Enabling mode23 is really quite easy but it took me an hour of reading though quite a few posts for it to click. hopefully this will help others save time. Do this at your own risk
1) Get an open port 2.0 cable
2)Install Evoscan(
http://www.limitless.co.nz/) & ECU Flash(
http://www.openecu.org/index.php?title=EcuFlash). ECU Flash contains the drivers you will need for the OP2 cable.
3) Head out to your car and hook up your OP2 cable to your laptop. Open up ECU Flash and download your current ROM.
4) Identify your ROM ID
5) go to:
Evo X Logging to get the changes you need to make the the xml metadata for Ecu Flash. The ROM ID you just got from above will tell you which 3 lines of XML you will need.
6) Open up your XML metadata definition file located at C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
the definition file will have the same name as your ROMID
If your ROM looks like the next image then you will need to edit the base file it inherits from. In this example the ROM ID was 52680018. This ROM definition inherits from 52680015.
Copy the XML from step 5 and paste it BEFORE </rom>
7) open up (close it and re-open if is still open) ECU Flash and open the ROM you downloaded in step 3
8) You will now need to edit 3 values. The changes you made the the XML file add 3 entries under the Misc. header in ECU Flash
The 3 changes highlighted above tell you what your changing the values to.
The 1st entry you will change the value from 0x05 to 0x23
The 2nd entry you will change the value from 0x05 to 0x23
The 3rd entry you will change the value from 0x42 to 0x52
9) After making the 3 changes save your ROM and flash it back to your car
10) fire up Evoscan and start logging with mode23 enabled.
Evoscan beta 18 - verified
This thread is just a simple step by step how-to. If you have any technical questions please direct them to
Evo X Logging Tephra gets full credit for enabling mode23. Any questions in regards to the steps I listed above I should be able to answer
please let me know if i missed anything
