Aug 26, 2009, 09:06 AM
Personal Sales Rating: ( 6)
Drives: 2008 Evolution X & 1996 Eclipse GSX
Quote:
Originally Posted by LIGHTSPD
For what it is worth I had the shop car on the dyno last week. MBT for cruise area running a stable 14.7 AFR in closed loop. AT 40-50% Load was where I was playing at 2000-2500rpm 43 degrees and at 3000-3500 was at 45 degrees. Keep in mind I was running stock Mivec at these RPM. I am also running a fuel that is 10 percent ethanol. Not sure if this helps anyone but it is what it is.
Cheers C
Seems like we are in the right ballpark for timing then. There may be some gains bumping timing earlier from 2000-2500 as well as testing 45-46* from 3000-4000 RPM's. Also depending on where your car sits for load during cruise adjusting 50% load area slightly higher yet might work as well.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Aug 26, 2009, 11:51 AM
Personal Sales Rating: ( 2)
2003 Ford Mustang
Drives: 99 GSX, 08 RR GSR
what about mivec changes? or is that pretty much been worked over already (are the current JDM maps the most efficent for MPG?)
__________________
Rawr
Offline
Aug 26, 2009, 12:13 PM
Personal Sales Rating: ( 0)
Drives: 2008 EVO X GSR
Quote:
Originally Posted by tipoytm
91 or 93 oct? How much improvement on MPG? I got the timing map updated on my current ROM, but have yet to flash yet...
I have not checked MPG all I was looking for was MBT at certain loads. By knowing MBT I know the timing value that will work best there. The idea is to improve the efficiency of the engine if I go to far in my timing the engine will actually be working against itself resluting in lower MPG. If I don't give it enough I will not be building the most possible cylinder pressure that I can build. An engine is basically a glorified air pump. The more eficiently you pump the air the efficiently the engine runs. SO lets talk about MPG we want the engine to produce the most amount of cylinder pressure possible using the least amount of fuel to do that. So we command a leaner mixture say 15:1. Now this leaner mixture is doing a couple of things it is using less fuel which is good but is also starting to produce hotter cylinder temps moving us closer to preignition. I could get into a long winded speach about detonation and preignition but in this case preignition. Now on our cars I was able to go 2 degrees over MBT at cruise before I even saw any knock counts so that tells me the combustion chamber on this car is very efficient. What we want to do is max out the torque measured on the dyno at cruise speeds and cruise load. This is referred to as MBT it is different for each fuel as well so there is no set rule. As well adjusting the MIVEC is also going to effect this. BY adjusting the cam overlap we are able to change the cylinder pressure. As well by adjusting the exhaust cam we are able to simulate an EGR effect as well. This is where it gets more complicated you could add exhaust to the mixture which is going to dilute the mixture mildly depending on how much EGR you run. This is going to make the mixture less volatile in doing this you will be able to add more timing. The only purpose of this is would be to increase the cylinder pressure. Sometimes you can get so close to MBT that this does not help. Thats why they call it R&D lol. I hope this helps some of the new guys who are just trying to learn.
Cheers C
Offline
Aug 26, 2009, 12:38 PM
Drives: X
^ thanks for the info... I'd love to hear if anyone else has tried this with results
__________________
What does the RA forum "guru" think of the Evo's build?
Quote:
Originally Posted by ambystom01
"The build quality of the Evo is really no better than the average Civic, you could logically argue it is actually worse."
"it'll blow their mind that a hater, troll, slowbaru driver like myself would actually defend(?) an Evo."
100% Stock
Ghetto "Carputer" w/ Evoscan:
Nighttime Video
Daytime Video (carmount setup shown)
Car-webcam added
Custom Gauge Layout I
Offline
Aug 27, 2009, 07:30 AM
I also increased the timing by 12% in 0-50 load (up to 45 degrees) and by approx 5% in 60-100 load and I got 7% better mileage during cruising. Have to say I am running on liquid petroleum gas, which is approx AKI95.
Offline
Aug 27, 2009, 09:06 AM
Hiboost, I'm curious as to the slight increase in timing @ 500-1000+ RPM; low load (40-60?), what is the benefit of this?
I was just smoothing out idle a bit since my car was wandering a bit lean making it sound like I had cams. After bumping timing 2* that seemed to have gone away now, plus it should be a good setting for Cosworth Cams when I get those installed.
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Aug 27, 2009, 11:06 AM
Drives: 08 Evo X GSR
I logged a modified version of the map you posted Chris. Everything looks good though I haven't had time to really calc mpg yet....I can post data from the log (10-15 minutes at 60-70 mph ~90 degree ambient) upon request...
I have a question thought that is semi-off-topic.
What load cells do you hit when you are down shifting coming into a corner? I assume the load would be rather lowish...40,50,60 and the RPMs initially higher 4k+. Chris, are you maps close to stock in these cells? If they aren't would the increased timing for gas mileage result in spiked egts on the track?
__________________
brandon
gg evo x gsr
toyota fjc
gg evo ix mr -- sold
Offline
Aug 27, 2009, 11:29 AM
From 4500+ they are pretty much stock, maybe 1* increase in a few places that I noticed there was a dip in timing compared to surrounding cells. EGT's shouldn't be an issue except under boost and 100%+ load cells either way though. Since at 5000+ you will be in open loop you could slightly richen up the fuel tables to compensate, although to much fuel in the 10-20% load cells will give you qutiea bit more fireballs.
Generally the car goes full lean and turns off the injectors after about a second of letting off the throttle during engine braking and that is cooling things down quite a bit until you get into boost again.
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Aug 27, 2009, 11:36 AM
Quote:
Just in case make sure you are looking at the X and Y axis right since mine are altered from stock and that can cause some confusion.
Yeah, I modified accordingly....speaking of that...I imagine you modified the base xml file scaling to change the X and Y axis?
Quote:
...EGT's shouldn't be an issue except under boost and 100%+ load cells either way though
I knew this but my thinking was if the EGTs would already be higher than normal (cruising) due to the previous, straight-away, chicane, whatever, spent at 100%+, wouldn't increasing timing in the lower % cells increase EGTs as well?
Obviously this is moot when talking about 1* here and there...
Thanks Chris!
__________________
brandon
gg evo x gsr
toyota fjc
Offline
Aug 27, 2009, 06:42 PM
Drives: X
Quote:
Cool, thanks! Are you on the 80020 ROM? I've read somewhere that it smoothens out the idle compared to previous versions, and it seems to do so when I shifted from 80018 to the newest one... Just wondering if I should try out advancing the idle timing a little bit too, although my idle is fine as it is.
__________________
100% Stock
Nighttime Video
Car-webcam added
Offline
Aug 27, 2009, 08:39 PM
Hmmm not sure what they would have changed, unless it was something in a table we can't access. Currently my ROM is based off 52680017 (Inherits: 52680015).
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Aug 28, 2009, 10:10 AM
Wow an allnight dyno session and my head is still ringing kind of like drinking all night. Anyways I am on the 0017 ROM at this time as well. I will call you later today or this weekend Chris. Sounds liek we got alot to talk about.
Cheers Cam
Offline
Aug 28, 2009, 10:41 AM
Drives: WW EVO X
Better gas mileage?! Im interested
__________________
WW EVO X #32
AMS Front Motor Mount & Underhood Shifter Bushings
TurboTrix Piping Kit
ETS Dual Exhaust
T1R o2/DP Combo, T1R Testpipe, Shift Boot, Stubby Antenna
Prosport Boost Gauge
AEM Uego
DTM Stg. 2 FMIC
Perrin EBCS
Eibach Springs
Whiteline RCK
TWM STS, Bushings
Ichiba Spacer
Seibon CW hood/OEM Trunk
Chargespeed FRP VG
ECUTek Tune (318whp/359 Torque @ 26psi)
First EVO X in Canada to Break 300whp
Offline
Aug 28, 2009, 07:53 PM
Drives: Evo X GSR
Thanks for sharing these ideas! I am now running 43 degrees of timing at cruise. One word of caution (at least on my car), I had issues with advancing timing more than 1 degree in the 50 load column, and ended up keeping stock timing mostly in the 50/60/70 load columns. My car would knock on normal driving, especially at low rpm's. For instance, if I jabbed the gas pedal at about 2000 rpm's, it would cause repeatable knock. I ended up doing more smoothing so that my most aggressive timing is around 3000-3750 rpm's at 0-40 load, and it gets less aggressive at both lower/higher rpm. Also note that at higher speeds (above 70), my car tends to cruise between 50-60 load. Since I couldn't easily get a smooth knock-free map when adjusting the higher load cells, I just left them stock. Thanks again! I'll report back in a week or so with any noticeable mpg changes.
Offline
Aug 28, 2009, 09:31 PM
Hmmm that is interesting. It could be that all the mods I have for cooling and extra flow are giving me more headroom for timing increases. It's also interesting that at 70 mph I'm still running around 35-40% load versus 50-60% load. I haven't seen an ounce of knock since increasing the timing to where it is now. Let us know what kind of mileage you are seeing from the changes you made though, and good job with datalogging to verify that your setup will work with the extra timing!
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Tags
154, advance, afr, eclipse, economy, efficient, evo, fuel, fuel economy, gsx, ignition, increase, lean cruise, making, mileage, mpg, timing advance  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
