Nov 9, 2009, 09:16 PM
#151
Personal Sales Rating: ( 6)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
I think you are better off with getting your injector scaling dead on the ball and then upping the timing in cruise range. You will be better off with those settings.
I upped my timing more and managed to get about 2-3 mpg more at cruise with my injector trims at +1% idle and -0.5% cruise. Pretty close to 0, maybe the cruise fluctuates at more +/- 2%
__________________
List:
-Clipse3GT Tune -COBB UICP, LICP, BOV HP, SF Intake, Turbo Inlet Pipe, Sway Bars -ETS 4" FMIC -AMS DP, Fuel Rail, Rollerstop -T1R Exhaust -MXP TP -FORGE WGA -APS TV BOV -xMR Catch Cans -GM 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant. -Advan RS 18x10
Future:
FP Green Turbo (to install)
XXX Exhaust Manifold
Offline
Nov 9, 2009, 09:21 PM
#152
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
scalings or latencies?
scaling shouldn't really have an impact on MPG, since the trims will bring it back into place.
latencies on the other hand...
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Nov 9, 2009, 09:34 PM
#153
Personal Sales Rating: ( 2)
Drives: 06 RR Evo RS (sold ) RR Evo X GSR
I increased timing +3 degrees from 2500-4000 0-40 load... it did help me some.. i'm not getting the 30 mpg that HiBoost is getting either... but as I had asked, I don't know if that's because of the less restrictive mods he has or not.
Offline
Nov 9, 2009, 09:53 PM
#154
I meant it as both items. Most of the times you need to adjust both to get it right. If you adjust one and the other goes out of wack. So it's a bit balancing act.
So I meant adjust injector trim = latency & scaling.
__________________
List:
Future:
Offline
Nov 9, 2009, 09:56 PM
#155
Quote:
I increased timing about 2-3 degree in the areas from 40-70% load and from 2250 to 4500 range. No knock at cruise. But the MPG increase was significant. Mixed HWY and City I easily average 22-23mpg, not really babying the car either but just regular driving and giving it a boot full on the ramps. I am sure on a long trip I could average about ~25 on the highway.
__________________
List:
Future:
Offline
Nov 10, 2009, 07:27 AM
#156
Drives: Evo x
You know I have not even F'ed with this because I don't drive my car much maybe next summer I'll play with this. Seems be help a lot of people out that are DD.
__________________
08 Evo SSS/WW Tsudo Cat-Back Exhaust (no cat)
ETS intake, ETS DP Open dump Ecuflash, Evoscan, Self tuned it now for my X (Thanks to the help of people on this forum) LC-1 Wideband, UR UICP,LICP and Garrett 4.5 IC, Perrin 3 Port, Forge WG, Forge BOV
(on the way), 20% tent and Rally Armor flaps all installs done by me and tuned by me.
78 Corvette 406sbc 175 shot.
Offline
Nov 10, 2009, 04:35 PM
#157
I may give this a try... just 2* from 40-70 and see what happens.
Offline
Nov 11, 2009, 01:51 AM
#158
Personal Sales Rating: ( 0)
Drives: 03 RSX Type S, 08 Evo X
currently if i drive my car 65mph i get 28.5mpg, 75mph 25-26mpg, 85mph 23-25, 95mph 21-23.5 mpg...
this is b4 i made some recent part throttle changes to my map....ill have to retest and see what it does...not to shabby based on how ****ty this car came from the factory...
__________________
03 RSX Type S_10.0:1_GT3582R
08 Evo X_FullRace_(soon to be powered by Garret)
K20A>4B11
Offline
Nov 15, 2009, 12:12 AM
#159
how do you have your timing/anything else set? Any mods on the car?
*edit* oh I see the FPred... that could make a difference too I guess.
Offline
Nov 15, 2009, 12:13 AM
#160
so do you think it's safe to adjust the 40-70 load 2 degrees?
Offline
Nov 15, 2009, 09:28 AM
#161
Personal Sales Rating: ( 7)
2008 Mitsubishi Lancer Evolution
Drives: 2008 Evolution X & 1996 Eclipse GSX
I'm getting away with it but you definitely have to be carefull not to go too far and reduce power again. I'm sure the factory timing maps are somewhat conservative and on the low side of the optimal timing slope for any given RPM and load.
__________________
Chris Wirth
Onelap.RochesterDSM.org
2008 Evolution X (11.7 @ 118 mph)
- Garrett GT3076R - Prototype Intake Manifold
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" v1 CB - ATP O2 DP w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- 275/30-19 Yokohama ADVAN Neova AD08 on 19x9.5 Kosei K3 Wheels
- BC Racing ER Coilovers (10k/10k) - Rear Anti-roll Bar
Offline
Nov 15, 2009, 10:17 AM
#162
Quote:
yeah, that's why i'm trying just 2 degrees, instead of 3... I thought that would help at least some
Offline
Nov 15, 2009, 11:12 AM
#163
Drives: E-X
i also increased 2 deg timing. did some logging during cruise to get better milage
cruise @ 100 km/h load @ 40-60 range, cruise control on & rpm is @ approx. 2500
cruise @ 120 km/h load @ 50-80 range, cruise control on & rpm is @ approx. 3000
didn't note how much milage gained but definitely increased. was monitoring the milage after refuelling full tank.
i would try again by increasing 2 deg timing @ 2250-3500 rpm & load from 40-80. should be on the safe side.
__________________
Estimated 311 WHP 312 lb.ft TQ @ 24 psi Boost
HKS-UICP & LICP Pipes - Suction Reloaded Intake - Legamax Exhaust - Center Pipe
AMS-High Flow Race Cat
Innovate Motorsports-LC1 WB02 XD16 Gauge Combo
WGA-Stock but forgot how many turns
ECU-Stock-Self tuned-EvoScan V2.7 Final Release
more on it's way when i have more time to install them & some EXTRA CASH to burn
Offline
Nov 16, 2009, 11:48 AM
#164
As long as your IAT and CTS temps are within range and no knock.I say it's fine to advance the timing 2-3 degs in the 50-70 load areas. I did it and managed about 24mpg going 75mph on a 180 mile trip.
__________________
List:
Future:
Offline
Nov 16, 2009, 12:25 PM
#165
Drives: OB 08 Lancer Evo X
I managed roughly 26-27 mpg (at the pump) on a 1500 mile journey using 42 degrees BTDC advance in 40-80 load cells at highway cruise. Speed was between 70-80 mph the whole trip.
Offline
Tags
154, advance, afr, eclipse, economy, efficient, evo, fuel, fuel economy, gsx, ignition, increase, lean cruise, making, mileage, mpg, timing advance  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
