Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine Management / Tuning Forums
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 7, 2009, 07:59 AM   #31
Personal Sales Rating: (4)
Drives: 08 PB EvoX
Quote:
Originally Posted by boostin20 View Post
I just got done spending some time trying to put those tables in different places. I tried putting them in 15, then 15mod, then 18; I also tried putting them in 15, 15mod, and 18 at the same time with no luck. I also tried modifying the address from 0x7f121, etc by taking out the x first, then tried taking out the 0x so the address read7f121, 8ab11,etc. Nothing made those tables show up. I did completely exit out of xml editor and ecuflash each time I made a change to a definition. Any ideas?
Am I correct that I'm changing the 52680015 definition in the rommet>mitsu>evo>52680015 file, and that is supposed to add those tables for whatever saved rom image (.hex) for rom id 52680018 when I open them in ecuflash?
Is it actually saving the changes? Some people have their permissions wrong, so when you make a change, save it to the desktop then drag it into the rom folder.
You should only need to change the 15.
Offline
Old Oct 7, 2009, 08:44 AM   #32
Personal Sales Rating: (0)
boostin20's Avatar
Drives: OB Evo X GSR, 72 c-10
When I close it and open the file later it shows up so I'm thinking it's saving. I will try saving to desktop first.
Edit: I ran as administrator in order to move the file from desktop to rommetdata and replaced the 52680018. It still doesn't show up. I got pissed and uninstalled/reinstalled ecuflash and tried again. No luck. I'm starting to get pretty frustrated.
Offline
Old Oct 7, 2009, 09:17 AM   #33
Drives: 08 PB EvoX
Haha, you're just having all the luck, aren't you?
Make sure your ECUFlash is pointing to the right directory (the same one you changed the files in). Make sure your file is actually being edited (open it with Wordpad after you save it). Make sure you're changing the right file for the ROM you want to open (if you change say, the MR XML, it won't show up until you open a MR ROM).
If none of that works, PM me.
Offline
Old Oct 7, 2009, 09:24 AM   #34
boostin20's Avatar
All of this can be done with the cable disconnected from the car, correct? I assumed this could be done all through the definitions file and checking to see those 3 new tables show up by opening ecuflash and loading my rom.
Pm'ed you.
Offline
Old Oct 7, 2009, 09:51 AM   #35
boostin20's Avatar
I just got it. The 52680015 inherits from evoxbase.xml. I placed it in misc there and it showed up. Note: I don't have it in def 52680015, only in evoxbase. Now onto the placing the config.txt...
Offline
Old Oct 16, 2009, 06:17 PM   #36
Personal Sales Rating: (1)
mpboost's Avatar
Drives: 2008 EVO X
Great pictorial.
Coming from an ECUflash/EVOscan newbie, these step by step instructions were of great benefit.
Now its time to log, log, and log some more
__________________
08 Apex Silver EVO X: stock, daily driver
Offline
Old Oct 18, 2009, 10:02 AM   #37
Personal Sales Rating: (3)
DVDee's Avatar
Drives: WW EvoX
I seem to be having a problem with step 8. When I click set data I don't get the small window that says enter value or expression. Anyone know what the problem might be?
__________________
Performance Mods: Nisei UIP - Ecutek Tune by Dynoflash @ ICS Performance Dynojet - Forge WGA - Forge Unos MBC - SX HFC w/ WB bung - Tsudo N1 Extreme Exhaust
Interior Mods: Defi White Racer Gauge - AEM UEGO WideBand
Exterior Mods: 20% Tints all around - Faux CF wing inserts
Offline
Old Oct 18, 2009, 10:30 AM   #38
Drives: 08 PB EvoX
Open the table, click the cell with the number in it, and push "=".
Does it work then?
Offline
Old Oct 18, 2009, 06:10 PM   #39
DVDee's Avatar
Drives: WW EvoX
It works. Thx.
__________________
Offline
Old Oct 19, 2009, 03:39 PM   #40
Hrm, I think that the 15-20 Memory locations also apply to Rom 21. Just FYI in case anyone is wondering. Rom 21 says that it inherits from 15.
verkion
Offline
Tags
adding, enabling, illustrated, mode23, rom
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
