect microphone that listens for noise, this noise is then processed by the ECU which looks for a specific pattern which is then interpolated as "knock." Very low knock readings may or may not be knock. Very high readings are something to be worried about.
Travis
COBB Tuning
Old Mar 14, 2010, 12:26 AM
Rands's Avatar
Travis
COBB Tuning
What amount of knock correction is okay under WOT? I did a couple pulls today and I saw my knock retard count go as high as 2.46. Number is a bit high, but only happened once outta 2 pulls.
Also on another note, I'm looking at xhomm02's log, how do you get the AP to sample so frequently? I'm looking at my logs and it seems to log a sample every half a second. Do you just not log as many items?
Old Mar 14, 2010, 01:45 AM
xhomm02's Avatar
The less items you log, the higher fequency you achieve. In the log above the listed items are the only ones I logged.
2.46 knock retard is pretty high as I understand from what I have read so far. Can you post the log?
Old Mar 14, 2010, 10:51 AM
Rands's Avatar
Yeah that's what I kinda thought, I had a lot of stuff being logged before, and I reduced the list a bit, but didn't seem to change the frequency. I'll take out some more things from the list next time I do any logging.
And as for logs here it is. I just did 2, 3 gear pulls (1'st, 2'nd, 3'rd). The first time I did there was 1 count of measured knock retard that was at 1.41, which isn't too too bad. But the second time I did it, there was a recorded count of 2.41, and 2.11. I noticed the LTFTs stayed at 0% throughout the data log. I thought that it would go up a few percent to prevent the car from leaning out.
Old Mar 14, 2010, 02:15 PM
xhomm02's Avatar
Try to do some 4th gear puls, the lower 3 gears are too fast to sse anything ih the log.
Also decrease logged items to about 5, then the freq. will increase. LTFT does not prevent from knock, it tries to keep the AFR as close as possible to the values set in the tables (in case of air filter dirty or things like that).
Old Mar 15, 2010, 12:09 PM
Rands's Avatar
Yeah I'll try to do a 4'th gear pull and log that. But the cops are out on full force since it's kinda warm out here, so I'm kinda scared of getting pinched haha. I know of a street where I can probably do a 3'rd gear pull safely, so I might have to just work with that.
Old Mar 15, 2010, 03:42 PM
Please do your logs in a safe an controlled environment! If you are running the Harman intake, that could be part of the problem if you are using a calibration not made for that intake. These cars are very sensitive to changes in the intake. That said, I would take a look at your fuel pump relay and then think about a tune for your intake. I hate to tell you again to just get a tune, but it really is the best way to go for intakes that we don't have calibrations for. We are not currently working on further intake calibrations, however, that does not mean there won't be more in the future.
Travis
COBB Tuning
Old Mar 15, 2010, 04:26 PM
Rands's Avatar
^^ Haha I know I know I totally understand! I'm thinking of getting a tune in about 2 months or so, just gonna use one of the OTS maps as a temporary solution before my tune. Just hoping that the OTS maps is safe enough for my car if I'm not ripping on my car... much.
evo10fanatic33
Dec 14, 2014 04:58 AM
GsrJake
Cobb AccessPORT
13
Apr 7, 2013 12:24 PM
o0oz
Dec 15, 2011 07:23 AM
robyn402
Aug 13, 2010 07:07 AM
Quick Reply: cobb ap knock retard ?
