Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 6, 2009, 09:13 AM   #1
Personal Sales Rating: (2)
Yousef's Avatar
Drives: 2009 GG SST Evo X & 2006 Cadillac STS V8
Help P0107
P0107 BARO sensor circuit out of range low
500 meters away from home the evo suddenly got into limp mode and shutdown with steering lock
off-on many times code is gone and car is normal, drove her home and shes parked since then!!!!!
what the hell does that mean??? what is BARO??
I had nothing but problems with this car !!!!!!!!! i am so mad
__________________
2009 GG SST Evolution X
>HKS Legamax Exhaust
>HKS Center Pipe
>Agency Power Cat Delete
>HKS EVC 6
>AMS UICP
>HKS Drop In Filter
>Custom Tune
>Eibach Pro Kit
>Advan RS-D 19x10 +25
>BlackTop Exhaust Heat Shield
>Rexpeed R-Style Ducts
>Rexpeed Trunk Spoiler
>Rexpeed R-Style Splitter
>Rexpeed Type-1 Hood Scoop
>Rexpeed Twin Bonnet Vent
>MOMO Team 300mm Steering Wheel
>Works Bell Hub
>MOMO Race Knob w/rev.
Offline
Old Nov 6, 2009, 09:59 AM   #2
Personal Sales Rating: (5)
Clipse3GT's Avatar
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Send a message via AIM to Clipse3GT
Probably a vacuum leak or boost leak.
I suggest you check the FPR vacuum line to see if it didn't pop off.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Old Nov 6, 2009, 10:08 AM   #3
Clipse3GT's Avatar
Brain storm...
Abu dhabi is almost at sea level maybe a bit above or below sea level.
The sensor reads 0-1800 meters. If you go below 0 or below sea level for over 2 min you might throw the code.
I say reset your ECU and check the FPR line.
Go and drive and see if you can repeat the condition.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Nov 6, 2009, 11:48 AM   #4
Yousef's Avatar
where is the FPR vacuum line?
thanx
__________________
>HKS Legamax Exhaust
>HKS Center Pipe
>HKS EVC 6
>AMS UICP
>HKS Drop In Filter
>Custom Tune
>Eibach Pro Kit
>Works Bell Hub
Offline
Old Nov 6, 2009, 12:27 PM   #5
Personal Sales Rating: (0)
Drives: 2008 RR Evo X
Quote:
thanx
it's the one that pops off the intake manifold. it right near the oil dipstick.
Offline
Old Nov 6, 2009, 01:02 PM   #6
Yousef's Avatar
checked all visible vacuum lines
took her for a hard short test drive, all good !!!!!!
this car is driving me crazy
I have a 350 miles trip next week :s
__________________
>HKS Legamax Exhaust
>HKS Center Pipe
>HKS EVC 6
>AMS UICP
>HKS Drop In Filter
>Custom Tune
>Eibach Pro Kit
>Works Bell Hub
Offline
Old Nov 6, 2009, 03:48 PM   #7
P107 deals with the MAP sensor....sounds like just a fluke code
http://www.obd-codes.com/p0107
Offline
Old Nov 6, 2009, 05:48 PM   #8
Clipse3GT's Avatar
Bet you it went of becaue you are so close to sea level, which is 0. Baro went for a wacky reading.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Nov 6, 2009, 06:30 PM   #9
2008 Mitsubishi Lancer Evolution
My Garage
stikllr13's Avatar
Drives: Evo X
^^ I dont know about that. Several areas in the united states and other places are below sea level. The MAP sensor doesn't necessarily read altitude. It measures the BAROmetric pressure of the atmosphere to determine the density of the air. My guess to the OP's problem is that he might have a intermittent vacuum leak near the MAP sensor.
But since this only happened once and you can't repeat the problem then it could be a weak connection at a connector or high resistance in the circuit.
Let us know what you find, I suggest you take it to a shop and try to have this diagnosed
__________________
Mods:
Cobb: SF Intake, Springs, R/Sway Bar, AP, Turbo Inlet
Artisan: Cat-back exhaust
Works: Short Shift
AMS: Under Hood Shifter Bushings
Titek: CF Hood Scoop
Rexpeed: CF Front Lip, CF Bumper Cover, CF Side Spats
Auto Meter: Boost Gauge w/ CF pod
3M: 5% Tint
Endless: NS97 Front Pads
Rotora: Brake Lines
Ralliart: Tails
Rota: 18X9.5 Yamaha Black Rota Grids
325Whp 323Wtq on Mustang Dyno
Stage 3 coming this Summer
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
