Nov 6, 2009, 07:04 AM
Personal Sales Rating: ( 10)
Drives: Apex Silver X SSS
Help, Cobb Stage 2 breaking up at high RPM
I'm running Cobb HKS 93 oct stage 2 map. My mods are just a panel filter, UICP, pulled the pill (I tried putting it back in because I was slightly overboosting, but I had the same results.) and AP.
I'm getting a lot of breakup that starts at about 5500rpm at WOT. I'm thinking plugs are possibly getting weak, but I just don't know. I'm also getting tons of black smoke during the breakup, so I don't know if it is from overfueling or misfire.
Any help would be great. Thanks.
Offline
Nov 6, 2009, 07:10 AM
Personal Sales Rating: ( 13)
Drives: 2006 Evolution IX, 2006 Range Rover Sport SC
probably going super rich and turning off the spark. Pull out the plugs and check the way they look see if it's all black.
Online
Nov 6, 2009, 07:20 AM
Quote:
That's what I was thinking, but I'm somewhat of a rookie when it comes to this stuff. I'll try to do that in the morning. Thanks!
Offline
Nov 6, 2009, 11:18 AM
Personal Sales Rating: ( 2)
Drives: 08 Evo X GSR Apex Silver Metallic SSS - NAVI
Are you running a turboback exhaust as per the instructions for a stage 2 map?
__________________
SSS - NAVI
Offline
Nov 6, 2009, 11:26 AM
Personal Sales Rating: ( 0)
Drives: 2004 BMW M3 2008 LANCER EVO X 2008 FORD FUSION 2008 TOYOTA LAND CRUISER
Quote:
Originally Posted by cool_g_83
are you running a turboback exhaust as per the instructions for a stage 2 map?
+2
Offline
Nov 6, 2009, 06:52 PM
Personal Sales Rating: ( 11)
Drives: AS EVO X MR
Yeah, looks as if you should have read the stage II requirements a little more closely... Put the pill back in, and reflash to HKS Stage I.
__________________
Are you in the North Texas area? Check out NTEC!
Offline
Nov 7, 2009, 12:12 AM
Personal Sales Rating: ( 5)
Drives: Wicked White Evo X
A minimum of a catback + test pipe is required for a stage 2. You don't necessarily need a DP upgrade as the stock one already flows very well.
Offline
Nov 7, 2009, 06:15 AM
For all that don't know, Stage 2 does not require the exhaust system(per Hollywood).
I have read the instructions and am fully aware of what cobb states is required.
It has been verified by several other people and tuners that the stage 2 is safer without the exhaust and not absolutly needed.
Offline
Nov 7, 2009, 07:46 AM
Well, some people are obviously having problems running a stage II map on a stage I equipped car. So maybe there is something to COBB's recommendation...
Offline
Nov 7, 2009, 07:50 AM
Quote:
lol Maybe.  Do you have any history with the AP?
Offline
Nov 7, 2009, 09:35 AM
Drives: Evo X GSR
Why don't you call Cobb directly? There has to be a reason they have a stage 1 versus stage 2 map right? It "might" be ok for "some" cars to run stage 2 without an exhaust, but I would guess that in general, it's safer and better to run the stage 1 map. Try stage 1 and see how it runs.
Offline
Nov 7, 2009, 10:12 AM
Quote:
Getting ready to flash stage 1 here in a few.
Offline
Nov 7, 2009, 10:59 AM
Personal Sales Rating: ( 1)
Drives: WW Evo X
Stage 1 - Intended for an otherwise stock 2008 Mitsubishi EVO X GSR vehicle with a stock or cat-back exhaust
Stage 2 - Intended for an otherwise stock 2008 Mitsubishi EVO GSR vehicle with full turbo back exhaust system
Which part of “full turbo back” don’t you understand?
Offline
Nov 7, 2009, 11:55 AM
Edited.
I am very aware of what cobb claims that you need to run stage 2.
This is the type of response i was looking for.
Originally Posted by hollywood_X
Also when running stage 2 without the "Requested" modifications that Cobb lists you wont get the full benefits from the tune.
You gave a lot of down low grunt but in the upper rpm's at higher gears the exhaust backpressure will start effecting you.
Getting a good cat back will solve the power loss and studder that you are experiencing.
Offline
Nov 7, 2009, 12:20 PM
Drives: '08 RR EVO X GSR
mine does it with just stage 1 it doesn't have anything to do with stages or turbo-back / stock. It must just still be getting far to much fuel up top... wish I could get rid of this so I can haul ass all the way to redline!!!
__________________
EXTERIOR:
Matte black roof
Wingless
Blacked out front emblem
Debadged rear
Stealth front blinker bulbs
Smoked sidemarkers
Niteshade tail lights and third brake
LED mini corner lights
INTERIOR:
Custom red suede shiftboot
tazo knob
Custom red suede door cards
Prosport boost guage on a-pillar
Valentine One
PERFORMANCE:
COBB AP stage 1
Perrin Inlet tube w/ K&N cone
T1R Intercooler pipe kit *PINKISH*
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
