Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Sign in using an external account
Register Forgot Password?
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Dec 3, 2009, 03:38 PM   #1
Personal Sales Rating: (0)
Garage is empty, add now
Drives: 2008 Phantom Black EVO X GSR, 07 Yamaha R1
Points: 4,926, Level: 44
Points: 4,926, Level: 44 Points: 4,926, Level: 44 Points: 4,926, Level: 44
Daily Activity: 2.9%
Daily Activity: 2.9% Daily Activity: 2.9% Daily Activity: 2.9%
Send a message via AIM to Evo4Emperor
Vacuum leak after install AEM intake
hey guys.. so here is the deal... I got my AEM intake.. put it on...then had some difficulties...
the biggest problem i have is that im pretty sure i have a vacuum leak. Upon starting up the car.. my idle sounds like a heartbeat..(bump,bump,bump) it almost sounds like it would die (lights dim as rpm drops to 250 and then pumps back to normal) and when i slow down to a stop i put the clutch in and the RPM's randomly go up and the engine revs?? There is a noise similar to a can compressed air, this noise is consistently on if the car is on.
the pic below is where i believe the vacuum leak is
also after installation.. i was left with this piece that i never put on??? what is it.. could this lead to the problem?
lastly... with my problems that i said.. is it safe to assume that it is a vacuum leak?
any help is needed...thanks!
__________________
- 08 Evo X GSR SSS: AMS o2 housing/downpipe, AMS Single-Exit Cat-back, AMS hi-flo cat, AEM intake. Tuned by HBspeed: 340whp @ 345 lb/ft
- 07 Yamaha YZF-R1: SOLD
Online
Old Dec 3, 2009, 05:06 PM   #2
Japistani's Avatar
Drives: 2008 Mitsubishi Evolution X MR Premium (Phantom Black)
Points: 2,744, Level: 31
Points: 2,744, Level: 31 Points: 2,744, Level: 31 Points: 2,744, Level: 31
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
If I'm not mistaken, that's the piece that goes on the inside of the airbox, that ensures a tight fit between the inlet pipe and the airbox... I would think that is where the "vacuum leak" is coming from...
Try putting that in and see...
__________________
Modifications:
ECU: Cobb Accessport Stage II (AEM 93 Octane)
Intake: AEM Cold Air Intake
Intercooler: Ultimate Racing FMIC w/ Polished UICP & LICP
Brakes: Girodisc Slotted 2pc Rotors w/ Braided Lines & Hawk Performance Pads
Exhaust: Ultimate Racing Dual Exit TBE w/ HFC
Tax Reduction: Escort Passport 9500ix (Hardwired)
Exterior: 3M 20% Tint (Rear Window/Doors)
Offline
Old Dec 3, 2009, 05:11 PM   #3
Personal Sales Rating: (1)
Golden's Avatar
Drives: 2010 Evo GSR Black
Points: 2,316, Level: 29
Points: 2,316, Level: 29 Points: 2,316, Level: 29 Points: 2,316, Level: 29
Daily Activity: 4.5%
Daily Activity: 4.5% Daily Activity: 4.5% Daily Activity: 4.5%
That piece is the seal that goes on the inside of the round hole on the back side of the box. Its just needed to keep warm air out of the box.
I'd bet that your issue is that 10" hose that the gave you to go from the bop valve to the engine(the one you are pointing at in the first pic). It's too big. I had to leave mine off and use the original one. I'm going to stop by the store tomorrow and get a proper size and length one.
I just installed mine earlier today, btw.
__________________
2010 Evolution X GSR Phantom Black
Info - Mods - Installs - and More in Golden's Thread
FP Red - E-85 - Self Tuned
Corn Fed
Need a Definition for the X? Golden's Definition Database
Offline
Old Dec 3, 2009, 05:14 PM   #4
Golden's Avatar
The seal is installed on step 3.c in your instructions.
__________________
Corn Fed
Offline
Old Dec 3, 2009, 07:16 PM   #5
thanks so much for the replies! ok.. yeah the extra piece when they said edge trim i used the styrofoam from the stock intake box(i thought that was the edge trim)...
and i guess i have to use the old piece... where would i be able to go to get a tubing like that? just go to home depot and ask for a rubber tube?
thanks again guys!
__________________
Online
Old Dec 3, 2009, 08:02 PM   #6
Golden's Avatar
I'm going to check an automotive store for vacuum lines.
What sucks is that I will probably have to bring my pliers and take it off at the store to make sure I get the right size.
__________________
Corn Fed
Offline
Old Dec 3, 2009, 10:20 PM   #7
Personal Sales Rating: (3)
tonyboy's Avatar
Drives: 2010 WW Evolution X
Points: 3,352, Level: 36
Points: 3,352, Level: 36 Points: 3,352, Level: 36 Points: 3,352, Level: 36
Daily Activity: 0.5%
Daily Activity: 0.5% Daily Activity: 0.5% Daily Activity: 0.5%
if your idle goes up and down almost dying, i'm assuming there is a vacuum leak before the maf...or the maf has a leak/or not properly installed...
Offline
Old Dec 4, 2009, 06:40 AM   #8
Personal Sales Rating: (7)
Drives: RR 08 EVO X
Points: 2,165, Level: 28
Points: 2,165, Level: 28 Points: 2,165, Level: 28 Points: 2,165, Level: 28
Daily Activity: 2.4%
Daily Activity: 2.4% Daily Activity: 2.4% Daily Activity: 2.4%
Yeah keep us posted, I'll be doing the install soon and it will be good to hear how you resolved it...
Offline
Old Dec 4, 2009, 12:36 PM   #9
Golden's Avatar
I just got a new BPV vacuum tube today. The one include in the kit is definitely the wrong size for my '10 X. (It may be correct for an '08)
__________________
Corn Fed
Offline
Old Dec 4, 2009, 01:12 PM   #10
Personal Sales Rating: (9)
Drives: 2008 Evo, 1987 turbo Golf, 1984 Rabbit GTI
Points: 964, Level: 16
Points: 964, Level: 16 Points: 964, Level: 16 Points: 964, Level: 16
Daily Activity: 1.0%
Daily Activity: 1.0% Daily Activity: 1.0% Daily Activity: 1.0%
for future reference... wrong forum
__________________
Nothing's for certain, it could always go wrong.
Come in when it's raining, go on out when it's gone.
Have a SST-equipped Evo? Want to trade it for a 5-speed? CONTACT ME! (-:
Offline
Old Dec 4, 2009, 05:07 PM   #11
Quote:
yep.. the tube they gave me was DEFINATELY tooo big... as soon as i put the stock vacuum line on the car sounded normal again!... the stock line fits...so you can get away with it...i plan on eventually getting a tube with the right size as the stock line is a tad bit short...
__________________
Online
Old Dec 4, 2009, 08:20 PM   #12
tonyboy's Avatar
^^ i agree...i installed my aem intake too with my '10 evo x too...i bought another hose for the bov...the oem is a bit too short, and the one provided by aem is too big...
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
aem, cobb, edge, evo, evox, gsr, hoses, idle, install, intake, leak, lines, passport, trim, vaccuum, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
