Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 24, 2009, 10:10 AM   #1
Personal Sales Rating: (0)
2008 Mitsubishi Lancer Evolution
cnj4ever's Avatar
Drives: 08 Lancer Evo GSR
Defi gauge showing 28-29 boost spike
Ok so I installed a Defi Cr white racer boost gauge, and when I floor it, the gauge shows a spike of 28-29ish then settles around 23. Is this normal or is this bad. All my mods are in my Sig except i took off the MBC. Thanks
__________________
Harmon Motive Intake
Harmon Motive CBE
Buschur MBC
Defi Boost Gauge
ACT HD Clutch
ACT Streetlite Flywheel
Offline
Old Oct 24, 2009, 10:15 AM   #2
Personal Sales Rating: (4)
wongck's Avatar
Drives: GG Evo X GSR
it looks a bit high. Are you getting any error codes? It seems like with winter rolling around, a lot of people are running into problems of overboosting
__________________
Graphite Gray '08 Evo X GSR
Power
Greddy Spectrum Elite Exhaust - Cosworth Drop-In Filter - Boost Pill - HB Speed Tune
Suspension and Wheels
Stance GR+ Coilovers - Advan RZ 19x9 +25 Bronze - Muellerized Set-up and Alignment
Vanity
Razo RA24 Onyx Shift Knob - Rexpeed CF Hood Dampeners - Rays Formula Lug Nuts - Advan Low-Type Center Caps - Nokya Artic Yellow H11 Foglights - Piaa Sport Horn 400Hz + 500Hz
Offline
Old Oct 24, 2009, 10:16 AM   #3
Personal Sales Rating: (2)
jd888jd's Avatar
Drives: Evo X- now I own, WRX Subaru - SOLD!!
Send a message via MSN to jd888jd Send a message via Yahoo to jd888jd
It might just be off....get ur car in a dyno and get an accurate reading. happened to me to.
Online
Old Oct 24, 2009, 07:36 PM   #4
WaitForIt's Avatar
Drives: 2008 GG X GSR
Mine does the exact same thing. It seems to be maybe 1-2psi off at most when I datalogged. I would still be seeing mid to upper 27's peak boost. Stock except for a once piece UIP. Couldnt find any definite reason as to why and was told it was more or less normal as I wasn't throwing overboosting codes or anything. This was also in the summer with 70-80 degree days.
Offline
Old Oct 25, 2009, 11:04 AM   #5
Personal Sales Rating: (3)
Drives: Evo X MR
I'm in the same situation. Seems to me the boost pressure is very sensitive to weather change.
My car was dyno-tuned via ECUflash to 26.5psi just a two weeks ago. Nothing has been altered since, except our weather changed a bit and became colder since. I was triggering ASC light at peak boost and my mode23 datalogs showed I was boosting at 31psi!? In other words, I was overboosting.
I brought it back to the tuner to check for possible vaccum leak, he checked every vacuum hoses and confimed everything were intact. I have been running the JUN wga and he wondered whether if it was set too tight for the cooler weather, so he disconnected the stock boost solenoid vacuum hose, boosting solely using the JUN wga. I did several pulls to see whether I would still trigger the ASC light. Datalog shows 19psi at peak with this test, with no overboosting issue.
He said that it is not unusual for the boost to increase due to colder weather, especially when using stock boost solenoid. He recommends getting aftermarket boost controller to avoid this from happening. Do you guys agree with his comment?
Our temperature is now 10 degress celcius, compared to two weeks ago about 20 degrees celcius. But I'm still surprised by how much boost I am seeing now compared to two weeks ago due to this change (31psi vs 26.6psi!).
__________________
Advan RZ
ARC IC/OC/titan & bov pipe/duct/r-cap/knob
Billion r-hose
Blitz S-tank/NurSpec DT/TC/inlet/stopper
Chargespeed f-ducts
Coltspeed GT shifter
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
HKS cat/strut bars/grill
JUN lip/skirts/mirrors/manifold/TB/thermo/wga
NGK race plugs
OEM CF eng cover/camera/h-brake/brake guide
Okada Plasma coils
Project Kics R40
Ralliart taillights/ac & shift panel/pedals/oil cap
Swift springs
Varis diffuser
Walbro 255
Online
Old Oct 25, 2009, 04:22 PM   #6
Personal Sales Rating: (1)
sne2040's Avatar
Drives: 2008 Evolution X
Send a message via AIM to sne2040
do you get the overboost when you're in lets say 3rd gear at 3500 rpm and you go WOT? that's actually quite common because your load (i believe it goes past 240% load) just flies through the roof and it spikes for that second or so. If you notice, it actually drops down to normal afterwards (ex. 25 psi) and gradually decreases while you climb up the RPM value. From my understanding, a 3-port ebcs can cure that issue.
Offline
Old Oct 26, 2009, 05:46 PM   #7
Drives: Evo X MR
^yes it would happen in any gear other than 1st. My load hit as high as 300% at 4000 rpm.
I retuned my boost map and fixed the issue.
__________________
Advan RZ
Billion r-hose
Chargespeed f-ducts
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
NGK race plugs
Okada Plasma coils
Project Kics R40
Swift springs
Varis diffuser
Walbro 255
Online
Old Oct 26, 2009, 11:04 PM   #8
Personal Sales Rating: (5)
Clipse3GT's Avatar
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Send a message via AIM to Clipse3GT
I had this same issue. My problem was fixed replacing the stock BOV. Yes, I poped in a GFB and the boost went back to normal. That is just my finding. I don't know if this is the case here as well.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Old Oct 27, 2009, 09:38 AM   #9
Personal Sales Rating: (7)
MR. Tim's Avatar
Drives: 2008 Mitsubishi Evolution X
To the OP - you should log the car with evoscan. See what the ecu is seeing, not what an aftermarket gauge is telling you.
__________________
"Aerodynamics are for people who can't build engines." - Enzo Ferrari
2008 Graphite Gray Pearl Evolution X
Offline
Tags
boost, bov, defi, elite, fs, gauge, gauges, greddy, solenoid, spectrum, spike, subaru, wrx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
