Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 5, 2009, 07:51 AM   #1
Personal Sales Rating: (10)
Fourdoor's Avatar
Drives: 2010 Ralliart Sportback.
Re-scalling maps
Hey guys,
I am getting ready to re-scale some of my maps in ECUflash for my 2010 Ralliart, and I got to wondering...
The timing maps are much larger than the fuel maps. It is my understanding that the reason for this is that in the actual XML file, the address for the RPM scale is different.
What would happen if you altered the XML file for the Fuel map RPM address to match the RPM scale address from the timing map?
I'm not gonna be a guinea pig on this, just asking if any crazy person out there has tried something like that to get an expanded fuel map, if it worked, if their ECU burst into flames and Satan laughed in the distance, or Angles sing and they have expanded fuel tuning maps... what happens?
Thanks,
Keith
__________________
2010 Lancer Ralliart Sportback... From stock to modified as follows in less than a week!
Buschur Racing FMIC, upper IC pipe, and lower IC pipe with EVO X BOV. AMS cat back exhaust, mini battery kit, and MAF housing from EVO X,Buschur Air filter mounted to EVO X MAF housing. Forge WG actuator, Ultimate Racing high flow cat.
Triple gauge pod with Wide band A/F ratio and boost.
Offline
Old Nov 5, 2009, 09:43 AM   #2
Personal Sales Rating: (5)
Clipse3GT's Avatar
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Send a message via AIM to Clipse3GT
Best person to ask this will be Tephra by far.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Old Nov 5, 2009, 12:02 PM   #3
Fourdoor's Avatar
Quote:
His PM inbox is permanently full.... so I am hoping that he (or someone like him) see's this thread
Keith
__________________
Offline
Old Nov 5, 2009, 12:05 PM   #4
Fourdoor's Avatar
Another question!
I know that the older ECU's you can run multiple maps with "shift on the fly" capability for different things (valet map, E-85 blah blah blah)... and I know there are lots of unused maps in the EVO X / Ralliart ECU such as the cylinder fuel trims.... isn't there a way we could re-define those maps and use them for "swap on the fly" capability?
Just wondering,
Keith
__________________
Offline
Old Nov 5, 2009, 02:38 PM   #5
Clipse3GT's Avatar
Quote:
Originally Posted by Fourdoor View Post
Another question!
Just wondering,
Keith
He is on Aussie time, so he will be around here at night usually.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Nov 5, 2009, 03:46 PM   #6
Personal Sales Rating: (3)
Drives: WW EvoX GSR
ok the timing AND fuel maps have different axis's
you cant just change the address in ecuflash because the ECU wont realise.
if you are absolutle dying to rescale send me the ROM and I will make sure no other tables are using the same axis - this is always the biggest problem we rescaling, if another table (that we havn't found yet) uses the same axis you rescaling, its bad
I plan todo tephramods for the X - so stay tuned for that... there is HEAPS of free space so we done need to reuse maps
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Online
Old Nov 5, 2009, 07:23 PM   #7
Fourdoor's Avatar
I already re-scaled today, doing both load AND RPM is a real pain in the @ss! Makes it so you can't just easily cut and past to re-configure things. The high octane fuel map effect the low octane map, and cylinder fuel trim #1, #2, #3, and #4.... if it affects others it hasn't caused me any problems yet.... I sent you a link to my map a few days ago at your gmail accept if you would like to check and see if there is anything else it may interfere with in the background where I can't see / correct it
I can't wait for the tephramods for the X! I was just hoping that some of that free space could be sucked up by larger maps for some of the things we already have... but from what you said above it sounds like that is a no-go
Later,
Keith
PS: At first I thought it effected the Evap maps, but I was incorrect... hence the edit...
__________________
Offline
Old Nov 18, 2009, 09:26 PM   #8
2008 Mitsubishi Lancer Evolution
smanders's Avatar
Drives: 2008 Silver Evo X MR / 2008 Silver Odyssey Touring (wife)
Hello Tephra,
I'm on the verge of rescaling the WGDC (High and Low) on my Evo X. Any other tables using those axis's? Know of anyone who's done that yet? I need more granularity in the 2750-3500 range for my EBCS in interrupt mode.
Thanks,
smanders
__________________
Silver Evo X MR
Buschur Crossflow Catback | UR HFC Metal Substrate | AEM Intake | Nisei 1pc UICP | GrimmSpeed EBCS | Swift Springs | Cobb Rear Sway Bar
CarPC | OpenPort 2.0 | LC-1 Wideband | EvoScan 2.7 beta (Thanks EvoScan Team) | Tuned by smanders
AVIC-Z110BT | PAC SWI-PS
Need to install: Cobb Front Sway Bar
Offline
Old Nov 18, 2009, 10:51 PM   #9
Drives: WW EvoX GSR
yeah I already done that too
BDEL obviously changes
__________________
Online
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
