Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 24, 2009, 06:35 PM   #31
SiC
Personal Sales Rating: (1)
2008 Mitsubishi Lancer Evolution
SiC's Avatar
Drives: Lancer Evo X GSR
I tested this out last night and this morning. I can confirm the problem is resolved, this is a big help for people with aftermarket injectors/cams. Now I don't have to avoid those RPM/load zones during cold start
Thanks alot!
Offline
Old Aug 24, 2009, 06:58 PM   #32
Personal Sales Rating: (6)
Hiboost's Avatar
Drives: 2008 Evolution X & 1996 Eclipse GSX
Quote:
Originally Posted by coevolve View Post
Thanks man. The "axis" change post was the only thing that confused me a bit...
screenshots would be awesome. When did you start experiencing this low throttle condition? My X is stock save the tuning that i've been learning. My current part throttle is quite fine.
I noticed it on the stock turbo after doing some bolt on's but it was hard to feel the effect because I rarely ran -5 psi on the stock turbo at those low RPM's. With the larger laggier turbo that lower rpm range feels more "retarded" until boost kicks in to mask it. If you don't feel a hestitation at light throttle it probably won't matter. For me knowing the "how and why" it was doing the hesitation was the biggest thing.
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Old Aug 24, 2009, 11:59 PM   #33
Personal Sales Rating: (0)
BigT's Avatar
Drives: 2 ****su's
i definately feel this on cold starts. i'll give it a shot tomorrow.
Offline
Old Aug 25, 2009, 05:23 AM   #34
coevolve's Avatar
Drives: 08 Evo X GSR
Thanks Bryan/Tephra, got it:
I haven't exhibited problems with part throttle/cold start yet but it is still quite warm here and the car heats up rapidly....(NoVA)
Thanks hiboost, that makes a lot of sense.
__________________
brandon
gg evo x gsr
toyota fjc
gg evo ix mr -- sold
Offline
Old Aug 25, 2009, 05:27 AM   #35
Personal Sales Rating: (3)
Drives: WW EvoX GSR
yeah i reckon it works as well
ok so the question is, do you damage the cat by not warming it up?
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Old Aug 25, 2009, 06:53 AM   #36
Hiboost's Avatar
I did some research last night on that topic, it's mainly just going to take slightly longer to warm things up for a cat to come up to operating temperature. The thing is if you drive at higher throttle to avoid the hesitation that yields 0 to 10 psi instead of -5 psi then you will be in the 100 to 140% load cells and not even have that table kick in very much. I'm going to test 40%, 30%, 20%, 10% in the columns to see if I notice a difference compared to 0%.
Since I am running 44* peak timing at cruising loads for better MPG, I would rather not run higher than stock 40* until it is closer to full operating temperature. We'll see where it sits, probably in the 30's which would be a good compromise.
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Old Aug 25, 2009, 04:11 PM   #37
Drives: Evo X GSR
Thanks all for figuring this out! I was thinking about this. I tend to only notice the hesitation around 2000 rpm's, and only during the first 2 or 3 sessions of light acceleration from a stop. I think I need to log coolant temp during warmup to see how quickly temperatures rise. Since it doesn't seem to last very long, I don't know if I should modify these tables (or just leave it to help save the stock cat). Should I just deal with the annoyance or modify the tables? It's reassuring to know that it's not necessarily something wrong with my car (such as bad plugs), but it also sucks that the car just doesn't feel right under light acceleration after a cold start. Mine is most noticeable around 2000 +- 250 rpm's.
Offline
Old Aug 25, 2009, 04:59 PM   #38
Drives: WW EvoX GSR
I did:
-32C 0
-8C 0
7C 100
20C 100
34C 75
50C 0
62C 0
77C 0
that seems to work quiet well, although im tempted to use 75 for the 100's as well..
__________________
Offline
Old Aug 25, 2009, 05:24 PM   #39
Hiboost's Avatar
I did:
-32C 0
-8C 0
7C 100
20C 100
34C 75
50C 0
62C 0
77C 0
I tested these settings and they were perfect for my setup:
-32 C - 0
-8 C - 40%
7 C - 30%
20 C - 20%
34 C - 10%
50 C - 0
62 C - 0
77 C - 0
That yielded timing in the high 20's at 2k RPM climbing to high 30's by 4k RPM with zero hesitation and coolant temps of around 120-140 F. Seems the temp scale is a bit off but the desired effect is working great and predictable.
Probably a less drastic change to test for cat users would be these settings which should still keep you away from dropping much below 20* in most cases and avoid hestitation:
-32 C - 0
-8 C - 75%
7 C - 60%
20 C - 45%
34 C - 25%
50 C - 0
62 C - 0
77 C - 0
If your cooling system is working correctly you should be warming the car up within a few minutes either way.
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Old Aug 25, 2009, 10:19 PM   #40
BigT's Avatar
Drives: 2 ****su's
Thanks for posting this guys. Helped a lot!
Offline
Old Aug 26, 2009, 11:22 PM   #41
Drives: 08 Evo X Apex Silver
Quote:
-32 C - 0
-8 C - 40%
7 C - 30%
20 C - 20%
34 C - 10%
50 C - 0
62 C - 0
77 C - 0
-32 C - 0
-8 C - 75%
7 C - 60%
20 C - 45%
34 C - 25%
50 C - 0
62 C - 0
77 C - 0
Thanks Hiboost!
I used 100%, 60%, 40%, and 20%. That was good enough for me and it worked great.
Offline
Old Sep 25, 2009, 06:57 AM   #42
EvoM Super Moderator
Personal Sales Rating: (20)
Noize's Avatar
Drives: PB Evo X
Sorry to bump a month old thread.
My car does something similar, but its different too.
I warm the car sufficiently before getting on the throttle, but I can drive normally for 15 minutes, than start accelerating in 5th on the interstate. When I pass through the 3300-3700rpm range, I feel hesitation. This is with the car seemingly warm, mind you. Its annoying enough that I'll replicate it a couple times, and it goes away completely.
Stock turbo, bolt ons. Thoughts?
I can try to capture the behavior in a log one morning, please tell me what parameters I need to log.
Thanks
__________________
Powered by Ultimate Racing and Ecuflash
Site rules and guidelines can be found by clicking here
Autocritic blogspot
Online
Old Sep 25, 2009, 07:01 AM   #43
Drives: WW EvoX GSR
coolanttemp/timing/knock/rpm/tps/load and afr if you have it
__________________
Offline
Old Sep 25, 2009, 07:42 AM   #44
Noize's Avatar
Drives: PB Evo X
AFR I don't, but I know its straight from a dyno session recently. Low-mid 11s.
I'll work on getting the rest, thanks heaps Tephra!
__________________
Autocritic blogspot
Online
Old Sep 28, 2009, 08:44 PM   #45
Noize's Avatar
Drives: PB Evo X
.rar file renamed to zip to upload. Please change back to .rar to open.
I'm not getting any appreciable knock, nor does it seem to be acting funny on the road tonight. Its ambient 58 degrees F outside here, so quite cool.
Just wanted you guys to have a look to see what you thought.
I basically just cruised in fifth and booted it every few seconds in the range it sometimes hesitates, and held it.
Thanks for looking.
__________________
Autocritic blogspot
Online
Tags
53040010, acceleration, car, cold, evo, evolutionm, hesitates, hesitation, hesitations, sales, slight, start, stops, timing, warm
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
