Oct 10, 2009, 04:39 PM
Personal Sales Rating: ( 0)
Drives: Evo X GSR
Question about Knock
I am getting 1.8 counts of knock and I am concerned about it. I'm experiencing it at strange times though. It's not while I'm boosting. Under max boost the most knock I've gotten is .30. I'm pulling the highest knock under 1000 rpms and at very low speeds. Almost when I'm coming to a stop or when I'm coming from a stop.
What could be causing this? Should I be worried, or is normal? How can I fix this?
Thanks
__________________
ETS 4" FMIC
ETS UICP
ETS LICP
SHORT RAM AI W/ K&N
BUSCHUR EXHAUST
COBB AP STAGE 2
Offline
Oct 10, 2009, 05:01 PM
Drives: 2010 EVO X.....I dont need a wing!
are you data logging? How are you measuring the knocK? evoscan?
Offline
Oct 10, 2009, 05:20 PM
Drives: Evo X GSR
data logging with Cobb AP.
__________________
ETS 4" FMIC
ETS UICP
ETS LICP
SHORT RAM AI W/ K&N
BUSCHUR EXHAUST
COBB AP STAGE 2
Offline
Oct 20, 2009, 12:58 AM
Drives: evo x gsr
ive seen the same thing have u figured out why
Offline
Oct 20, 2009, 12:28 PM
bump. I would like to find out more about this too.
Offline
Oct 21, 2009, 10:45 AM
Drives: Evo X GSR
I've found from mutiple logs that when the most amount of knock happens it's at a very low rpm like sub 800 and little to no vehicle speed. I've driven it really hard and pushed up to 27.5 psi of boost. I've found that under hard driving there is virtually no knock. It only really happens at random right before idle or after idle.
I've stopped worrying about it since it's well below 3 counts of knock and if timing is getting pulled it's not while the engine is under any kind of strain. I only encounter any measurable knock when the car is not being pushed and there is no throttle.
__________________
ETS 4" FMIC
ETS UICP
ETS LICP
SHORT RAM AI W/ K&N
BUSCHUR EXHAUST
COBB AP STAGE 2
Offline
Oct 21, 2009, 10:55 AM
Drives: OB 08 Lancer Evo X
This is completely normal. I've seen up to 12 counts of knock in EvoScan under low load/low RPM conditions. Nothing to worry about, probably isn't even legitimate knock anyway as I've tried to negate it with pulled timing and it still persists.
Offline
Oct 21, 2009, 01:15 PM
Drives: EVO X MR
Thanks
My guess is your running too lean comming and going in and out of closed loop from open loop.
__________________
EVO X MR 08' Wicked White
HP 321\TQ 325\91 Oct
MODS:
Cobb Access port w/Surgeline Map
Cobb SF Intake
DynoComp Tuned
TurboSmart BOV (un-installed for testing)
HKS UIP/LICP
AMS FMIC
Cosworth MX1 CAMS
Walbro 255 Fuel Pump and High Flow Filter kit
5Zigen Pro Racer ZZ Exhaust
Ultimate Racing Mini Muffler Test Pipe
AVC-R Boost Controller (un-installed)
Offline
Oct 21, 2009, 03:04 PM
bump. good theories.
Offline
Oct 21, 2009, 04:23 PM
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
yeh i've been seeing some very odd knock as well.
hunting for the cause/solution...
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Oct 22, 2009, 12:55 PM
Drives: Evo X GSR
Mine is less than 3 counts maximum when it does happen. I'm starting to wonder if the weather has anything to do with it.
Does anyone know if the knock sensor could possibly pick up elements outside of the engine and it's components?
__________________
ETS 4" FMIC
ETS UICP
ETS LICP
SHORT RAM AI W/ K&N
BUSCHUR EXHAUST
COBB AP STAGE 2
Offline
Oct 22, 2009, 01:18 PM
Drives: X
I'm experiencing this too (see the other thead Tephra recently started).
__________________
What does the RA forum "guru" think of the Evo's build?
Quote:
Originally Posted by ambystom01
"The build quality of the Evo is really no better than the average Civic, you could logically argue it is actually worse."
"it'll blow their mind that a hater, troll, slowbaru driver like myself would actually defend(?) an Evo."
100% Stock
Ghetto "Carputer" w/ Evoscan:
Nighttime Video
Daytime Video (carmount setup shown)
Car-webcam added
Custom Gauge Layout I
Offline
Oct 22, 2009, 02:29 PM
Yes...it will pick up on lots of things. I don't think the knock filters are written very well.
verkion
Offline
Oct 24, 2009, 07:56 AM
Drives: Evo X GSR
I've read that weather fluctuations like extreme heat or cold can cause the engine to act differently since the tune was most likely made for a baseline condition.
Plus the quality of gas, ie low octane can cause the engine to act differently.
I'm going to wait for a warm day and go fill up on 93 oct and put some octane booster in and see what the data log looks like.
__________________
ETS 4" FMIC
ETS UICP
ETS LICP
SHORT RAM AI W/ K&N
BUSCHUR EXHAUST
COBB AP STAGE 2
Offline
Oct 25, 2009, 01:35 AM
Drives: evo x gsr
good info
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
