Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 7, 2009, 12:30 PM   #16
Personal Sales Rating: (10)
Ruff Ryda's Avatar
Drives: Apex Silver X SSS
Quote:
Originally Posted by EVOXMAINE View Post
mine does it with just stage 1 it doesn't have anything to do with stages or turbo-back / stock. It must just still be getting far to much fuel up top... wish I could get rid of this so I can haul ass all the way to redline!!!
Same here!!
__________________
You have to grow up sometime. Hello X!
You Know You're Grown Up When.. You hear your favorite song in an elevator.
http://forums.evolutionm.net/sale-wa...ml#post7177756
Offline
Old Nov 7, 2009, 12:33 PM   #17
Personal Sales Rating: (0)
Quote:
Originally Posted by Ruff Ryda View Post
Do you have any history with the AP?
Im bone stock flashed with stg 1 91 running on california pisstane. So far so good, pulls straight to redline with no hesitation in any gear in 110 degree central valley heat.
Offline
Old Nov 7, 2009, 12:39 PM   #18
Put the stock intake and filter back in. Cobb noted that the current gen EVO's are very sensitive to intake changes. They developed separate maps for different intake configs.
Cobb has stated in the past that something as simple as a drop in filter caused a change of 0.5 AFR. This is pretty significant.
Diffrent diameter MAF housings and intake tubing throw the AFR so far off that it actually becomes unsafe to run a non specific OTS map.
Offline
Old Nov 7, 2009, 12:43 PM   #19
Ruff Ryda's Avatar
I'm running the HKS panel filter map.
__________________
Offline
Old Nov 7, 2009, 12:52 PM   #20
Ya, i was referring to EVOXMAINE's problem. If the sig is correct he's running a custom intake setup.
Offline
Old Nov 8, 2009, 07:33 AM   #21
EVOXMAINE's Avatar
Drives: '08 RR EVO X GSR
Have perrin inlet and a cone. This helped my problem. before when I was stock this problem was bad. I put an intake in because someone had said it helped and it did. seems as though an intake would lean, and I need as much of that as I can. I use the cobb map for use with sf intake. That intake is basically just a filter. Just explain if I am wrong!!! I would love to get this problem solved.
__________________
EXTERIOR:
Matte black roof
Wingless
Blacked out front emblem
Debadged rear
Stealth front blinker bulbs
Smoked sidemarkers
Niteshade tail lights and third brake
LED mini corner lights
INTERIOR:
Custom red suede shiftboot
tazo knob
Custom red suede door cards
Prosport boost guage on a-pillar
Valentine One
PERFORMANCE:
COBB AP stage 1
Perrin Inlet tube w/ K&N cone
T1R Intercooler pipe kit *PINKISH*
Online
Old Nov 8, 2009, 09:00 AM   #22
Personal Sales Rating: (11)
Drives: AS EVO X MR
OP-
you're being a bit less than helpful with others here trying to give you some assistance. Let's take it from the top and see if you can fill in the blanks...
Original issue- running AP stage II map (which one?) with panel filter (which brand and type?), UICP, and removed boost pill. Experiencing breakup around 5500 rpm.
Troubleshooting 1- put boost pill back in. Same issue. (same map?)
Troubleshooting 2- you were requested to put the pill back in, and reflash to Stage I with HKS filter. Did you do this? What were the results? Did you log?
Troubleshooting 3- replace aftermarket filter with stock. Probably a good idea when you are doing this to clean the MAF as some filters will foul the sensor and cause issues. Intake sensitivity is well documented on this vehicle.
A few other things- you don't mention what kind or octane fuel you are running. If you are running a 93 octane map, you should also try the above steps with the 91 octane map to ensure it is not and issue with the fuel itself.
I'm interested in your statement that many tuners (Hollywood) have verified that the stage ii map is safer (safe at all?) on a car with a stock exhaust. Would you mind pointing out a few threads where this has been demonstrated?
__________________
Are you in the North Texas area? Check out NTEC!
Offline
Old Nov 8, 2009, 10:08 AM   #23
Ruff Ryda's Avatar
Quote:
Originally Posted by mrMTB View Post
OP-
I'll start by telling you that just telling me the same thing that is stated on cobb website 5 times in a row is not what I call helping.
I am running BP 93 oct fuel. I have done all the steps that you stated above with similar results. I just installed Cobb ATR this morning and will be doing some logging with that later today.
__________________
Offline
Old Nov 9, 2009, 08:00 AM   #24
EVOXMAINE's Avatar
I just tried stg2 and it didn't pull as good as stg1... seemed pretty doggish. hoping that changes when I get the turboback. Also I took the possitive off the battery and held the brake to the floor for a while to reset everything. I then flashed back to stg1 and it seems to haul right now. I think that even with the AP the ecu learns to richen itself.
__________________
EXTERIOR:
Matte black roof
Wingless
Debadged rear
Smoked sidemarkers
INTERIOR:
tazo knob
Valentine One
PERFORMANCE:
COBB AP stage 1
Online
Old Nov 9, 2009, 08:20 AM   #25
Ruff Ryda's Avatar
I did some logging yesterday. My car seamed to be running ok but still the slight breakup. My car ran stage 2 fine at first but after the ecu made it's changes through learning it became a lil too rich up top.
All in all my car runs good, it's just a little embarrasing when you go WOT and cars start crashing behind me because they can no longer see because the black smoke.
__________________
Offline
Old Nov 9, 2009, 10:08 AM   #26
Drives: AS EVO X MR
Would you mind posting the logs? What map were you running, and what was the state of your hardware modifications at that time (boost pill, filter, etc)?
__________________
Offline
Old Nov 9, 2009, 10:49 AM   #27
Ruff Ryda's Avatar
Sure will. I'm at work right now, I'll try to post them later tonight.
__________________
Offline
Old Nov 9, 2009, 05:39 PM   #28
Ruff Ryda's Avatar
Here is a AP log that I ran yesterday morning. My ATR logs are a screwed up.
__________________
Offline
Old Nov 9, 2009, 08:30 PM   #29
Drives: AS EVO X MR
Hmm, you're overboosting @9.65, and it appears that the ECU is hiccuping for a second as it tries to get it back under control (this is happening around the 5500 RPM you mention previously). Your load cells move 174 > 238 (spike) > 192 (recover) > 210 (1.3 sec following spike) > 206 > 191.
Have you tried running the Stage II + HKS map? Cobb recommends the HKS intake maps for people who have issues running the regular stage maps with a panel filter. Yes, it'll enrich the fueling in those transition and spool areas, but this might be just what the system needs to keep the spike under control.
__________________
Offline
Old Nov 9, 2009, 08:36 PM   #30
Ruff Ryda's Avatar
Yeah, that is what I am currently running, and was running during this log.
__________________
Offline
Tags
cobb, evo, flash, high, kit, rpm, running, songs, stage, stock
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
