Sep 27, 2009, 06:49 PM
Personal Sales Rating: ( 0)
Drives: 2008 WW X MR: 325tq, 305whp, Rota Grids, Perrin shorty ant., Cobb F+B sway bars, HKS drop-in (3 layer-dry), AMS twin tip catback exhaust, UPIC, HBspeed tune
MAFs gone bad!
I have now had to change out 2 MAF sensors when going WOT, pedal to the metal, only to have both times "service required" main message and "check engine soon" lights come up. Code P0102. Changed out the MAF sensor, all is well both times!
My fuel pump relay is fine, I have a HKS drop in that I think may be the problem: have since ordered a Cosworth and am currently using the OEM paper filter.
Can my tune be an issue? Need to recheck with HBSpeed? Any thoughts as to whats up?
Thanks
Offline
Sep 27, 2009, 08:39 PM
Drives: 2008 RR Evo X
Thanks
Wash the HKS drop in under warm water and let it dry....some of the filter ship with some kind of oil on it that can muck up the maf.
Offline
Sep 27, 2009, 08:55 PM
Drives: GG X
I too also popped 2 MAF's and coincidentally was running the HKS SuperHybrid drop in as well. Just as the above poster stated I washed and dried the filter throughly and no more MAF failure. Did your dealership replace yours under warranty? Just curious...
__________________
evolutiondynamics built longblock • 5 angle valve job w/ported & polished head • Kelford 214-B's w/springs • FPRed • GM 3 port solenoid • AMS FMIC • AMS intake • AMS UICP • AMS LICP • UR o2/DP combo • DW 800cc • Walbro 255 • ACT 6-puck • Megan Racing coilovers • Volk TE37 18x9.5 • 285/35/18 Ventus RS-2's • Carbon Fiber. Lot's of Carbon Fiber.
Offline
Sep 28, 2009, 09:28 PM
No
Can a tune mess up a MAF sensor?
Offline
Sep 28, 2009, 10:06 PM
Personal Sales Rating: ( 1)
Drives: CZ4A
Hmm... been using the HKS filter for almost a year and no MAF issues.
Offline
Sep 28, 2009, 10:20 PM
Quote:
like i said some people have it some people don't
Offline
Sep 29, 2009, 03:19 PM
I even bought the new 3 layer dry HKS to replace the old HKS and both sensors failed after that. However, it may not be the culprit. Again, can the tune cause this problem or is that not possible?
Offline
Sep 29, 2009, 03:23 PM
Drives: Evo X GSR
I've know of another person that ran the HKS drop-in and had a MAF go bad too. Seems like too many cases to be a coincidence. How many people with a stock filter had a MAF go bad?
Offline
Sep 29, 2009, 03:39 PM
I agree: too many cases for it to be a coincidence.
Offline
Sep 29, 2009, 07:19 PM
Personal Sales Rating: ( 6)
Drives: 2006 EVO IX
Just run the stock filter and see if you get the p0102 code. If you do not get it, then it is the filter. If you do, then it is something else.
__________________
2006 EVO IX, Stock
2002 Toyota Tundra, 207 hp, 271 ft-lbs torque
1998 SE-R Race Car, 2008 SCCA ITA SoPac Champion
Offline
Sep 29, 2009, 07:52 PM
Even with the HKS in, it was OK, except for all the way out WOT which I did twice leading to 2 MAFs going bad. I am afraid to try it with the OEM filter! But eventually I will do it and then we will see!
Offline
Sep 29, 2009, 10:02 PM
Drives: Evo X
is the hks an oil foam filter?
Offline
Sep 29, 2009, 10:20 PM
Quote:
no
but I believe there is some kind of, either manufacturing lubricant or something else getting onto the filters prior to them being sealed up at the factory.
Offline
Sep 29, 2009, 10:25 PM
Personal Sales Rating: ( 5)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Maybe get a Perrin, Cosworth, or WORKS filter...
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Cosworth MX1
SteepSpeed Exhaust Manifold
Offline
Sep 29, 2009, 11:14 PM
Personal Sales Rating: ( 10)
Drives: On the mustang dyno
I've had one go out and I also have the HKS drop in. Full throttle on 2nd gear to redline when it popped up. Mitsu covered and also replace the maf plug. I was in the impression that it was the plug that was the problem thats why they replaced it. I dont think its the tune the could mess it up. I have since been running the same tune. But now I wanna change my filter to a Perrin one maybe.
__________________
---Will have new numbers soon----
08 Evo X FPRED
03 Evo VIII FPgreen (street), GT42r(Drag), soon to try 6262 to both street and drag.
Times
12.0 2005
11.4 2008
10.8 2009
Offline
Tags
2006, bad, cobb, eclipse, evo, filter, foam, gt, hks, mafs, p0102, plug, po102, port, replace, upic  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
