Increased in boost due to weather/temperature changes?
Those of you who is using stock boost solenoid to control boost, have you noticed an increased in boost during the colder season?
My car was dyno-tuned via ECUflash to 26.5psi just two weeks ago. Nothing has been altered since, except our weather changed and became colder since. I was triggering ASC light at peak boost and my mode23 datalogs showed I was boosting at 31psi!? In other words, I was overboosting.
I brought the car back to the tuner to check for possible vaccum leak, he checked every vacuum hoses and confimed everything were intact. I have been running the JUN wga and he wondered whether if it was set too tight for the cooler weather, so he disconnected the stock boost solenoid vacuum hose, boosting solely using the JUN wga. I did several pulls to see whether I would still trigger the ASC light. Datalog shows 19psi at peak with this test, with no overboosting issue.
He said that it is not unusual for the boost to increase due to colder weather, especially when using stock boost solenoid. He recommends getting aftermarket boost controller to avoid this from happening. Do you guys agree with his comment?
Our temperature is now 10 degress celcius, compared to two weeks ago about 20 degrees celcius. But I'm still surprised by how much boost I am seeing now compared to two weeks ago due to this change (31psi vs 26.5psi!). Has anyone else notice the same issue?
__________________
Advan RZ
ARC IC/OC/titan & bov pipe/duct/r-cap/knob
Billion r-hose
Blitz S-tank/NurSpec DT/TC/inlet/stopper
Chargespeed f-ducts
Coltspeed GT shifter
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
HKS cat/strut bars/grill
JUN lip/skirts/mirrors/manifold/TB/thermo/wga
NGK race plugs
OEM CF eng cover/camera/h-brake/brake guide
Okada Plasma coils
Project Kics R40
Ralliart taillights/ac & shift panel/pedals/oil cap
Swift springs
Varis diffuser
Walbro 255
