Nov 5, 2009, 03:47 PM
#136
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
Quote:
Originally Posted by tephra
you are really dying for better fuel consumption hey
generally:
1) make more power from the fuel you put in - ie MIVEC or IgnitionAdv changes
2) put less fuel in (ie lean cruise) - but this will require MORE IgntionAdv again otherwise you will loose power from the slower burning mix
I have yet to see any empirical proof that #2 works, feel free to do some tests for us
1. has shown to produce better MPG to me.
I tested both closed/open loop cruise and ignition changes for over a year on my personal Evo 8. Keeping it in closed loop and tweaking ignition produced better MPG on my Evo 8.
On the 10's and 9's, I've seen better mpg with ignition and mivec cruise changes.
- Bryan
Offline
Nov 5, 2009, 03:51 PM
#137
Personal Sales Rating: ( 5)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
generally:
I am beginning to think that scaling and latency has a affects fuel consumption. I know when I was running 696 scaling and 14v @ ~1.400 for my DW800cc I would get 24-25mpg on the highway with a setting my injectors to 770 and about ~1.200 latency @ 14V I get about 18-19.5mpg. No changes to MAF or Ignition or any changes to my High Octane map in the cruise range.
I figured out the that the stock 600cc injectors are about 11% scaled down to about 532. If you scale the DW 800cc injectors by 11% you should get about 713 in ECUFLASH. I will try to rescale my car for 713 and see if I net any better gas mileage.
I am thinking that 770 is too high and you need to lower the latency about .25 @ 14v to get your car into +/-5% cruise and idle.
If it dosent work, well then I can go back to my now working scaling and latency. I will do some testing today.
__________________
List:
-CBRD Tune -COBB AP -COBB UICP, LICP, BOV HP -COBB SFI -COBB Turbo Inlet Pipe -COBB Sway Bars -ETS 4" FMIC -AMS DP -T1R Exhaust -MXP TP -FORGE WGA -xMR Catch Cans -AMS Front Rollerstop -AMS Fuel Rail -evoDynamics 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant.
Future:
ROTA Torque
CBRD BBK Turbo
Cosworth MX1
SteepSpeed Exhaust Manifold
Offline
Nov 5, 2009, 04:20 PM
#138
Silver Sponsor
Drives: EVO, STI
Of course it has an effect if the car has to keep adding fuel to get the trims inline. It will always overshoot with too much fuel, then take fuel out, it's a downward spiral.
The 10's can be a pita in this way compared to the 8/9's since the LTFT is so sensitive and effects open loop fueling as well and is way too sensitive about it.
Offline
Nov 5, 2009, 06:32 PM
#139
Yeah I just did a run with much lower scaling at 680 and much high latency, now getting 28 mpg cruising.
Here comes the fun of rescaling everything again.
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Cosworth MX1
Offline
Nov 5, 2009, 06:41 PM
#140
Silver Sponsor
Drives: EVO, STI
28mpg for now until the fuel trims come back in line. What are your STFT's doing?
Offline
Nov 5, 2009, 06:49 PM
#141
Looks fuel trims look terrible.
STFT is within +/- 5%
LTFT IDLE is -1%
LTFT CRUISE is -12.5%
LOL , I need to adjust them.
Before I had it at 770 and latency lower and I was within these values:
STFT +/-6%
LTFT IDLE + between 1-5%
LTFT CRUISE +/- 2-3%
__________________
List:
Future:
ROTA Torque
CBRD BBK Turbo
Cosworth MX1
Offline
Nov 5, 2009, 07:05 PM
#142
Silver Sponsor
Drives: EVO, STI
LTFT IDLE is -1%
STFT +/-6%
hehe cruise maxed out negative.
Looks like your 770 scaling is much more inline
Go back to 770 and add a little bit more latency
Offline
Nov 7, 2009, 01:20 PM
#143
Personal Sales Rating: ( 2)
Drives: 06 RR Evo RS (sold ) RR Evo X GSR
which turbo would be the one that might save a bit of fuel instead of the oem mitsu turbo? One that doesn't start into boost so fast?
Offline
Nov 9, 2009, 03:42 PM
#144
Quote:
bump... still wondering about this question... any insight?
Offline
Nov 9, 2009, 04:42 PM
#145
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
you got a right foot yeh?
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Nov 9, 2009, 04:43 PM
#146
no I don't... I actually lost it in a freak bear hunting accident.
Offline
Nov 9, 2009, 04:44 PM
#147
Drives: WW EvoX GSR
mmm - should have gone the SST then
__________________
Offline
Nov 9, 2009, 06:18 PM
#148
ANYWAY... I guess what I am asking is which turbo's spool up more slowly than the OEM ones... and wouldn't that save fuel by doing so?
Offline
Nov 9, 2009, 06:26 PM
#149
Drives: WW EvoX GSR
lol
almost ANY aftermarket turbo will spool slower.
red/dom2/30r/35r
I don't think the fuel saving will be much
__________________
Offline
Nov 9, 2009, 06:29 PM
#150
lol
red/dom2/30r/35r
hmmm, well I had considered getting another turbo once money got a little better so I am just doing research now. Would I just be better off getting a TBE UICP IC drop in filter, etc and get better mileage that way? Less restriction, so I would think it would help maybe a few mpg.
Offline
Tags
154, advance, afr, eclipse, economy, efficient, evo, fuel, fuel economy, gsx, ignition, increase, lean cruise, making, mileage, mpg, timing advance  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
