Aug 23, 2009, 11:00 PM
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
mine is exactly how GST posted...
Keep in mind it is a percentage for interpolation to the coldstart maps.. not a % of the actual timing value...
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Aug 23, 2009, 11:21 PM
Personal Sales Rating: ( 6)
Drives: 2008 Evolution X & 1996 Eclipse GSX
Hmm mine looks like this:
-40 0%
-40 100%
-40 100%
-40 100%
-40 100%
-40 0%
-40 0%
-40 0%
Not sure if it is worth testing still, I would rather find the right table before mucking with unknown values.
As far as percentage for interpolation that is confusing me a bit.
If (42*)+ (-30*) = 12* at 100%, what would 50% or 25% be then?
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Aug 23, 2009, 11:38 PM
Drives: WW EvoX GSR
oops - axis updated in post above...
__________________
Offline
Aug 24, 2009, 12:28 AM
Personal Sales Rating: ( 0)
Drives: Mitsubhsi EVO 9 & Nissan 240SX
hmm good thread, im sub'd to this thread
Offline
Aug 24, 2009, 12:31 AM
That works, will test on my next cold start!
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Aug 24, 2009, 01:21 AM
Personal Sales Rating: ( 1)
2008 Mitsubishi Lancer Evolution
Drives: Lancer Evo X GSR
I had the same problem after changing injectors/cams. I just learned how to drive avoiding this RPM/load area when the engine was cold  I'll test this out and see how it goes.
Offline
Aug 24, 2009, 08:08 AM
Drives: 08 Evo X GSR
great work guys....subscribed
__________________
brandon
gg evo x gsr
toyota fjc
gg evo ix mr -- sold
Offline
Aug 24, 2009, 08:56 AM
Drum roll...
The car had a wonderfull 40* timing during cold start and was driving SMOOTH as ever just like it was fully warmed up. Thanks Tephra and GST for pin pointing this so quickly!
The only thing is Mitsu may have placed that there to warm the cat for emmissions purposes so anyone still running one may want to try reducing the use of the tables only partially to see if there is balance between smoothness and heating up the cat on cold starts.
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Aug 24, 2009, 09:02 AM
Drives: WW EvoX GSR
Did you just reduce the % in that little table?
I will probably just make 34 degC like 75% and 50 degC like 0%...
So I will still have cold start, but just for shorter time...
__________________
Offline
Aug 24, 2009, 09:16 AM
hiboost/tephra can you give a comprehensive review of what you did? (not comprehensive in length necessarily)
What .xml code did you use?
Which map?
What changes...etc
Thanks guys, awesome work!!!
__________________
brandon
gg evo x gsr
toyota fjc
Offline
Aug 24, 2009, 09:18 AM
I went to 0% for now and will add some retard back for the colder weather that will eventually bear down on New York State. There is probably a happy medium ground for percentages that will work for colder weather.
What looks odd to me though is the retard was kicking in at 120-140 F coolant temps but according to the chart it should only have kicked in that table from 18 F to 93 F for 100% and then tapered to 0% by 122 F.
-32 C = -26 F
-8 C = 18 F
7 C = 45 F
20 C = 68 F
34 C = 93 F
50 C = 122 F
62 C = 144 F
77 C = 171 F
Which map?
What changes...etc
I'll post some screenshots after work unless Tephra beats me to it, everything you would need is in the posts though.
__________________
Chris Wirth
RochesterDSM.org
- Garrett GT3076R
Offline
Aug 24, 2009, 11:35 AM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
Quote:
Originally Posted by Hiboost
Drum roll...
Awesome, glad tephra could find it so quickly.
This will help a ton when you get cams as well as they make the cold starts worse with the timing retard.
Offline
Aug 24, 2009, 11:56 AM
-32 C = -26 F
-8 C = 18 F
7 C = 45 F
20 C = 68 F
34 C = 93 F
50 C = 122 F
62 C = 144 F
77 C = 171 F
Thanks man. The "axis" change post was the only thing that confused me a bit...
screenshots would be awesome. When did you start experiencing this low throttle condition? My X is stock save the tuning that i've been learning. My current part throttle is quite fine.
__________________
brandon
gg evo x gsr
toyota fjc
Offline
Aug 24, 2009, 12:50 PM
Silver Sponsor
Drives: EVO, STI
Ok here is the table:
and here is the code used for getting it:
evo10base.xml:
<scaling name="Percent255" units="%" toexpr="100*x/255" frexpr="255*x/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/>
<table name="Percent Low Temp Timing Trim vs Coolant Temp" category="Timing" type="2D" level="2" scaling="Percent255">
<table name="Engine Temp" type="Y Axis" elements="8" scaling="Temp"/>
</table>
52680015:
<table name="Percent Low Temp Timing Trim vs Coolant Temp" address="56170">
<table name="Engine Temp" address="610e0"/>
</table>
A big thanks to Tephra.
Offline
Aug 24, 2009, 04:59 PM
Drives: WW EvoX GSR
no problemo
__________________
Offline
Tags
53040010, acceleration, car, cold, evo, evolutionm, hesitates, hesitation, hesitations, sales, slight, start, stops, timing, warm  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
