Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 28, 2009, 05:47 PM   #1
Personal Sales Rating: (5)
Clipse3GT's Avatar
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Send a message via AIM to Clipse3GT
COBB PROTUNED for 11.5 AFR ECU Slowly leaning car out to dangerous AFR???? Help!!!
Well I cannot figure something out.
I was PROTUNED with the COBB AP for 12 AFR then to 11.5 AFR under WOT. I am running a AEM UEGO to monitor my AFR under boost etc...
However, this is the issue. If I unmarry the COBB AP, unplug the battery, and let the ECU reset. Then I go and re-install the COBB AP on the car, and reinstall my COBB AP PROTUNE map. The car will run 11.5 AFR at WOT and 12's under light partial boost (i.e. 5 psi and under). After about 50 miles or less. The ECU will start to retune the car for leaner settings. Therefore the car will begin to lean out to 12.2-12.8 AFR under WOT, which is dangerous because of the knock. I got about 7CA of knock with that, which is dangerous and I do not want to grenade my motor.
Once it starts doing this, for me to drive the car hard. I have to either reset the ECU (with COBB AP) or I have to remap the COBB AP by reinstalling my PROTUNE map from CBRD.
I tried to switch relays, I tried 3 relays. Stock BLACK, Stock Green, and BOSCH 30A relay wired in. It has the same effect with all three. The computer starts to revert to original tune or tries to tune for leaner settings.
I am not sure what is going on, anyone can help with this issue. I am trying to get a hold of CBRD to switch me to ECUFLASH.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Old Sep 28, 2009, 05:57 PM   #2
Personal Sales Rating: (0)
Drives: Evo X GSR
Have you logged your long term fuel trims? One guess would be that over time, it is becoming negative, causing the car to give less fuel than necessary during WOT. This could be adjusted through injector scaling/latency I believe.
Offline
Old Sep 28, 2009, 06:33 PM   #3
Silver Sponsor
Personal Sales Rating: (4)
GST Motorsports's Avatar
Drives: EVO, STI
sounds like it wasn't tuned for the intake and/or larger injectors properly and the trims are slowing changing your fueling.
- Bryan
__________________
GST Motorsports
2439 Industrial Pkwy. West Suite A
Hayward, CA 94545
510-264-9049
The original E85 Army
http://www.gstmotorsports.com
Offline
Old Sep 28, 2009, 07:11 PM   #4
Silver Sponsor
Personal Sales Rating: (46)
CBRD's Avatar
Drives: LOT's'O'EVO's
Send a message via AIM to CBRD
Quote:
- Bryan
Bryan,
I would normally agree, but if I recall the long/short were both within 2-3%. I can't remember what intake it was, but I've seen the return hose into the inlet pipe post maf leak and cause similar issues.
Cb
Kris I'll call u tomorrow
__________________
www.cbrdspeedfactory.com
Immaculately prepared facility... State of the Art equipment..
Proven Motorsports Background.. ALMS, Grand-Am, Open wheel...
www.ChadBlock.com
CBRD Radiators, BBK Turbos, Intercoolers, EVO X parts, and CBRD Time Attack EVO backed by Advan
The standard just became standard. Meeting expectations is now not acceptable... we must always exceed them.
Offline
Old Sep 28, 2009, 08:02 PM   #5
Clipse3GT's Avatar
Quote:
Originally Posted by CBRD View Post
Bryan,
Cb
Thanks Chad!!!
I am not sure what is going on with this damn COBB AP. I thought it was my relay's going out at first, that's when I switched out the original relay with a green one, but the problem persisted. I even tried a BOSCH relay, and that did not help the cause either. I then started doing various tests with unmarrying and remarrying the COBB AP and relfashing maps.
I have CBRD MAP, CBRD 2, and CBRD 5 maps. I tried all of them, and it keeps happening with all of the maps. I am really clueless what is going on, the best I came up with is that it is adjusting the long term fuel trims over the course of a few trips. It is fine for a cruise or low boost. Since the AFR's a still in the 12's put I cannot do any WOT pulls without fear.
I mean the car runs about 14.3-14.9 cruising in 5th on the highway at 70mph. But then in 5th if I try to give it a bit of boost it goes to low 12's and then mid to high 12's.
Ontop of it will throw a p1241 with a STOCK EVO X DV valve. I switched to stock ever since that time we had issues with the FORGE RS throwing that code.
Now I am not sure if its the lean conditions that cause it throw the code. On top it the car will throw either a p0172 (system too rich) or p0139 (rear O2 circuit slow response) whenever the car feels like it.
P.S. I have the COBB AP intake and COBB Turbo Inlet pipe. We used the MAF scaling from OTS maps from COBB.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Sep 28, 2009, 08:55 PM   #6
Silver Sponsor
Drives: EVO, STI
Log the fuel trims with the AP (or just view in real time), that will be good information to post.
STFT and LTFT.
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Offline
Old Sep 28, 2009, 08:56 PM   #7
Silver Sponsor
Drives: EVO, STI
Bryan,
Cb
I didn't even notice the CBRD tune in the sig. I would imagine something is amiss as Chad knows a thing or two about deez evoz.
- Bryan
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Offline
Old Sep 28, 2009, 11:57 PM   #8
Personal Sales Rating: (2)
gunzo's Avatar
Drives: Lancer Evolution SST
Send a message via ICQ to gunzo
STFT and LTFT.
These don't affect Open loop .. or do they ??
lean spool ??
Offline
Old Sep 29, 2009, 12:10 AM   #9
Silver Sponsor
Drives: EVO, STI
Many people have posted cases of LTFT swings effecting OL fueling on the 10's
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Offline
Old Sep 29, 2009, 10:17 PM   #10
Clipse3GT's Avatar
Working with Chad @ CBRD to figure out the issue.
Great Tuner! Definitely helps his customers out.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Sep 29, 2009, 10:17 PM   #11
Clipse3GT's Avatar
Yes, I am thinking this is what is happening.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Sep 30, 2009, 12:05 AM   #12
Drives: Evo X
- Bryan
if I got a tune using Ralliart drop in filter, then changed to Cosworth filter, do you think that would matter?
Offline
Old Sep 30, 2009, 07:28 AM   #13
ak47m203's Avatar
Drives: evo xmr, civic, pathfinder, hopefully ZO6 with-in 5years
can you try asking kevin of NTEC here at evoM. it's local evo club or i will post it there.
__________________
http://www.cardomain.com/ride/3308500
Are you in the North Texas area? http://forums.evolutionm.net/north-t...club-ntec-303/
Evo X MR Perrin Drop In. Nesie 1 pc UICP. Modified Stock exhaust. Resonator delete.
Stock dyno:
http://www.motionbox.com/videos/7a9ad9b71614e3c3
f5
Will do:AP pro tune and boost pill(later this year), test pipe.
Tune dyno: ?
Offline
Old Sep 30, 2009, 07:37 AM   #14
Personal Sales Rating: (6)
Hiboost's Avatar
Drives: 2008 Evolution X & 1996 Eclipse GSX
My car is doing something similar but only swinging from +5 to -5. I bet yours is going to -5 or even -10 LTFT which really pulls out fuel when that happens. If I reset my ECU everything is fine at 11.5 AFR but it's almost random where the LTFT will settle and there are no other variables besides day to day weather changes. I'm using the same gas every week for fillups and checked the intake connections from the filter to the turbo and all seems fine.
I know that Tephra is working on a Fuel trim disable code but at the same time I want to figure out why it was hovering around +-2 before and now all of a sudden it's swinging +-5 day to day.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Old Sep 30, 2009, 07:44 AM   #15
coevolve's Avatar
Drives: 08 Evo X GSR
Chad, do you suspect that this is the issue?
Over time I'm sure that we will arrive at definitive answers regarding the structure/logic of the X ecu. However, it would be so nice to have our own EvoM Mitsubishi engineer that could affirm or deny theories...
I'd pass a hat and put in a large bill myself to encourage Tephra to accomplish this
__________________
brandon
gg evo x gsr
toyota fjc
gg evo ix mr -- sold
Offline
Tags
115, afr, beta, boost, cobb, crack, dangerous, ecu, evo, evoscan, front, intercoolers, leaning, log, logging, monitor, mount, v27
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
