Oct 25, 2009, 07:22 PM
Personal Sales Rating: ( 0)
Drives: 09 GSR
factory ecu map + fp red and boltons, will my car start?
So im going to be attempting my fp red install with a friend of mine and i have a couple questions.
Will the factory ecu map be a good enough base map to be able to start the car and have it running good enough to drive the car onto a trailer so i don't have to pay a retarded amount of money for labor on installs? I was planning to install all other bolt ons as well but leave the stock injectors in until the car arrives at my tuner. Any info or recommendations you guys could throw at me would be greatly appreciated. With all the info , support and DIY's on this forum i feel confident enough to install these parts myself so i can't justify spending the extra cash when its not needed.
mods will be :
ams fmic
harman motive uicp, licp, intake
ported fp red
forge wga red spring
ams dp, testpipe, cbe
walbro pump
deatschwerks 1000cc inj
aquamist hfs6 meth kit
ecutek tune by Cam at Lightspeed Innovatons
Thanks !
Offline
Oct 25, 2009, 07:28 PM
Personal Sales Rating: ( 5)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
As long as you do not get into boost you will be okay. Just stay in vacuum and you will be okay. It will be fine to drive on top a trailer and then shut it off and transport it. I do not recommend you got for a joy ride after a install without a tune.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Oct 25, 2009, 08:02 PM
Drives: OB 08 Lancer Evo X
I'd also run the wastegate on straight manifold pressure just to make certain you cannot possibly hit peak boost.
Online
Oct 25, 2009, 08:08 PM
Drives: 09 GSR
I have no intentions of driving the car around the block. I just want to be sure it will somehwat idle and be able to be driven onto a trailer. Thanks for the quick responses guys.
Offline
Oct 25, 2009, 09:33 PM
Drives: 09 GSR
i still have to ask has this been done? can someone actually say " yes the map will work i have completed the install myself and the car started and i was able to get it on a trailer " somewhere along those lines maybe? not saying that clipse3gt is wrong but i didn't see a fp red in his sig.
Offline
Oct 25, 2009, 09:36 PM
Drives: Swapped GC
Cant speak for EVOs but I have done this on Subarus and it worked just fine just avoid boost and you will be fine.
Offline
Oct 25, 2009, 09:47 PM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
You can drive the car just fine. You will need larger injectors and a walbro fuel pump with UR pump kit to get it tuned.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Oct 25, 2009, 10:02 PM
Drives: 09 GSR
Quote:
Thank you. When you mean " You can drive the car just fine " do you mean id be able to drive 600 kms to get it tuned rather then having to trailer it? That would be a huge bonus lol but i imagine its not recommended although my eyes would be locked on the wideband gauge. I am considering the UR install kit and fuel filter kit but i still find it quite pricey for the two pieces. I was told HBspeed has an install kit but im yet to find any info on it and have not received a email back. I see everyone running the walbro but how.
Offline
Oct 25, 2009, 10:03 PM
Drives: 09 GSR
Quote:
member since 2007 and that was your first post? welcome buddy and thanks for your experiences!
Offline
Silver Sponsor +1
You should be able to drive the car the whole way if need be. You should disconnect the wastegate arm for safety measure this way the car will not be able to boost.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Oct 25, 2009, 10:08 PM
Drives: 09 GSR
Awesome thanks for your help. I will leave it detached when i throw the WGA on the turbo, this makes me feel much better about everything feewwff
Offline
Oct 27, 2009, 06:08 AM
Personal Sales Rating: ( 6)
Drives: PB GSR
I would install everything except for the the injectors. You'll be dumping a lot more fuel since they have to be scaled once tuned. I drove with my DOM 2 170 and let the shop install the injectors and I was all good. I was hard staying in vac...but 10 psi partial throttle won't do any dammage! Great choice of parts btw!!!!!!!!!!!
__________________
HM intake (converted to CAI)
Forge RS BOV
DOM 2 TURBO
DW 800 CC injectors
Walbro 255 FP
UR Uicp
UR O2 DP
ARTISAN SINGLE Down Pipe Back Exhaust
White Defi Racer
ETS 4" IC
BC Coils
Gt-Spec Strut Bar
1.835 60', 11.79 @ 117.5 mph!!!! (second time at the track)
Tuned by DG motors 318 whp (old setup)
Retuned by DG motors 397.5 whp (new setup)
My brother paints tail lights!!!!!
Offline
Oct 27, 2009, 06:10 AM
Drives: PB GSR
Oh and don't hook up the meth. Let the shop finish it for you. Whos tuning the car?
__________________
Forge RS BOV
DOM 2 TURBO
DW 800 CC injectors
Walbro 255 FP
UR Uicp
UR O2 DP
White Defi Racer
ETS 4" IC
BC Coils
Gt-Spec Strut Bar
Offline
Oct 27, 2009, 08:35 AM
Drives: 09 GSR
Quote:
I will be letting the shop finish the final install of the meth ill be mountiong the pump , gauge and tap the pipes for the jets myself but will get cam at lightspeed to do the final touches and tune the car along with install the injectors. Thanks for your advice!
Offline
Oct 27, 2009, 09:29 AM
Drives: PB GSR
Np! Where is she getting tuned?
__________________
Forge RS BOV
DOM 2 TURBO
DW 800 CC injectors
Walbro 255 FP
UR Uicp
UR O2 DP
White Defi Racer
ETS 4" IC
BC Coils
Gt-Spec Strut Bar
Offline
Tags
bolt, car, dtm, ecu, evo, evom, factory, installing, map, ons, run, shutting, struts, tuned  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
