Aug 20, 2009, 08:06 PM
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
I can trust it, because if I see a funny reading I know to ignore it...
like if I tuned for 11:1 and then all of a sudden I was seeing 10:1 I know the LC1 has probably stuffed up... and I can ignore that log...
HOWEVER with narrowband sim, the car doesn't have that filtering capability, it places complete trust in the signal being correct... it doesn't ask me first  hehe
space is also an issue with the 02 sensor
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Aug 20, 2009, 08:11 PM
Personal Sales Rating: ( 0)
Drives: Evo X GSR
Hmm so if I always had a wideband gauge mounted, and occasionally checked WOT AFR's to make sure the LC-1 was accurate, then could it be trusted as a narrowband simulator? I'd rather not weld a bung into the stock downpipe if I dno't have to
Offline
Aug 20, 2009, 08:15 PM
Drives: WW EvoX GSR
well in all honesty I am probably being over-dramatic..
narrowband only revolves around 14.7:1, which the LC1 seems to be fairly good at getting right.. ie its doesn't need to be that accurate.
hey - give it ago, you will find the heater for the narrowband an issue, you *might* get away with disabling that bit to disable the heater for the front narrowband thou...
__________________
Offline
Aug 20, 2009, 09:17 PM
Drives: 2008 Evo X GSR
Quote:
Originally Posted by LaXGSR
OT: lol... I've got that exact same tool from Harbor Freight. Disposable tools FTW.
Offline
Aug 20, 2009, 09:34 PM
Drives: WW EvoX GSR
cheap tools that work FTW
__________________
Offline
Sep 1, 2009, 11:53 AM
Drives: 2008 Evo X MR
Subscribe..
I am also interested in possibly replacing the OEM narrowband with my LC-1.
Offline
Sep 1, 2009, 11:55 AM
What do you mean "stuffed up"? How is space an issue?
Offline
Sep 1, 2009, 03:48 PM
Personal Sales Rating: ( 6)
Drives: 2008 Evolution X & 1996 Eclipse GSX
I think that's UK/Aussie English for "messed up".
__________________
Chris Wirth
RochesterDSM.org
2008 GG Evolution X (New numbers soon!)
- Garrett GT3076R
- Full-Race Tubular Exhaust Manifold - 800 CC Inj - Walbro FP
- ETS 4" FMIC - ETS 2.5" IC Pipes - AMS Intake
- ETS 3" Dual CB - ATP O2 Downpipe w/ 44mm Tial
- MBC 25/27 psi - Works BOV - EcuFlash Tune
- ACT-ME1-HDG6 Clutch - ACT Streetlite Flywheel
- Selling Forge WGA, ETS Headers, & UR O2 DP
Offline
Sep 1, 2009, 05:00 PM
Drives: WW EvoX GSR
yup
__________________
Offline
Sep 2, 2009, 03:13 PM
If I could do it again I would slightly rotate the sensor to the right (maybe 30degrees, when looking towards the front of the car) so that both sensors have a bit more clearance from each other.
So tephra, the wideband should be 3 inches in front of the stock sensor but at a 10:30 o'clock position, passenger side? (considering a USDM LHD car)..
The stock o2 sensor is at a 12 o'clock position right (vertical)?
Offline
Sep 2, 2009, 03:15 PM
They also sell that socket at autozone..
Offline
Sep 2, 2009, 04:59 PM
Drives: WW EvoX GSR
funks - if your looking towards the front of the car (being under it) the wideband should be at like 0130..
make sense?
__________________
Offline
Sep 3, 2009, 10:19 AM
make sense?
Just to clarify one more time before I start drilling the hole - lol..
So on a USDM-LHD car - if viewing the downpipe from the front (bumper) of the car looking back if then it should be 10:30 position (around 315 degrees) should be pointing up/left towards the passenger side..
Basically, reversed compared to the location shown in the following pics - eq. AMS widemouth downpipe
Offline
Sep 3, 2009, 11:26 AM
Drives: 08 Evo X GSR
that looks good to me...nice pic btw
__________________
brandon
gg evo x gsr
toyota fjc
gg evo ix mr -- sold
Offline
Sep 3, 2009, 05:05 PM
Drives: WW EvoX GSR
yeah that will work.
the two after market piece you have will have the 02 sensor coming out at horizontal almost...
next time your under the car just take a look - you will see there is a lot of space above the pipe..
__________________
Offline
Tags
02, band, bung, cat, downpipe, evo, front, lc1, narrow, oxygen, pipe, post, replace, sensor, simulator, wideband  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
