Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 3, 2009, 02:38 PM   #1
Personal Sales Rating: (0)
Drives: B5 S4
Zeitronix wideband installation
I am getting ready to install Zeitronix wideband, got 2 questions
1) for rpm pick up, do i tap into ecm harness pin #8, Crankshaft Position sensor?
2) for boost sensor, do i T it off from fuel pressure regulator vacuum line?
Thanks
Offline
Old Nov 8, 2009, 07:13 PM   #2
Sabot's Avatar
Drives: S13, S14, PB Evo X & wife's 03 Evo
Late reply but...I'm using the DashDaq so I didn't need to connect the rpm wire but I did T of my boost signal from the fpr vacuum line with no problems and it works great.
__________________
http://4q.mybrute.com
Offline
Old Nov 8, 2009, 08:16 PM   #3
NTEC Club Forum Leader
Personal Sales Rating: (4)
goofygrin's Avatar
Drives: RR EvoX
wideband doesn't need rpm or boost...
__________________
Are you in the North Texas area? Check out NTEC!
mmmm corn
Offline
Old Nov 8, 2009, 09:36 PM   #4
Personal Sales Rating: (2)
flyguycfi's Avatar
Drives: Evolution X GSR
The ZT-2 can display boost, EGT, AFR, and a few other things through data logging with the supplied software that's probably why he is asking.
__________________
2008 Lancer Evolution X GSR
Baseline - 259whp @ 21PSI *stock turbo*
Tuned - 358whp @ 25PSI *stock turbo*
Tuned by TTP Engineering - Orlando, FL
Offline
Old Nov 8, 2009, 09:55 PM   #5
goofygrin's Avatar
Drives: RR EvoX
I figured as much, but seems weird to ask "for my wideband install, where do I tap off to get rpm and boost" lol.
You can also tap off an injector to get RPM.
__________________
mmmm corn
Offline
Old Nov 8, 2009, 11:02 PM   #6
Frankiago's Avatar
Drives: OB X GSR
Quote:
Pin 4, #1 ign coil (for RPM)
But pin 2 is #1 injector...
I'm gonna do this install as soon as I get a HFC on for the O2 sensor bung.
Offline
Old Nov 8, 2009, 11:04 PM   #7
flyguycfi's Avatar
Ah yea I see where your coming from.
__________________
Offline
Tags
evo, rpm, zeitronix
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
