Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 7, 2009, 11:41 AM   #1
Personal Sales Rating: (4)
seven_227's Avatar
Drives: EVO X GSR
Question Disabling the boost cut?
Any one knows how to disable the stock boost cut (Service required light) above 29 psi?
Car is tuned with EcuFlash.
Offline
Old Oct 7, 2009, 03:17 PM   #2
Personal Sales Rating: (6)
Hiboost's Avatar
Drives: 2008 Evolution X & 1996 Eclipse GSX
You could disable it by setting the Boost Limits to 319% or changing the Boost Cut Delay Timer to 10,000 ms but you are better off raising the load % that it gets triggered at about 10-20% higher than the max you typically see at 29 psi. That way if you run 35 psi due to a WGA signal failing to open your Wastgate you'll hopefully save the engine.
Using EcuFlash you can edit the "Boost Limit" table to set the higher thresholds.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Old Oct 7, 2009, 03:24 PM   #3
seven_227's Avatar
Drives: EVO X GSR
Thanks! I'll give it a try.
I'm actually aiming for 29 psi, but sometimes between shifts boost slightly spikes over 29 psi, and that's when It hits boost cut.
Offline
Tags
boost, cut
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
