Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 29, 2009, 12:04 PM   #1
Personal Sales Rating: (0)
stokEd's Avatar
Drives: 2008 Evo X GSR
Exclamation ECUFlash and EvoScan problems with Asus Eee PC
I have been having problems getting ECUFlash and EvoScan to work properly with my Asus Eee PC 1000h. The OS is XP Home and I've been running PCMScan for months with no problems.
ECUFlash problem:
With my Eee I'm unable to 'Read from ECU' but I AM able to 'Compare to ECU.' When I click 'Read from ECU' the screen that usually appears with the list of ECUs comes up blank.
I'll get some screen shots up later this evening.
EvoScan problem:
Unable to log with Mode23. I know I've read that EvoScan won't function properly if your voltages aren't to par, but I've tried running power straight from my Cig Lighter to the laptop and still no luck.
What I've tried:
Re-installed both ECUFlash and EvoScan (several times) making sure to delete any files leftover from previous installs and cleaned the Registry.
Re-installed OpenPort 2.0 drivers (at least twice.)
Tried four or five different USB cables.
Played with every possible power setting I know of one the computer.
Tried new laptop power cables.
Ordered a new battery for the computer (en route, should be here later this week)
Additional Comment:
I have been able to Read and Write to the ECU and log in EvoScan using Mode23 using a friend's 15" Sony Laptop running Windows 7 so I don't think it's the OP2.0 cable itself.
Help needed. Thanks.
Online
Old Sep 29, 2009, 12:12 PM   #2
coevolve's Avatar
Drives: 08 Evo X GSR
I'm running both on a Dell Mini ( without issue. Though I haven't used "compare to ecu"...)
IntelŪAtomŪProcessor Z520 (1.33GHz/533MHz FSB/512K Cache)
Which Eee PC model are you running?
__________________
brandon
gg evo x gsr
toyota fjc
gg evo ix mr -- sold
Offline
Old Sep 29, 2009, 12:42 PM   #3
SupremeX's Avatar
Drives: 08 GG EVO X GSR, 08 RR Outlander ES
My carpc works fine and it is an Atom 330 Processor (1.6Ghz, Dual Core). PCMScan and EVOScan work great but ECUFlash doesn't work.
I am about to upgrade the MB on my system and upgrade to Windows 7 very soon. I figure it is something with the install, but I haven't been worried enough about it to care to fix it yet.
__________________
2008 GG EVO X GSR SSS
~ AEM Intake: GST Boost pill: Buschur "Quiet" CBE: No Limit Recirc O2 Dump: No Limit Testpipe: No Limit UICP
SPEC P-Trim Twin Clutch : AMS Underhood Bushings
~ TWM Short Shifter w/ Bushings : TWM Big Type R Shift Knob
~ Sharkfin Antenna: OEM Mud flaps: Ralliart Taillights
~ Zeitronix ZT-2 Wideband w/ 3.5 MAP Sensor
Installing - AMS Clutch Master Cylinder Ring
Custom In-Dash Carputer : CF Sub enclosure
Offline
Old Sep 29, 2009, 08:51 PM   #4
stokEd's Avatar
Quote:
I have the Eee PC 1000h . It has the 1.6GHz Atom processor and (upgraded to OCZ) 2GB of RAM.
What OS is everyone running? I'm using XP Home.
Online
Old Sep 30, 2009, 07:50 AM   #5
coevolve's Avatar
I have the same processor in my dell mini, same OS, but 1GB less ram. No problems...
Is this the file you downloaded/installed?
ecuflash_1422595_win.exe
Are you using the tactrix cable? Or have you tried it? I know you said that you have tried several cables...
__________________
brandon
gg evo x gsr
toyota fjc
Offline
Old Sep 30, 2009, 11:56 AM   #6
stokEd's Avatar
I'm pretty sure I have the most version of ECUFlash. I believe I downloaded a new copy when I was doing the re-installs mentioned above.
Yes, I'm using the Tactrix OpenPort 2.0 cable. I was referring to having tried different USB cables.
Thanks.
Anybody else?
Online
Old Sep 30, 2009, 04:05 PM   #7
Drives: 2009 Lancer Ralliart
Everything works OK with my 7" 4G EEE PC running XP Pro
Offline
Old Sep 30, 2009, 06:37 PM   #8
SiC
Personal Sales Rating: (1)
2008 Mitsubishi Lancer Evolution
SiC's Avatar
Drives: Lancer Evo X GSR
I have an EeePC 1000H running WinXP Home and I don't have any problems using Evoscan or ECUFlash.......
Offline
Old Sep 30, 2009, 07:35 PM   #9
stokEd's Avatar
Quote:
Do you have the "stock" 1GB of RAM?
Any idea of what I might be doing wrong? Are there settings I should check are a certain way?
I'm hoping that new battery arrives and solves all my problems. The battery I have now hasn't been performing as well as it used to.
Online
Old Sep 30, 2009, 07:51 PM   #10
SiC
SiC's Avatar
No, I upgraded the RAM to 2GB the day I bought it. I didn't have to change anything, I installed Evoscan and ECUFlash without doing anything special.
Offline
Old Oct 1, 2009, 05:50 AM   #11
coevolve's Avatar
You are sure the ignition is in the correct position (ACC on/1 turn forward/etc) when you click 'Read from ECU'?
Do that.
Quote:
EvoScan problem:
Were you able to successfully configure Mode23? I know you've logged with it from your friends laptop but are you sure that you configured it correctly on your computer?
Side Note:
Your post number is 666...beasty
__________________
brandon
gg evo x gsr
toyota fjc
Offline
Old Oct 1, 2009, 07:32 AM   #12
NTEC Club Forum Leader
Personal Sales Rating: (4)
goofygrin's Avatar
Drives: RR EvoX
Quote:
+1 and this is the super mega hella slow eee (celeron 700 or something).
I think your install of evo scan and ecuflash is wrong/messed up/something.
__________________
Are you in the North Texas area? Check out NTEC!
mmmm corn
Online
Old Oct 1, 2009, 08:15 AM   #13
stokEd's Avatar
Same here, first day.
Yes, definitely.
We flashed a Mode23 enabled ROM onto my car with my friend's laptop and it logs fine with Evoscan on his computer. Then using my computer on the same ROM I am unable to log in Evoscan with Mode23 enabled. I'll triple-check everything and report back.
Quote:
Side Note:
Yes, THE BEAST.
Quote:
I have a 60 Gb OCZ SSD in the desktop I'm using now that I'll be formatting and throwing in the laptop soon, so we'll see if uber-fresh installs of each program does the trick.
Today is the last day of my job (WOOHOO!) so pictures will come as soon as I can get to my car--I walk to work so I go days without seeing/driving it.
I uninstalled my USB wireless mouse in case that was throwing things off some how. Still have a feeling it's something to do with the voltages being off if it's not a software issue. And I'm still waiting on the new battery to try.
Anyway, thanks for the replies, I'll hopefully have something more to report by tomorrow.
Online
Old Oct 1, 2009, 08:16 AM   #14
Personal Sales Rating: (6)
Drives: 2008 Evo, 1987 turbo Golf
couldn't hurt to reinstall the OS, or better yet upgrade to XP pro
__________________
Nothing's for certain, it could always go wrong.
Come in when it's raining, go on out when it's gone.
Offline
Old Oct 1, 2009, 08:17 AM   #15
stokEd's Avatar
Quote:
Yeah, agreed. When I install my SSD I think I'm going to give Windows 7 (beta) a try.
Online
Tags
drivers, ecuflash, evoscan, log, login, problems, probs, win7, windows, work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
