Yeah I run MX1 Cams and when I first got them in the car it ran like sheet. Idling rough, stalling, and then I upgraded my COBB AP and it finally cleared the LTFT's when I reset the ECU and then all of a sudden it started idling right and has ran with no problems ever since even after un-installing the COBB AP software and using ECUFLASH and changing maps. It seems to run decent on any map I use now, however It does seem to seek up and down sometimes depending on if it's warmed up or not which I am told is normal for CAMS. Sometimes it will idle at 900 RPM sweetly and other times it will seek up and down from 900 to 1,200 back down to 600 and back up to 900 RPM in a repeating cycle. Just varries from day to day.
Does anyone have any MIVEC MAPS\Cam Phasing Maps, ROM's, COBB AP RACE MAPS they use with COSSWORTH MX1 CAMS that I can look at? Hiboost? Hollywood X? Anyone?
Please PM me if you do! Thanks!
__________________
EVO X MR 08' Wicked White
HP 321\TQ 325\91 Oct
MODS:
Cobb Access port w/Surgeline Map
Cobb SF Intake
DynoComp Tuned
TurboSmart BOV (un-installed for testing)
HKS UIP/LICP
AMS FMIC
Cosworth MX1 CAMS
Walbro 255 Fuel Pump and High Flow Filter kit
5Zigen Pro Racer ZZ Exhaust
Ultimate Racing Mini Muffler Test Pipe
AVC-R Boost Controller (un-installed)
