Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 21, 2009, 10:35 PM   #1
Personal Sales Rating: (3)
Drives: WW EvoX GSR
Bad Flash? Knock?
Hi Guys,
I am quickly coming to the conclusion that random cruise knock is caused by a "bad" flash.
Anyone have an experience with this?
ie sometimes you do a flash and you get 0 knock, then other times you do a flash and get 15 KS randomly when driving...
Cheers
D.
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Old Oct 22, 2009, 11:21 AM   #2
Personal Sales Rating: (0)
Drives: 03 RSX Type S, 08 Evo X
Only way this would be possible is if your battery voltage was lower than desired during a flash?
Define a bad flash please....
I've had the random part throttle knock b4 at low rpm but haven't seen it in a while and I haven't changed anything in that area....I have done recent flashes thou tuning for new parts...
Quote:
Originally Posted by tephra View Post
Hi Guys,
Cheers
D.
__________________
03 RSX Type S_T 2069cc_9.5:1_GT3582R
08 Evo X_FullRace_FPRed
K20A>4B11
Offline
Old Oct 22, 2009, 12:15 PM   #3
Drives: X
Hi teph, I'm also experiencing some of these random knocks myself... it would be around 3-6 knocksums at 60-80% load (fuel), between 1250-1500 RPM. My car is completely stock using NJ's generic 91oct ROM (slightly tweaked). Since this is in closed loop and the timing at that range is stock, I can't blame it on the tune. I've tried lowering the timing by a degree in that troublespot and it has helped a lot, but still sometimes i see the occasional knocks. I would say averagely, 2 out of 5 days of driving (dd to work)... I would see it once.
I don't think the flash has anything to do with it, since flashing the ECU is ultimately in binary (like all digital hardware) and there are builtin safeguards (ie. checksum) to make sure data is intact upon flashing. I know for sure since I've been flashing the ECU close to 40 times (started from Gunzo's and a lot of tweaks up to this point)... this troublespot has always showed up in the logs occasionally no matter what generic/tweaked tune I put in.
__________________
What does the RA forum "guru" think of the Evo's build?
Quote:
Originally Posted by ambystom01 View Post
"The build quality of the Evo is really no better than the average Civic, you could logically argue it is actually worse."
"it'll blow their mind that a hater, troll, slowbaru driver like myself would actually defend(?) an Evo."
100% Stock
Ghetto "Carputer" w/ Evoscan:
Nighttime Video
Daytime Video (carmount setup shown)
Car-webcam added
Custom Gauge Layout I
Online
Old Oct 22, 2009, 12:58 PM   #4
LAX
Drives: Evo X
I have the same exact thing. 60-80 load at part throttle and low rpm (1000-2000 rpm's), I get occasional knocks. Sometimes it will happen all the time. I've tried smoothing the timing a bit and it's still there. Tried switching back to stock map and it's still there (on a 100% stock car). So..I don't think that knock is anything to worry about.
Going back to tephra's concerns, I don't see how a bad flash could cause knock unless the maps actually got screwed up when getting written. One way to double check is to re-read the ROM from the ECU and see if the timing and fuel maps etc all look ok. If the actual procedural code were messed up, then I don't think the car would run at all. I've flashed over 40 times and haven't seen any random knock like that aside from the low load/rpm knock coming from a stop.
Offline
Old Oct 22, 2009, 01:15 PM   #5
Drives: X
^ Good to know someone else is experiencing this on a stock X.. and you even tested it out with the factory tune/ROM. I agree, a good way would be to test and compare the ROM by using the built-in ECUflash "compare to ECU" function also. Is Tephra getting the knocks in high-boost or WOT?
__________________
100% Stock
Nighttime Video
Car-webcam added
Online
Old Oct 22, 2009, 03:16 PM   #6
2Fst4U's Avatar
Drives: PB Evo X MR
Did you guys check your fuel pump relay? Been several accounts of it failing and causing car to run lean and then knock. Anticipate a recall to hit eventually, but the current fix is to replace with a new green relay from Mitsu if you don't want to wait for your motor to get harshed. Just something to maybe look at.
Here is some more info.
http://www.***************/forums/sh...ad.php?t=18887
Edit: Well that's interesting it won't accept the link. Anyway maybe research that.
__________________
2008 PB EVO X MR
FP Green, ETS Intake, ETS UICP, ETS V2 Exhaust, ETS Test Pipe, ETS O2 Downpipe, FIC 900cc injectors, AEM electronic boost controller, AEM Wideband
English Tuned @381.51awhp/311.98awtq
...and no transmission issues.
Offline
Old Oct 22, 2009, 03:34 PM   #7
Drives: X
^ no problem, most of us who hangout here in the tuning forums are aware of the fuel pump relay issue. We don't think it's the cause though, I'm almost sure Tephra has tried that out already.
__________________
100% Stock
Nighttime Video
Car-webcam added
Online
Old Oct 22, 2009, 04:46 PM   #8
Drives: WW EvoX GSR
I have no doubt that the ROM on the ECU is ok.
I am talking about something more sinister.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
