Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 12, 2009, 09:26 AM   #1
Personal Sales Rating: (0)
Drives: E-X
Need URGENT HELP ! ROM definition needed.
Hi to all guru's out there and here's my 1st post and need help !
1) I finally got ECUFLASH v.1.42 latest from open ecu
2) Got my Tactrix Cable OP 2.0 Cable & Evoscan v2.6
3) Innovate LC-1 WB yet to be hooked up.
Plugged in the cables today and launched ecuflash to read my ECU all went well and ecuflash asked me to turn off ignition key.
I turned ign off and restarted the car, i've got an CEL, i managed to read from evoscan and it says ECUID: i also tried to clear it but no help.
Tried the process again then i tried to test write, it says unknown ROM so i guess i probably need a definition file (my rom is attached and it is legal from my own X). I also tried to Clear DTC & end session in ecuflash before exiting the program but it didn't work out for me and on the Task Info it says something like "unknown flashing tool ' ' "
Also tried disconnecting the batt and waited 5 minutes but no help.
I'm running Windows XP SP3. Installed all drivers needed for Ecuflash & Evoscan. Logworks 3 is also installed.
My Evo X is 08 and located in the middle east. I also asked the dealer and they said it is Gulf Specs.
I'm able to drive the car, my guess is that I need a ROM definition for my ECU and put it in ecuflash and try the entire process again. I also saved a copy of the original ROM (attached).
All advices and Help is greatly appreciated !
Offline
Old Oct 12, 2009, 09:31 AM   #2
Drives: E-X
Tried to attach ROM in post but exceeded forum limit of 100kb's. I zipped the file but it is at 324kb's still too big.
Here's the link http://www.sendspace.com/file/qdyu3l
Thanks again in advance
Offline
Old Oct 12, 2009, 11:05 AM   #3
Drives: E-X
just started my car and the CEL is gone but i still need a definition file for my ROM.
__________________
08 Evo X MR
99 Evo 6
Offline
Old Oct 12, 2009, 11:18 AM   #4
Drives: E-X
forgot to mention, when i open my rom image, ecuflash says "unknown rom image"
any help ?
__________________
08 Evo X MR
99 Evo 6
Offline
Old Oct 12, 2009, 12:22 PM   #5
acamus's Avatar
Location: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Drives: his wife crazy & 04 Lancer
ROMID is 53050006
__________________
0xBADC0DE
Offline
Old Oct 12, 2009, 12:30 PM   #6
Personal Sales Rating: (2)
blk-majik's Avatar
Drives: 08 RR Evo X GSR
So the only problem is that you got a CEL after a *READ*, and you don't have the correct XMLs for your ROM? No need to panic
I don't think Evoscan or ECUFlash can clear codes on an X yet. The CEL is probably a U042 iirc. Lost communication with the ETACS module, I think. It happens to me every time I use ECU flash. I also own PCMSCAN, and I use it to clear.
Offline
Old Oct 12, 2009, 12:48 PM   #7
Drives: E-X
thx so much blk-majik, a relief for me now at least yeah when i started to download the ROM using ecuflash with ign to on position, everything flashses like a circus and all sorts of warning but then it all went back to normal. I'll try PCMSCAN if it comes again. i took the batt out for couple of mins it was still there but after a while when i restarted my car the CEL was gone by itself.
acamus, ROMID is 53050006, thx for the id. but how do i get the definition files ? i understand that once i get hold of the definition files, i copy it in the metadata in ecuflash ?
Hope to get more help and guidance . thx for the replies
__________________
08 Evo X MR
99 Evo 6
Offline
Old Oct 12, 2009, 03:23 PM   #8
To Bad's Avatar
Drives: EVO X MR
Enabling mode23 illustrated
Try this. I still get the cel and have not ever been able to test write but have not had the need to.
Offline
Old Oct 12, 2009, 11:56 PM   #9
Drives: E-X
will give it a shot . . . thx
__________________
08 Evo X MR
99 Evo 6
Offline
Old Oct 13, 2009, 07:47 PM   #10
Drives: E-X
i was able to get hold of the romid 53050006 def-file mentioned by acamus. pasted it in metadata in ecuflash and now i can see the parameters in ecuflash but not sure if mode23 is enabled. also tried to do some logging using evoscan but looks like i'm not able to log stuff i selected. i'll try to to enable mode23 to see if it works for me in evoscan. at the moment i'm just peeking the data in my ecu for now.
still waiting for replies from guru's out there and hope to get the proper def-file for my ecu (still wondering which spec my ride belongs to) then i'll start all over again from scratch by downloading from my ecu and see how it goes from there and also hope to find out which ECU i should select from evoscan to log data. at the moment i selected EVO X instead of usdm evo x mode23.
hope someone out there can help me out to solve this issue.
many many many thx in advance
__________________
08 Evo X MR
99 Evo 6
Offline
Tags
142, ecuflash, image, rom, unknown
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
