Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 30, 2009, 08:24 AM   #16
Silver Sponsor
Personal Sales Rating: (40)
2003 Mitsubishi Lancer Evolution
My Garage
KevinD's Avatar
Drives: '04 evo8 daily driver, '03 evo8 time attack car, 08 outlander
Send a message via AIM to KevinD
one thing to watch out for is boost leaks and vacuum leaks. the two are DIFFERENT, and have different effects on the operation of the car.
first do a boost leak test if you haven't done one (and if all of a sudden your AFRs are swinging wildly, do another). the boost leaks test covers any possible leaks from the compressor cover to the intake valves. any leaks between these two points will cause the car to run rich when your manifold pressure is positive, and lean when maifold pressure is negative. if you have a leak between the MAF and the compressor inlet, then it will cause it to run lean under both positive and negative manifold pressure. there are not a lot of places leaks can happen between the MAF and the compressor, so its pretty easy to inspect.
keep in mind that even a small leak can cause your LTFT and STFT to swing pretty significantly, yet your closed loop operation will still remain within the 14.7AFR target. and as GST and CBRD already mentioned, the trims do effect the open loop operation on the X (this is not the case for the 8/9).
i don't know if i see this as a faulty accessport, i would think that if the car was tuned and worked well for a while and all of a sudden is doing this, i would wager that something else is amiss. if it has been doing it since the day you got tuned, well then it could definately be accessport or tune related.
__________________
EVOLUTION DYNAMICS LLC
Tuning, Custom Fabrication, and installs in the DFW area.
www.evodynamics.com
email: evokevin@gmail.com
Phone + Text messages: 817-776-2170
Kelford, mil.spec, ACT, Aquamist, FIC, ShepTrans, Zeitronix, + many others
Evo Dynamics Unlimited Time Attack Build
3-Port PnP Boost controllers for Evo 8/9/X and RA
Join us on FaceBook!
Offline
Old Oct 5, 2009, 02:33 PM   #17
Personal Sales Rating: (5)
Clipse3GT's Avatar
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Send a message via AIM to Clipse3GT
Well I think I found the problem. I think it was a pre-turbo problem.
Look at these pictures of the COBB SFI Intake.
Notice the large crack running through the housing, which is open to the other side behind the filter. I am sure that is what is throwing off the LTFT.
I put the stock in take back on with stock filter. I will monitor what happens with the stock intake.
I am shocked. I am calling COBB in a few moments to complain and get a replacement.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Kelford Stg.2 w Springs
SteepSpeed Exhaust Manifold
Offline
Old Oct 5, 2009, 02:46 PM   #18
Personal Sales Rating: (0)
BigT's Avatar
Drives: 2 ****su's
Hm, despite the crack, the air entering is still being measured at the sensor.
__________________
RR X GSR
Bolt-ons
Self Tune
VDR Dyno Numbers
Evo-M mode
357whp
366wtq
Offline
Old Oct 5, 2009, 02:56 PM   #19
Clipse3GT's Avatar
Quote:
Yes, that is true. But maybe the car is so sensitive that is causing the car to lean out. I will see over the next day or two on how the car behaves. I read that people had issues when the open filter lost its oil and it was dry and the car would change LTFT's. So maybe this was enough for the car to act goofy.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Oct 5, 2009, 03:00 PM   #20
Silver Sponsor
Personal Sales Rating: (46)
CBRD's Avatar
Drives: LOT's'O'EVO's
Send a message via AIM to CBRD
well, the volume of air could change from when it was tuned, because its allowing un filtered air into the maf, but the maf will still supply fuel for the amount of air it sees...
let meknow what you find out,
ill get ur map converted as soon as i can,
cb
__________________
www.cbrdspeedfactory.com
Immaculately prepared facility... State of the Art equipment..
Proven Motorsports Background.. ALMS, Grand-Am, Open wheel...
www.ChadBlock.com
CBRD Radiators, BBK Turbos, Intercoolers, EVO X parts, and CBRD Time Attack EVO backed by Advan
The standard just became standard. Meeting expectations is now not acceptable... we must always exceed them.
Offline
Old Oct 5, 2009, 03:17 PM   #21
Clipse3GT's Avatar
cb
I will see. I put the stock air box on right now, and I recheck all the clamps and readjusted everything pre turbo.
So hopefully it will be the problem.
Thank you Chad for converting my map over, your customer service is second to none.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Oct 5, 2009, 08:25 PM   #22
Clipse3GT's Avatar
Well yet another failure...
LOL...
Here are some DATALOGS from EVOSCAN
LINKS IN POST BELOW
You can see some that in the second log that the last time there is major knock count (36 CA) is where the AFR leans out to 13's. The LTFT and STFT stay within 5%. I like a idiot forgot to monitor boost.
I will try to install my AEM UEGO to be able to datalog with EVOSCAN.
BUT... the only thing now that I can imagine is overboost????????????? Where the boost spikes really hard and the car cannot compensate???
I dunno. I am out of ideas totally now. Changed the intake...still same problem.
Looking over the LTFT over 20 minutes I noticed it went from -4.6% and then after 20 minutes it went to almost -6.1% so I guess it is steadly leaning out somehow.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Oct 5, 2009, 08:45 PM   #23
Silver Sponsor
Personal Sales Rating: (4)
GST Motorsports's Avatar
Drives: EVO, STI
Links no workie...
__________________
GST Motorsports
2439 Industrial Pkwy. West Suite A
Hayward, CA 94545
510-264-9049
The original E85 Army
http://www.gstmotorsports.com
Online
Old Oct 5, 2009, 08:48 PM   #24
Clipse3GT's Avatar
Quote:
Originally Posted by GST Motorsports View Post
Links no workie...
Link 1
http://www.mediafire.com/file/myzknm...5_19.18.01.csv
Link 2
http://www.mediafire.com/file/hq5emk...5_19.32.19.csv
Thanks for letting me know.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Oct 5, 2009, 09:01 PM   #25
Silver Sponsor
Drives: EVO, STI
What version of Evoscan are you using? I can't tell much from those logs other than your fuel trims are wack.
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Online
Old Oct 5, 2009, 09:06 PM   #26
Clipse3GT's Avatar
Evoscan 2.7 BETA5 .
But apparently there were some issues with the BETA5, so I guess there is a new BETA 5 version.
Apparently some got messed up.
EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Should I revert to version 2.6 of EVOSCAN.
Then select ECU: EVO X
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Oct 5, 2009, 09:08 PM   #27
Clipse3GT's Avatar
I wonder if when COBB updated the firmware and asked everyone to update their protune maps with the converter something got screwed royally up.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Oct 6, 2009, 08:44 AM   #28
Drives: STi
Send a message via AIM to flatblackterror
i see your crack there. But Did you say you pressure tested it? I have to deal with this everyday with the subarus I tune. leak between the maf and the turbo sucking in un metered air causing lean issues. Good luck.
__________________
Epic Motorsports Cobb Protuning.. AEM, Open Source, Hptuners. If you get it we can tune it.
Offline
Old Oct 6, 2009, 10:13 AM   #29
Clipse3GT's Avatar
Well I came back from the dealer for the fuel recall and the AWC campaign, I also switched to a BOSCH relay instead of the POS green and black ones. Right now my fuel trims LTFT are holding steady at negative -.5 etc... for about 30 miles.
Not sure if the dealer flash, the return line, or the BOSCH relay are doing their job. But the logs pretty steady and not jumpy like they used to be.
I will post them up after I log for a little longer and monitor if any changes occur.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Offline
Old Oct 6, 2009, 12:24 PM   #30
Personal Sales Rating: (6)
Hiboost's Avatar
Drives: 2008 Evolution X & 1996 Eclipse GSX
Keep in mind that if the LTFT's at cruise are "-5.0%" that it is actually running RICH and the car is using fuel trims to remove 5% fuel. This will also be leaning the car out at WOT by 5% which can be a .6 AFR shift (ex 11.5 -> 12.1 AFR).
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Tags
115, afr, beta, boost, cobb, crack, dangerous, ecu, evo, evoscan, front, intercoolers, leaning, log, logging, monitor, mount, v27
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
