Oct 6, 2009, 12:37 PM
#31
Personal Sales Rating: ( 5)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Quote:
Originally Posted by Hiboost
Keep in mind that if the LTFT's at cruise are "-5.0%" that it is actually running RICH and the car is using fuel trims to remove 5% fuel. This will also be leaning the car out at WOT by 5% which can be a .6 AFR shift (ex 11.5 -> 12.1 AFR).
Yes, I realize this. But what I am trying to figure out is why is it leaning the car out this much, which later in turn is causing knock and timing to be pulled at WOT.
But so far so good, after about 55 miles, we will see after work what the car will be doing.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Online
Oct 6, 2009, 12:51 PM
#32
Personal Sales Rating: ( 0)
Drives: Evo X GSR
The only reason LTFT would be leaning out so much would be if your car is running consistently richer than 14.7 during closed loop. It will be interesting if it doesn't lean out anymore after the dealer visit.
Offline
Oct 6, 2009, 01:18 PM
#33
Silver Sponsor
Personal Sales Rating: ( 46)
Drives: LOT's'O'EVO's
let me know what you find kris,
if there is some issue with the trims it will affect the new map i send, so i want to see what happens, ill make some revisions and see if its something we can fix for you
cb
__________________
www.cbrdspeedfactory.com
Immaculately prepared facility... State of the Art equipment..
Proven Motorsports Background.. ALMS, Grand-Am, Open wheel...
www.ChadBlock.com
CBRD Radiators, BBK Turbos, Intercoolers, EVO X parts, and CBRD Time Attack EVO backed by Advan
The standard just became standard. Meeting expectations is now not acceptable... we must always exceed them.
Offline
Oct 6, 2009, 01:32 PM
#34
cb
I'm doing some datalogs right now Chad. I have the seen the LTFT go from -.096 to right now -2.449 this is about a 55 miles of driving. So I will continue to datalog to see what is happening overtime. Right now I do not have issues with leaning out while under WOT or any knocking, minus small amounts below 3k rpm, which I think are small bumps in the road or ECU is trying to make the car more fuel efficient.
I will send you some of the datalogs from EVOscan later tonight to see what happening with these logs.
I do however realize that the original map I have from you Chad runs rich while cruising between 60 and 70 on the highway, where the AFR is about 12.8 to 13.6 cruising around 3000 to 3400 rpm. Might be the ECU trying to pull more fuel from the trims to make it 14.7 which in turn is causing my WOT trims to get wacky and get knock and timing retard.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Online
Oct 6, 2009, 06:08 PM
#35
No I have my car wired up so I have easy access to everything. But I have been being lazy in hooking it up to EVO scan.
Goodness is my LTFT have settled down.... like whaaaaa!!!!
They are -2.4 under cruise conditions and -6.1 at idle constantly. Unless I get out of closed loop. I don't have mode23 turned on, but I do have COBB AP still installed. After another 50 miles they have not changed.
I am not sure what the values should be but this is what they are staying at currently.
I cannot test if the COBB intake, dealer fuel recall, dealer AWC reflash, fuel relay, etc... settled it down. But they are staying constant atleast.
I attached the last few from my long cruises. Used EVOSCAN.
http://www.mediafire.com/file/j2ygny...6_13.01.07.csv
http://www.mediafire.com/file/4zygly...6_19.15.29.csv
http://www.mediafire.com/file/bjum2d...6_19.36.01.csv
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Online
Oct 7, 2009, 08:31 PM
#36
Well I put the COBB intake back one and started datalogging. Here is what is happening. The fuel trims are slowly moving towards a negative after about a 40 minute drive.
Looks like something is up with the tune and needs a tune up.
Here is a bit after I pulled into the parking garage. The trims downed to almost -5%.
Here are LOGS from EVOSCAN.
Log 1
http://www.mediafire.com/file/z5mmji...7_20.40.09.csv
Log 2 - PIC 1
http://www.mediafire.com/file/mzrxmy...7_20.43.37.csv
Log 3- PIC 2
http://www.mediafire.com/file/fo2ijz...7_21.20.09.csv
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Online
Oct 8, 2009, 09:01 AM
#37
Silver Sponsor
Kris,
odd how the trims were close to zero here, but after a 1.5 months they are off...
ill make some corrections and send you the ecuflash map
we will get you back to square one
cb
__________________
www.ChadBlock.com
Offline
Oct 8, 2009, 12:40 PM
#38
I dunno I always run Shell 93 octane. Only thing I can think Otherwise winterized fuel started coming into play.
Edit: Or somehow the elevation change over 300 mile distance. Not sure...
Thanks CBRD you guys are fantastic! Thank you for all the help!
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Online
Oct 9, 2009, 12:34 PM
#39
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
Some data for for people that like data
I had a 10 on the dyno last night with DW 1000cc injectors. I've tuned a bunch of them at this point, they work well.
Anyway. I was messing around with how much AFR change I would see with LTFT changes.
Car was set for 11.0 AFR at 0.3212 whatever LTFT
with a 2.0 LTFT it ran 10.7 AFR
with a 2.4 LTFT it ran 10.6 AFR
with a -1.5 LTFT it ran 11.2 AFR
Just some data, I also always error on the additive LTFT side if anything so it richens up, not leans out.
Personally I think the AFR sways with LTFT are a bit too sensitive. I know Tephra is (might be?) working on ways to either turn this off (so it acts like Evo 8's and 9's) or just reduce the sensitivity.
- Bryan
Offline
Oct 9, 2009, 02:12 PM
#40
Drives: Evo X GSR
- Bryan
Thanks for sharing! I've seen my LTFT jump as much as 2% on a single day on a completely stock car. Currently it's a bit over 3% and I'm seeing black smoke out the back when I do a 3rd gear WOT pull again (just like stock). I suspect my AFR is back in the 10.7-10.8 range instead of 11.0 or so. Do you have any observational data on how rich the AFR is typically when you start to see black smoke again? When I tuned it to 11.0, I had no black smoke. Need to get the wideband back on the car...
Offline
Oct 17, 2009, 09:26 AM
#41
Drives: X
What should the AFR be normally?
Offline
Tags
115, afr, beta, boost, cobb, crack, dangerous, ecu, evo, evoscan, front, intercoolers, leaning, log, logging, monitor, mount, v27  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
