Evoscan Navigator in Evo X? Yes please !!!
Oh and I've been talking to Hamish about adding in a peak hold feature that will display the peak numbers right next to the name of the data that is being logged. With this feature, you should be able to just glance at your screen to confirm your last run didn't have any knock or your boost didn't jump too high without having to eyeball the gauge during the entire run. You'll be able to clear the peaks whenever you want to by touching the clear peak function.
