Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 4, 2009, 12:58 AM   #31
Personal Sales Rating: (3)
I lifted up the car to reverify placement of the wideband per the discussion above.. And it's too tight fit and hard to get to with tools (I have an LM1 which I'm not planning on mounting permanently). I stuck a deep 17mm deep socket where I painted the dot below and and it's awfully close to the heatshield, and with the wire sticking out of top of the wideband - will most likely cause it stress and problems.
I believe the other side is better just like the other downpipes (pictured below) Much easier to get to and it's like the grand canyon on that side space wise.
Offline
Old Sep 4, 2009, 01:23 AM   #32
Drives: WW EvoX GSR
yeah it is a bit of a pain...
there was some reason why I didn't put it on your second dot...
give it a go
just make sure it clears the drive shaft
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Old Sep 4, 2009, 08:47 AM   #33
Personal Sales Rating: (0)
coevolve's Avatar
Drives: 08 Evo X GSR
What are you using to clean the red paint off the dp each time?
__________________
brandon
gg evo x gsr
toyota fjc
gg evo ix mr -- sold
Offline
Old Sep 4, 2009, 08:52 AM   #34
Quote:
Red paint? lol - photoshop?
Offline
Old Sep 4, 2009, 08:54 AM   #35
coevolve's Avatar
(was a bit of a joke/comic relief)
sorry...haha
If i ever find some e85 here in NoVA, i'll change my license plate to korny
__________________
brandon
gg evo x gsr
toyota fjc
Offline
Old Sep 5, 2009, 01:06 AM   #36
Offline
Old Sep 5, 2009, 01:36 AM   #37
Drives: WW EvoX GSR
cool
__________________
Offline
Old Sep 5, 2009, 05:34 PM   #38
Last pic, I promise - lol. There's plently of space all around in that location (clears the propeller shaft, which is 6 inches higher). I followed tephra's advise and unplugged the front o2 sensor from the cabin (grommet) was much easier to remove it that way than trying to monkey with the sensor while the downpipe is still attached. Those sensor's aren't cheap so it might be wise not to stuff it up (learned that from tephra). Anti-Sieze is your friend.
Offline
Old Sep 7, 2009, 01:03 AM   #39
Personal Sales Rating: (1)
sne2040's Avatar
Drives: 2008 Evolution X
Send a message via AIM to sne2040
I have the Perrin one piece dp/hfc and it doesn't have a bung. I'll be removing mine soon and having one welded on.
Offline
Old Sep 7, 2009, 01:23 AM   #40
Quote:
Looks like it has two bungs in it already for the stock sensors.. Should have no problem putting a wideband bung at the 3' oclock position run under the front bung (just like the AMS widemouth and the T1R v2 downpipes). Not really sure why perrin decided to make a downpipe + high flow cat considering the stock downpipe is already 2.75" ID (it's also nice that the stock downpipe is covered with heat shielding). Reading about, it's the o2 housing section that's restrictive (which is what the AMS, and the T1R downpipes fix). They should have made just a high flow cat section instead w/ a wideband O2 bung before the HFC, and one after the HFC (should have plenty of space to stick an o2 bung after the flange as their high flow cat is shorter in length).
Offline
Old Sep 7, 2009, 03:02 AM   #41
sne2040's Avatar
^ actually one bung is for the upper (pre) and the lower (post) cat on the Perrin. No wideband bungs. I'm gonna consider changing my downpipe for the AMS when i eventually go bigger turbo
Offline
Old Sep 7, 2009, 02:15 PM   #42
Yep, that's why you should get a bung welded at the 3 o'clock position under the first o2 bung (before cat).
Offline
Old Sep 9, 2009, 01:46 PM   #43
►EvolutionX◄'s Avatar
Drives: 08' GG Evolution X GSR
Arent Wideband sensors supposed to be mounted at at least a 10 degree angle with the horizontal so that no liquids can settle in the sensor housing/sensor?
__________________
Engine Modifications
AEM CAI
AMS FMIC
AMS UICP
AMS 02 Downpipe
AMS Test Pipe
ETS V2 Cat-back
-Visual Modifications-
AEM Analog Boost
AEM Analog Wideband
V1 Hardwired
Ralliart Tailights
Powdercoated Wheels
Offline
Old Sep 9, 2009, 05:18 PM   #44
per the docs, it's okay to mount them between vertically, up to 45 degree angle. Most of the downpipes that you see with a wideband bung mounted on them at the 45 degree angle. I guess you can mount them at an angle less than that but there's a drive shaft above.
Mine is mounted at a 45 degree angle.
Offline
Tags
02, band, bung, cat, downpipe, evo, front, lc1, narrow, oxygen, pipe, post, replace, sensor, simulator, wideband
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
