Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
New! Use your Facebook to securely log into this site, click logo to login
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 31, 2010, 12:29 PM   #1
Personal Sales Rating: (3)
Drives: 2010 Evo X GSR
Arrow E85 conversion question/help
This is what I want.
E85 conversion kit that is pretty much drop in and includes 1000cc injectors.
Best brand for that as far as quality and price goes?
Thanks
Offline
Old Jan 31, 2010, 12:52 PM   #2
Personal Sales Rating: (0)
yorT's Avatar
Drives: Evo X
Do you need a conversion kit or can you just change your fuel maps on your ECU? Your stoich AFR is going to change so it should be a matter of changing timing and AFR right?
Offline
Old Jan 31, 2010, 01:49 PM   #3
I just got the Cobb AP and want to run e85 map on my car. I know I need a fuel pump and injectors, but was just looking for a kit that would basically drop in. Obviously the injectors will but the fuel pump, do you get what I mean?
Offline
Old Feb 2, 2010, 01:32 PM   #4
yorT's Avatar
Drives: Evo X
Well as far as "drop in" don't think so. I'm guessing you want to do this yourself?
Offline
Old Feb 2, 2010, 02:19 PM   #5
Yes sir. I have the skills to do it, just don't know if i want to. haha. If i can get it installed for fairly cheap by a local shop, i.e. cobb, then i'll probally do that.
Offline
Old Feb 2, 2010, 02:27 PM   #6
Whitewind's Avatar
Drives: Evo x
When I move this year to KY im going E85. Be station right up the road.
__________________
08 Evo SSS/WW Tsudo Cat-Back Exhaust (no cat)
ETS intake, ETS DP Open dump Ecuflash, Evoscan, Self tuned it now for my X (Thanks to the help of people on this forum) LC-1 Wideband, UR UICP,LICP and Garrett 4.5 IC, Perrin 3 Port, Forge WG, Forge BOV
(on the way), 20% tent and Rally Armor flaps all installs done by me and tuned by me.
78 Corvette 406sbc 175 shot.
Offline
Old Feb 2, 2010, 06:02 PM   #7
Cool! I have one station in town. So it would be e85 on weekends and 91 or 93 during the week!
Offline
Old Feb 2, 2010, 07:28 PM   #8
emilebazin's Avatar
Drives: Mitsubishi Lancer Evolution X
It is not a cheap install. You have know what you doing. If it goes boom. know what I mean.
Offline
Old Feb 3, 2010, 07:33 AM   #9
Personal Sales Rating: (12)
Drives: AS EVO X MR
Search for GoofyGrin's e85 FAQ post...
__________________
Are you in the North Texas area? Check out NTEC!
Offline
Old Feb 3, 2010, 08:41 AM   #10
Personal Sales Rating: (1)
mlomker's Avatar
Quote:
You could save a couple bucks installing the pump & filter on your own (I'd suggest the BlaqOPs kits). Then have Cobb install the injectors and do your custom tune.
__________________
08 GSR / Mods
410hp/327tq (Dyno Dynamics 1.0cf)
Offline
Old Feb 3, 2010, 09:15 AM   #11
Personal Sales Rating: (2)
chriswolf81's Avatar
Drives: PB Evo X
Easier said than done. You cannot just switch fuel and map and be good to go WOT. It may take several tanks until the switch has been made.
E-85 summer and 91/93 winter is a good idea, but changing fuels every other day or so, does not seem like a good idea.
__________________
PB Evo X SSS
-UR TB Exhaust w/O2 DP (resonator)
-ETS 4"FMIC and UICP
-Harman Motive Intake (AEM filter)
-AMS underhood bushings
-Works Shifter and Works base bushings, Blox knob
-Zeitronix zt-2 Wideband and Boost Sensor
- GM 3-port
- Swift springs, Whiteline RCA and Perring R.Swaybar
Ecuflash by Camtuning
Offline
Old Feb 3, 2010, 01:30 PM   #12
yorT's Avatar
Drives: Evo X
^^ Yeah unless you completely drain the gas tank, you are going to have mixing of the E85 and 91/93 OCT.
Offline
Old Feb 3, 2010, 01:43 PM   #13
Personal Sales Rating: (466)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
Best bet is to get rid of the AP and use reflash instead.
Offline
Old Feb 3, 2010, 01:56 PM   #14
Drives: AS EVO X MR
Evo X E85 Conversion How To & Discussion
Since you already have the AP, their OTS e85 maps seem to be pretty good, while keeping the tune safe... I'm planning on headed that direction, too, though I'd like to go with 1000cc injectors to give the vehicle a bit more headroom.
__________________
Offline
Old Feb 3, 2010, 05:42 PM   #15
Personal Sales Rating: (6)
murlo26's Avatar
Drives: 08 RR X GSR
Send a message via AIM to murlo26
Please don't switch all the time, like people said it takes a few gas tanks to fully get rid of the 91/93.
This is why if people who convert to e85 go get retuned after a month make another 20whp, the system is then fully e85.
Personally I am an all or nothing, no switching all the time, once a year maybe, but personally if you go e85 you will never look back.
__________________
Old Numbers: 420whp/390wtq 1.0CF DD = Hole in block.
New numbers w/built motor:
???whp/???wtq
Still FP powered, 500+whp on 1.0DD or bust!
Offline
Tags
85, buschur, cobb, conversion, convert, converter, e85, evo, evolution, forum, injecotrs, installing, kit, lancer, racing, stoich
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
